03-13-2013, 16:24 | #1 (permalink) |
No Life Poster Join Date: Nov 2009 Location: huanuco-peru
Member: 1168673 Status: Offline Sonork: 100.1638333 Thanks Meter: 232 | sagem my101l I have my cable box + Sagem JTAG. [IMG]http://www.************/forum/uploads/monthly_04_2009/post-3085-1240976310.jpg[/IMG] |
03-13-2013, 22:46 | #2 (permalink) |
No Life Poster Join Date: Jun 2002 Location: East Europe Age: 51
Member: 12837 Status: Offline Thanks Meter: 2,740 | There is two type of My10x phones : - half of part are unlockabe via TP, and rest of them can be done via data cable only. All depends of MCU type. How to check it - search in section , we explain details several times. |
03-15-2013, 15:37 | #3 (permalink) |
Member: 1168673 Status: Offline Sonork: 100.1638333 Thanks Meter: 232 | PROBLEM: Failed to read IMEI! PROBLEM: Failed to read IMEI! PROBLEM: Choose COM Port! PROBLEM: Bootloader failed! 1. Remove the battery and then insert it again! 2. Press Power ON shortly! Phone not started or wrong speed chosen! PROBLEM: Bootloader failed! 1. Remove the battery and then insert it again! 2. Press Power ON shortly! PROBLEM: Bootloader failed! 1. Remove the battery and then insert it again! 2. Press Power ON shortly! PROBLEM: Failed to read IMEI! PROBLEM: Setting phone speed failed! PROBLEM: Setting phone speed failed! PROBLEM: Setting phone speed failed! PROBLEM: Bootloader failed! 1. Remove the battery and then insert it again! 2. Press Power ON shortly! PROBLEM: Bootloader failed! 1. Remove the battery and then insert it again! 2. Press Power ON shortly! |
