03-19-2007, 17:05 | #1 (permalink) |
No Life Poster Join Date: Apr 2005 Location: mars
Member: 132881 Status: Offline Thanks Meter: 105 | sagdd not detected on laptop Last edited by toptech; 03-20-2007 at 16:37. Reason: wrong headline |
03-20-2007, 17:17 | #2 (permalink) |
No Life Poster Join Date: Nov 2005 Location: MATRIX.REAL
Member: 202333 Status: Offline Thanks Meter: 178 | ok man try this download file attached unzip it lunch install.bat reboot your pc all will be okay tested by me this file will renitilise parametre of your windows LPT as well to working with your JTAG THX test and post result |
03-22-2007, 08:05 | #3 (permalink) |
Member: 132881 Status: Offline Thanks Meter: 105 | thanx will test i have taken it and will test it and then get bakc to you.on another note i have tried to unlock sesagem phones using this phone on my other computer nad i keep getting the bootloader failed when it gets to 60%.i have tried two different adapters on each model and i keep getting the message.i have also tried to shorten the tp cable but still the same message comes up.what else could be the problem.by the way i got this box new in january and up till now i have never unlocked a single phone,please help me |
03-24-2007, 09:18 | #8 (permalink) | |
No Life Poster Join Date: Apr 2005 Age: 45
Member: 139388 Status: Offline Thanks Meter: 98 | Quote:
1)Yes first check wht Mr.matrix.real said.If it not works then 2)Try to chance the crystal.It is the last chance to solve the problem.If it not works then no other go.Throw u r box and buy new one | |
03-26-2007, 08:37 | #9 (permalink) | |
No Life Poster Join Date: Apr 2005 Location: india
Member: 135945 Status: Offline Thanks Meter: 85 | Quote:
Tks for the throwing suggeestion! but i was wondering if its possible to chnge the mcu into a metal box? both are original ofcoursce! pls inform? WBR ReyTech. | |
03-29-2007, 07:43 | #12 (permalink) |
Member: 132881 Status: Offline Thanks Meter: 105 | thats not correct because the same cable works on the other boxes as well as the other computer where i get the bootloader failed problem.i have realised that the metal boxes have a problem bacause some has the problem that i have.they have not been able to unlock a single phone too using this box.face it gentlemen there is a problem with these boxes.iam just going to have to return mine to my reseller.hopefully it works. |
03-29-2007, 08:40 | #13 (permalink) |
No Life Poster Join Date: Feb 2002 Location: Europe
Member: 9544 Status: Offline Thanks Meter: 5,533 | @toptech There is not plastic boxes since 18 months. If box can`t read phone info on one PC he did`t read it on all other PC. If box shows "Bootloader failed " on one PC he will shows same on all other PC. Of course all cables (LPT, USB, box cable) must be connected and USB power +5V must be OK! BTW, plastic boxes can work without USB cable on some PC, because these boxes not have LED-s. So, contact reseller and solve your problem. Good luck! |
03-29-2007, 12:32 | #15 (permalink) |
Member: 9544 Status: Offline Thanks Meter: 5,533 | @ReyTech I not understand you! You are registered user. About similar specific question you must use support mail - www.sagdd.net. This way you will get answers and reccomendation faster. BTW, you can change MCU, but you must change account too. BR! |
how to protect my dongle against dongle not responding | softel2004 | SAGEM JTAG UNLOCKER | 1 | 12-03-2007 09:57 |
dongle not responding | vazgsm | SAGEM JTAG UNLOCKER | 2 | 03-17-2006 16:33 |
jatg dongle not responding !!! | gsmsalik | SAGEM JTAG UNLOCKER | 6 | 03-09-2006 14:52 |
PROBLEM: Dongle not responding! | gedan | SAGEM JTAG UNLOCKER | 4 | 12-21-2005 16:16 |
dongle not responding | valibuzauro | SAGEM JTAG UNLOCKER | 1 | 09-23-2005 20:40 |
