11-04-2009, 22:42 | #1 (permalink) |
Freak Poster Join Date: Dec 2003 Location: Spain Age: 41
Member: 46247 Status: Offline Thanks Meter: 8 | Problems with my302x Sagemdd Cable my-c2 I have conected login, but... Wich is my problem? 11/04/09 22:23:23] Phone Info: 080234151010 LB5,4F: 101006 1008; HT (38 05 01); Phone Code: 0000 [11/04/09 22:23:25] IMEI: 35772100160757-1; PROBLEM: Bootloader failed! [11/04/09 22:23:30] [11/04/09 22:23:30] Phone Info: 080234151010 LB5,4F: 101006 1008; HT (38 05 01); Phone Code: 0000 [11/04/09 22:23:32] IMEI: 35772100160757-1; PROBLEM: Bootloader failed! [11/04/09 22:24:58] [11/04/09 22:25:07] PROBLEM: Setting phone speed failed! [11/04/09 22:25:35] [11/04/09 22:25:38] Phone Info: 120110083045 LB5,4F: 101006 1008; HT (38 05 01) [11/04/09 22:25:40] IMEI: 35772100160543-5; PROBLEM: Bootloader failed! [11/04/09 22:32:37] [11/04/09 22:32:37] Phone Info: 120110083045 LB5,4F: 101006 1008; HT (38 05 01); Phone Code: 0000 [11/04/09 22:32:39] IMEI: 35772100160543-5; PROBLEM: Bootloader failed! [11/04/09 22:32:52] [11/04/09 22:32:52] Phone Info: 120110083045 LB5,4F: 101006 1008; HT (38 05 01); Phone Code: 0000 [11/04/09 22:32:54] IMEI: 35772100160543-5; PROBLEM: Bootloader failed! |
11-04-2009, 22:55 | #2 (permalink) |
Member: 46247 Status: Offline Thanks Meter: 8 | Problem solved I use rj45 to usb fdi sagdd Sorry. Direct unlock succeeded. IMEI: 35772100160561-7; Code: 29205733-55; 1. Remove the battery and then insert it again! 2. Press Power ON shortly! Direct unlock succeeded. IMEI: 35772100160757-1; Code: 41295256-84; 1. Remove the battery and then insert it again! 2. Press Power ON shortly! PROBLEM: Bootloader failed! 1. Remove the battery and then insert it again! 2. Press Power ON shortly! Direct unlock succeeded. IMEI: 35772100160543-5; Code: 08791638-24; 1. Remove the battery and then insert it again! 2. Press Power ON shortly! PROBLEM: Connect to the server first! |
The Following User Says Thank You to Carlazos For This Useful Post: |
Problem with unlocking Samsung E1080 | ..::alexis::.. | HWK | 18 | 09-25-2011 14:23 |
big problem with my mx key | sshreesai | MXKEY Nokia Flasher and Unlocker (by Alim Hape) | 4 | 03-31-2010 10:07 |
problem with nokia 6234 | pachicoo | Universalbox | 2 | 03-29-2010 15:19 |
.: Strange Problem with T610 power on with p-supply but never with battrey :. | Jani-Jan | Sony Ericsson Hardware Repair | 5 | 05-25-2004 16:31 |
