03-11-2010, 15:20 | #2 (permalink) |
No Life Poster Join Date: Jun 2009 Location: My Laptop
Member: 1052732 Status: Offline Sonork: 100.1616786 Thanks Meter: 3,145 | G1157 Direct unlock succeeded. IMEI: 35633403719994-3 1. Remove the battery and then insert it again! 2. Press Power ON shortly! IMEI: 356334037199943 Firmware: REL_P1.2PU04V01.04 |
03-11-2010, 15:21 | #3 (permalink) |
Member: 1052732 Status: Offline Sonork: 100.1616786 Thanks Meter: 3,145 | G1157 Direct unlock succeeded. IMEI: 35633403719853-1 1. Remove the battery and then insert it again! 2. Press Power ON shortly! IMEI: 356334037198531 Firmware: REL_P1.2PU04V01.04 |
03-11-2010, 15:22 | #4 (permalink) |
Member: 1052732 Status: Offline Sonork: 100.1616786 Thanks Meter: 3,145 | G1157 Direct unlock succeeded. IMEI: 35633403720036-0 1. Remove the battery and then insert it again! 2. Press Power ON shortly! IMEI: 356334037200360 Firmware: REL_P1.2PU04V01.04 |
03-11-2010, 15:24 | #5 (permalink) |
Member: 1052732 Status: Offline Sonork: 100.1616786 Thanks Meter: 3,145 | Direct unlock succeeded. IMEI: 35633403720053-5 1. Remove the battery and then insert it again! 2. Press Power ON shortly! IMEI: 356334037200535 Firmware: REL_P1.2PU04V01.04 |
03-11-2010, 15:25 | #6 (permalink) |
Member: 1052732 Status: Offline Sonork: 100.1616786 Thanks Meter: 3,145 | Direct unlock succeeded. IMEI: 35633403720169-9 1. Remove the battery and then insert it again! 2. Press Power ON shortly! IMEI: 356334037201699 Firmware: REL_P1.2PU04V01.04 |
03-11-2010, 15:26 | #7 (permalink) |
Member: 1052732 Status: Offline Sonork: 100.1616786 Thanks Meter: 3,145 | G1157 Direct unlock succeeded. IMEI: 35633403719917-4 1. Remove the battery and then insert it again! 2. Press Power ON shortly! IMEI: 356334037199174 Firmware: REL_P1.2PU04V01.04 |
03-11-2010, 15:27 | #8 (permalink) |
Member: 1052732 Status: Offline Sonork: 100.1616786 Thanks Meter: 3,145 | Direct unlock succeeded. IMEI: 35633403719400-1 1. Remove the battery and then insert it again! 2. Press Power ON shortly! IMEI: 356334037194001 Firmware: REL_P1.2PU04V01.04 |
03-11-2010, 15:56 | #10 (permalink) |
Member: 1052732 Status: Offline Sonork: 100.1616786 Thanks Meter: 3,145 | G1157 Direct unlock succeeded. IMEI: 35633403720366-1 1. Remove the battery and then insert it again! 2. Press Power ON shortly! IMEI: 356334037203661 Firmware: REL_P1.2PU04V01.04 |
03-11-2010, 15:57 | #11 (permalink) |
Member: 1052732 Status: Offline Sonork: 100.1616786 Thanks Meter: 3,145 | G1157 Direct unlock succeeded. IMEI: 35633403719908-3 1. Remove the battery and then insert it again! 2. Press Power ON shortly! IMEI: 356334037199083 Firmware: REL_P1.2PU04V01.04 |
03-11-2010, 16:00 | #13 (permalink) |
Member: 1052732 Status: Offline Sonork: 100.1616786 Thanks Meter: 3,145 | A136 (zong) Direct unlock succeeded. IMEI: 35435403072329-3 1. Remove the battery and then insert it again! 2. Press Power ON shortly! IMEI: 354354030723293 Firmware: EUZ-PK-CMPAK-P108E2FM(G)(S)V1.0.0B10 |
v3 unlock succesfully unlock | lilong_lee | Smart-Clip | 0 | 10-20-2009 12:14 |
k550 cid 53 unlock succese by Ultimate Unlocker v1.01 | binod | Cruiser Suite | 0 | 09-28-2008 11:09 |
CAN SAGDD UNLOCK SG346i | denard | SAGEM JTAG UNLOCKER | 2 | 05-16-2007 08:52 |
Myx6-2 Can Sagdd Unlock It? | denard | SAGEM JTAG UNLOCKER | 4 | 04-18-2007 19:28 |
Who have unlocked succesfully nec 331i with direct unlock? | Uvedovle | Redbox | 0 | 02-06-2006 19:11 |
