Go Back   GSM-Forum > Product Support Sections > No More Supported Solutions (Dead Products) > No More Supported H/W Products > SAGEM JTAG UNLOCKER
Old 03-19-2009, 18:55   #1 (permalink)
Member: 369802
Thanks Meter: 82
problem with repairing sim lock without sim on v56.x5-2v and myx6-2
pls i need help on this model v56,x5-2v and myx6-2.when i try to repair simlock without sim on v56 and x5-2v repair hardware failure will be done,crc also will be done but still simlock. when repairing myx6-2 only hardware failure will be done but crc will fail and still simlock.anyone or sag dd team can help me on this thanks
Old 03-19-2009, 19:03   #2 (permalink)
Member: 12837
Thanks Meter: 2,740
Check both options 'Hardware Failure' and 'CRC ' then press |REPAIR| btn.
Also don't apply UNLOCK after CRC repair!
p.s next time post enough information : phone info, error message log, etc.
Old 03-19-2009, 19:16   #3 (permalink)
Member: 9544
Thanks Meter: 5,533
@segun4u
Also post IMEI`s. So we can check what is the real situation, because there is something wrong in your post!
Remember, finalization for phones flashed by other tolses is forbidden!
Old 03-19-2009, 20:22   #4 (permalink)
Member: 369802
Thanks Meter: 82
Originally Posted by latigido View Post
@segun4u
does this means if phone is flashed with other tools and result to simlock without sim it cannot be repair with sagdd
Old 03-19-2009, 20:41   #5 (permalink)
Member: 9544
Thanks Meter: 5,533
@segun4u
Do yo know what is difference between forbidden and cannot?
Old 03-19-2009, 20:59   #6 (permalink)
Member: 369802
Thanks Meter: 82
@segun4u
no sir im not good in english,are this two word thesame or difference pls make me clear.thanks
Old 03-20-2009, 16:15   #7 (permalink)
zaki_barika's Avatar
Member: 135661
Thanks Meter: 92
i think he flashed this phone with smti without finalization "free" and try repairing with Sagdd also "free"
nice action ?????
LATIGIDO : just for info why its forbidden
Old 03-20-2009, 17:48   #8 (permalink)
Member: 9544
Thanks Meter: 5,533
@zaki_barika
Your post contains the answer!
Old 06-11-2009, 09:21   #9 (permalink)
gsm9l's Avatar
Member: 343657
Sonork: 100.1575777
Thanks Meter: 7,102
Hey here is the log for the same problem after unlock I got "sim problem" for myx5-2v,
also I tryed with CRC and Repair like you said ... what to do
Repair completed successfuly.
IMEI: 35240501154588-1;
Phone Info: 263255478091 LA5,8I: 250406 1625; HT (21 05 01); Phone Code: 0000
Direct unlock succeeded.
1. Remove the battery and then insert it again!
2. Power ON phone!
3. Press 'Space' key, 'Enter' key or 'Direct Unlock' button!
IMEI: 35240501154588-1; Code: 41829798-34;
IMEI: 35240501154588-1; Log: $HM1KxFvAmJxXyZ5A3RO4kbGDF6tEAtF5uSpVBOdPMHooBI3Ec IqyuFCi3wbg6nRBQnvPCsDbROIBFMXQ4hGnBVr3adQ5B4NdYBr gEXGhU9n9DzOke3VbDqS5mz+mI6XXy4II9oIW9QD
PROBLEM: Failed to read IMEI!
IMEI: 35240501154588-1; Log: $xMvzhZzJ6mnjvg8VqCVuKLSYh5VMBMerGire4SO2hAYs8f34c 6sfNPY+HB7e4J0m95cl85CR6VCzh5ChMk76HaAdijM9wWWf4wS 8YHzsBNSzHZIMN-xv+iyUwaT-koEdEkQgxMjlKb-
IMEI: 35240501154588-1; Log: $8xrufLRWpWF6-I6rWYcm46LpRRGlto0Evu6fnKOqkeXhyfmC+rmsKzmKCnf09Xl NhiBW9oqDvG+
PROBLEM: Setting phone speed failed!
Old 06-11-2009, 09:58   #10 (permalink)
gsm9l's Avatar
Member: 343657
Sonork: 100.1575777
Thanks Meter: 7,102
Solved thank's to cdor
WBR,
gsm9l
Old 07-05-2010, 20:17   #11 (permalink)
DomnulV's Avatar
Member: 1447
Thanks Meter: 97
How ?..I'm in this situation..sim problem...
Old 07-06-2010, 09:08   #12 (permalink)
gsm9l's Avatar
Member: 343657
Sonork: 100.1575777
Thanks Meter: 7,102
Sorry but I don't remember
(Cred ca a fost ceva Repair cu CRC bifat si conexiune la net)
WBR,
gsm9l
Old 07-06-2010, 09:30   #13 (permalink)
Member: 9544
Thanks Meter: 5,533
@gsm9l
@DomnulV
CRC repair is server based operation.
So, you must connect client aplication to the server before Repair.
Old 01-11-2011, 12:57   #14 (permalink)
MIRPUR AJK's Avatar
Member: 725834
Thanks Meter: 921
Stop spaming!
otherwise you will be banned!
Insert Sim And Sim Lock Without Sim PARMATMA Redbox 3 02-15-2006 10:03
how can i repair my-v55 sim locked without sim inside after flashing with sws-sag asmar Redbox 8 02-06-2006 01:38
my-x5 sim lock without sim? Chawkiz_gsm ARM9 BASED M62 / M62+ 6 02-06-2003 21:15
How To Repair MW3026 SIM Locked Without SIM blinet Infineon C16X M51 & ARM7 M52 BASED 2 01-21-2003 09:48
Sim Locked without SIM on 922 S5-D2 - how to repair? Bogi Infineon C16X M51 & ARM7 M52 BASED 2 10-26-2001 01:09
Page generated in 0.25136 seconds with 9 queries
