10-14-2006, 20:01 | #5 (permalink) |
No Life Poster Join Date: Dec 2004 Location: Algeria
Member: 96141 Status: Offline Thanks Meter: 200 | IMEI: 35610700416523-2; PROBLEM: Bootloader failed! Phone Info: 324210701516 KB3,ZH: 211005 1207; HT (18 25 01); Phone Code: 00000000 i used x5-2 tp, i got always failed with this myx5-2v !! is it supported? somtime it stops at 50 and sometimes at 70. my tp is ok, and cable too, i already short it and i used to read phones in the first try. is myx5-2v supported? |
10-14-2006, 21:46 | #6 (permalink) |
No Life Poster Join Date: Feb 2002 Location: Europe
Member: 9544 Status: Offline Thanks Meter: 5,533 | @.:bono:. Supported! Remember, no more not supported HT for SagemDD_V4.6 or upper. Probably your problem is wrong TP connection or bad TP adapter. Check again TP connection. |
05-26-2012, 18:52 | #9 (permalink) |
Freak Poster Join Date: Apr 2008 Location: Free Palestine
Member: 755916 Status: Offline Thanks Meter: 28 | [QUOTE=latigido;2035636]@.:bono:. Supported! Remember, no more not supported HT for SagemDD_V4.6 or upper. Probably your problem is wrong TP connection or bad TP adapter. Check again TP connection.[/QUOTE me too the same problem here is log : Phone Info: 301147256398 KB3,ZI: 130306 1847; HT (D4 87 01); Phone Code: 00000000 [05/26/12 14:22:08] IMEI: 35610900729370-6; PROBLEM: Bootloader failed! Dozen times withe adptor and with wire what's wrong? |
05-26-2012, 20:02 | #11 (permalink) |
Member: 9544 Status: Offline Thanks Meter: 5,533 | @wahid_2 Same answer to you! http://forum.gsmhosting.com/vbb/2035636-post6.html Better read carefully this post http://forum.gsmhosting.com/vbb/3242996-post1.html All explained clearly! |
05-26-2012, 21:23 | #12 (permalink) | |
Member: 755916 Status: Offline Thanks Meter: 28 | Quote:
thanks or ur comprehension | |
05-26-2012, 22:43 | #13 (permalink) | |
Member: 9544 Status: Offline Thanks Meter: 5,533 | @wahid_2 Once again, read carefully http://forum.gsmhosting.com/vbb/3242996-post1.html Check what MCU inside, because ; Quote:
Do you see any difference between TP picture for myX5-2 and myX5-2V pcb? | |
05-27-2012, 14:37 | #14 (permalink) |
Member: 96141 Status: Offline Thanks Meter: 200 | @wahid_2, try with data cable from phone connector via com port, without any test point, any result ? maybe it's new mcu. |
The Following User Says Thank You to .:bono:. For This Useful Post: |
Sagem myx5 Help!! | djsri | Sagem Hardware Repair Area | 5 | 08-21-2005 08:35 |
myx5 eng mode | djsri | ARM9 BASED M62 / M62+ | 0 | 12-04-2002 13:40 |
Sagem myx5 user maunal | robbiesl42 | ARM9 BASED M62 / M62+ | 0 | 12-03-2002 18:36 |
myx5 help | djsri | Phone Unlocking Codes & Maps | 0 | 12-02-2002 22:21 |
Where 2 get MyX5 unlocked? | my329 | ARM9 BASED M62 / M62+ | 0 | 11-05-2002 13:28 |
