02-18-2010, 21:16 | #2 (permalink) |
No Life Poster Join Date: Feb 2002 Location: Europe
Member: 9544 Status: Offline Thanks Meter: 5,533 | @wzupfones Do you wish to be supported??? So, follow our recomendations (many times repeated), read flash.bin (slow option), send it to [email protected] or upload somewhere. I hope it`s not so difficult! |
02-18-2010, 21:27 | #3 (permalink) | |
No Life Poster Join Date: Apr 2008 Location: INSIDE OCLHASHCAT
Member: 751235 Status: Offline Sonork: 100.1662008 Thanks Meter: 526 | ok Quote:
when i send now when will it be added cos the owner want to take it away.... i have 2000 pcs | |
02-18-2010, 21:40 | #5 (permalink) |
Member: 9544 Status: Offline Thanks Meter: 5,533 | @wzupfones You are strange user! We want just simple file ( flash.bin), not phone or someting additional. So read that flash.bin. Only SagDD supports S305+ now. So, these 2000 phones will be unlocked with SagDD. Maybe by you, maybe by someone else! |
02-18-2010, 23:23 | #9 (permalink) |
Super Moderator Join Date: Jul 2008 Location: Villa del rosario/Nsd Colombia
Member: 813309 Status: Offline Thanks Meter: 1,912 | hi here new firmware zte s305 new boot claro no support please add Firmware: ES-DOM-CLARO-P108A7(Z)V1.0.0B03 IMEI: 354286032854884 Press Power ON shortly! Remove the battery and then insert it again! PROBLEM: Direct unlock failed! http://www.mediafire.com/?jeyngr3myoq thanks please send me beta test by pm or icq thanks |
The Following User Says Thank You to Braycel For This Useful Post: |
02-18-2010, 23:27 | #10 (permalink) |
Member: 813309 Status: Offline Thanks Meter: 1,912 | hi this is log s305 comcel colombia Firmware: ES-CO-COMCEL-P108A8(V)-SST-V1.0.0B01 IMEI: 359906010050347 Press Power ON shortly! Remove the battery and then insert it again! IMEI: 35990601005034-7 Direct unlock succeeded. |
02-19-2010, 07:57 | #11 (permalink) | |
Member: 9544 Status: Offline Thanks Meter: 5,533 | Quote:
Already supported. Flash Read (fast) works if phone accept loaders. But some ZTE phones are very sensitive to cable parameters. Try to find USB data cable or USB to COM convertor which works stable with these phones. Also close all not used COM ports. Post result. | |
ZTE S305 not supported | GSM SOLUTION. | FuriousGold | 3 | 02-27-2010 14:27 |
My box is "dead". Show only "." and not working. Update not working! | GSMtricks | Multi-Box | 1 | 12-09-2008 21:04 |
My box is "dead". Show only "8" and not working. Update not working! | MobiLuy.co.yu | Multi-Box | 11 | 08-22-2007 07:52 |
PBB not work :( 1st day not work | todoportable | Phoenix Black Box | 23 | 08-05-2005 11:56 |
