Go Back   GSM-Forum > Product Support Sections > No More Supported Solutions (Dead Products) > No More Supported H/W Products > SAGEM JTAG UNLOCKER
Old 06-10-2012, 10:10   #1 (permalink)
shahzaadbutt's Avatar
Member: 123458
Sonork: 100.1594535
Thanks Meter: 3,299
Question MyX-5m Unlock Problem
IMEI: 35305500482049-1; PROBLEM: Bootloader failed!
Phone Info: 253701456809 JF3,9K: 050704 1925; HT (22 00 00); Phone Code: 00000000
PROBLEM: Sending Phone Info Command failed!
TPs are ok check 100 times but same problem
Old 06-10-2012, 11:54   #2 (permalink)
Member: 12837
Thanks Meter: 2,740
All about "Bootloader failed" error :
- bad TP adapter;
- wrong TP connection;
- too long "cable + wires" - total length must be less than 30 cm;
- damaged TP on board or in MCU - always use solder iron with 24V heater.
____SagemJTAGUnlocker Support____
Old 06-10-2012, 11:58   #3 (permalink)
Member: 9544
Thanks Meter: 5,533
@shahzaadbutt
Phone unlocking supported since 7 years.
TP connections are not OK!
100%!
Old 06-10-2012, 15:33   #4 (permalink)
Member: 123458
Sonork: 100.1594535
Thanks Meter: 3,299
Direct unlock succeeded.
1. Remove the battery and then insert it again!
2. Power ON phone!
3. Press 'Space' key, 'Enter' key or 'Direct Unlock' button!
IMEI: 35305500482049-1; L40: 18622334-00; L00: 07788810-17;
atlast done
with same tp wires & length
and tps are also ok i check in microscope
Unlocking 5190 Ryu Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 23 01-07-2018 17:14
$50 Reward for unlocking my 6150!!! TheDon Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 5 03-23-2015 15:21
Page generated in 0.24364 seconds with 8 queries
