05-18-2008, 09:23 | #1 (permalink) |
No Life Poster Join Date: Apr 2007 Location: INDIA-uttranchal-rishikesh Age: 47
Member: 484665 Status: Offline Sonork: 100.1578012 Thanks Meter: 175 | problem to run sagem dd software I HAVE NO ANTIVIRUS INSTALLED ANY MATE HELP ME SOON???????????????PLZZZZZZZ THE ANT................... |
05-18-2008, 11:23 | #2 (permalink) |
No Life Poster Join Date: Jun 2002 Location: East Europe Age: 51
Member: 12837 Status: Offline Thanks Meter: 2,740 | It's not SagDD application error - you know because utilize it already. Better take a look at yours OS features : http://support.microsoft.com/kb/875351 |
05-18-2008, 14:00 | #4 (permalink) |
No Life Poster Join Date: Aug 2005 Location: 突尼斯 Age: 38
Member: 172136 Status: Offline Sonork: 100.1574973 Thanks Meter: 777 | here is a best description: XP SP2: How to Turn Off the Data Execution Prevention feature (DEP) Several OSs have no-execute or execute protection. Microsoft has added this as well in SP2 with data execution prevention (DEP). This precents code execution in memory regions already marked as storage. This is a powerful tool against buffer overrun exploits. If a program is failing and you want to disable DEP to see if that is the cause. Here are the steps. (Just disable DEP for the program in question... don't disable it for your whole system.)
05-18-2008, 14:01 | #5 (permalink) |
Member: 172136 Status: Offline Sonork: 100.1574973 Thanks Meter: 777 | Enabling DEP for all Programs on Your Computer The default configuration for hardware and software DEP protects core Windows components and services and has a minimal impact on application compatibility, but you can choose to configure DEP to protect all applications and programs on your computer. If you configure DEP to protect all applications and programs on your computer you will have the benefit of additional protection, but it might lead to additional application compatibility issues. If you configure DEP to protect all applications and programs on your computer, you can exempt individual 32-bit applications from software DEP protection if they have compatibility issues. You cannot disable hardware DEP or exempt 64-bit applications running on 64-bit Windows XP systems with DEP compatible processors. Requirements to perform this task •Credentials: You must log on to your computer using an account with local Administrator rights. Configuring DEP to protect all applications To enable the DEP for all applications 1. Click Start, and then click ControlPanel. 2. Under Pickacategory, click PerformanceandMaintenance. 3. Under or Pick a Control Panel icon, click System. 4. Click the Advanced tab. Figure 1 System Properties - Advanced tab 5. In the Performance area, click Settings. Figure 2 Performance Options 6. Click the DataExecutionPrevention tab. Figure 3 Data Execution Prevention tab 7. Select Turn on DEP for all programs and services except for those I select. 8. Click Apply, and then click OK. A dialog box appears and informs you that you must restart your computer for the setting to take effect. Click OK. Verifying DEP Settings for all Programs Are Applied To verify DEP settings for all programs are applied 1. Click Start, and then click ControlPanel. 2. Under Pickacategory, click PerformanceandMaintenance. 3. Under or Pick a Control Panel icon, click System. 4. Click the Advanced tab. 5. In the Performance area, click Settings and then click DataExecutionPrevention. 6. Verify that Turn on DEP for all programs and services except for those I select is selected and then click OK to close Performance Settings. 7. Click OK to close SystemProperties then close PerformanceandMaintenance. Top of page Enabling the DEP Exception List If DEP causes a problem with your applications, a dialog box appears to let you know. Figure 4 Dialog box that appears if an application has attempted to execute and has encountered a problem with DEP In cases where DEP causes application failures, Microsoft strongly recommends that you contact the application vendor to determine if a DEP-compatible update is available. Installing such an update is the preferred solution for application compatibility issues with DEP. If no update is available for your application, follow these steps to access and to configure the Exception List. The Exception List is the list of applications that are excluded from DEP. Note: The DEP exception list functionality is only available if the DEP configuration is set to protect all programs and services. If you configure your computer to protect only essential Windows components and services, the exception list is unavailable. Requirements to perform this task •Credentials: You must log on to your computer using an account with local Administrator rights. Enabling the DEP Exception List To enable the DEP exception list 1. Click Start, and then click ControlPanel. 2. Under Pickacategory, click PerformanceandMaintenance. 3. Under or Pick a Control Panel icon, click System. 4. Click the Advanced tab. Figure 5 System Properties - Advanced tab 5. In the Performance area, click Settings. Figure 6 Performance Options 6. Click the DataExecutionPrevention tab. Figure 7 Data Execution Prevention tab 7. Click Add. 8. Locate and select the executable for the application that is failing, and then click Open. 9. In the warning box, click OK. The selected program now appears in the DEP program area. 10. Click Apply, and then click OK. A dialog box appears and informs you that you must restart your computer for the setting to take effect. Click OK. Verifying DEP Exception List Settings Are Applied To verify Memory Protection settings are applied 1. Click Start, and then click ControlPanel. 2. Under Pickacategory, click PerformanceandMaintenance. 3. Under or Pick a Control Panel icon, click System. 4. Click the Advanced tab. 5. In the Performance area, click Settings and then click DataExecutionPrevention. 6. Verify that the exception list contains the desired programs and then click OK to close PerformanceSettings. 7. Click OK to close SystemProperties then close PerformanceandMaintenance. |
05-18-2008, 14:04 | #6 (permalink) | |
Member: 484665 Status: Offline Sonork: 100.1578012 Thanks Meter: 175 | Quote:
thanks for help u r good team mate....... u r care to our customer....... the ant............. | |
how to run pinfinder box software without infinity box....? | GSMBALOCH | Infinity-Box | 10 | 01-23-2009 17:55 |
Any way to run series 60 softwares on series 60 3rd edition phone's. | neerajgour | Nokia Multimedia | 0 | 10-23-2006 13:14 |
problem to run philips software | chowdary | Redbox | 12 | 02-21-2006 17:51 |
who got problem to run all new sagem 2.1 (or 2.3) with dongle?? | infogsm | Infineon C16X M51 & ARM7 M52 BASED | 17 | 11-16-2003 22:54 |
