04-01-2014, 14:46 | #556 (permalink) | |
Junior Member Join Date: Jan 2010 Location: Central African Republic
Member: 1216580 Status: Offline Sonork: 100.1614325 Thanks Meter: 0 | g2158 Connect phone powered on ! Start auth ! SW Ver: REL_P1.1EN01V01.03 Imei: 358892035292596 SIGN READ FAILED ! Error ... ! Time needed - 00:00:02 Quote:
04-02-2014, 21:49 | #557 (permalink) |
No Life Poster Join Date: Jun 2002 Location: East Europe Age: 51
Member: 12837 Status: Offline Thanks Meter: 2,740 | brayanedenice question All G2158 version are fully supported HERE, but you log are not from Sagem Jtag Unlocker software... so, post it in correct section. |
05-05-2014, 08:15 | #558 (permalink) |
Member: 654997 Status: Offline Sonork: 1613804(Don't Spam Plz) Thanks Meter: 4,073 | G2201c Unlock Done :) Code: Elapsed Time: 00:00:22 Required Time: 00:00:17 Direct unlock succeeded. IMEI: 35962003159xxx-x 1. Remove the battery and then insert it again! 2. Press Power ON shortly! IMEI: 35962003159xxxx Firmware: 09.03.03:21.38.01:09.04.00:ULC2GPRS |
05-07-2014, 06:25 | #559 (permalink) |
Member: 654997 Status: Offline Sonork: 1613804(Don't Spam Plz) Thanks Meter: 4,073 | G2201c Unlock Done : Code: Elapsed Time: 00:00:20 Required Time: 00:00:17 Direct unlock succeeded. IMEI: 35962003159572-3 1. Remove the battery and then insert it again! 2. Press Power ON shortly! IMEI: 359620031595723 Firmware: 09.03.03:21.38.01:09.04.00:ULC2GPRS |
05-07-2014, 06:29 | #560 (permalink) |
Member: 654997 Status: Offline Sonork: 1613804(Don't Spam Plz) Thanks Meter: 4,073 | G2201c Unlock Done :) Code: Elapsed Time: 00:00:20 Required Time: 00:00:17 Direct unlock succeeded. IMEI: 35962003159807-3 1. Remove the battery and then insert it again! 2. Press Power ON shortly! IMEI: 359620031598073 Firmware: 09.03.03:21.38.01:09.04.00:ULC2GPRS |
05-07-2014, 06:31 | #561 (permalink) |
Member: 654997 Status: Offline Sonork: 1613804(Don't Spam Plz) Thanks Meter: 4,073 | G2201c Unlock Done :) Code: Elapsed Time: 00:00:18 Required Time: 00:00:17 Direct unlock succeeded. IMEI: 35962003159574-9 1. Remove the battery and then insert it again! 2. Press Power ON shortly! IMEI: 359620031595749 Firmware: 09.03.03:21.38.01:09.04.00:ULC2GPRS |
05-07-2014, 06:33 | #562 (permalink) |
Member: 654997 Status: Offline Sonork: 1613804(Don't Spam Plz) Thanks Meter: 4,073 | G2201c Unlock Done :) Code: Elapsed Time: 00:00:19 Required Time: 00:00:17 Direct unlock succeeded. IMEI: 35962003159560-8 1. Remove the battery and then insert it again! 2. Press Power ON shortly! IMEI: 359620031595608 Firmware: 09.03.03:21.38.01:09.04.00:ULC2GPRS |
05-07-2014, 06:42 | #563 (permalink) |
Member: 654997 Status: Offline Sonork: 1613804(Don't Spam Plz) Thanks Meter: 4,073 | G2201c Unlock Done :) Code: Elapsed Time: 00:00:23 Required Time: 00:00:21 Direct unlock succeeded. IMEI: 35962003159556-6 1. Remove the battery and then insert it again! 2. Press Power ON shortly! IMEI: 359620031595566 Firmware: 09.03.03:21.38.01:09.04.00:ULC2GPRS |
05-07-2014, 06:44 | #564 (permalink) |
Member: 654997 Status: Offline Sonork: 1613804(Don't Spam Plz) Thanks Meter: 4,073 | G2201c Unlock Done :) Code: Elapsed Time: 00:00:19 Required Time: 00:00:17 Direct unlock succeeded. IMEI: 35962003159554-1 1. Remove the battery and then insert it again! 2. Press Power ON shortly! IMEI: 359620031595541 Firmware: 09.03.03:21.38.01:09.04.00:ULC2GPRS |
05-07-2014, 06:48 | #565 (permalink) |
Member: 654997 Status: Offline Sonork: 1613804(Don't Spam Plz) Thanks Meter: 4,073 | G2201c Unlock Done :) Code: Elapsed Time: 00:00:19 Required Time: 00:00:17 Direct unlock succeeded. IMEI: 35962003159529-3 1. Remove the battery and then insert it again! 2. Press Power ON shortly! IMEI: 359620031595293 Firmware: 09.03.03:21.38.01:09.04.00:ULC2GPRS |
05-07-2014, 06:51 | #566 (permalink) |
Member: 654997 Status: Offline Sonork: 1613804(Don't Spam Plz) Thanks Meter: 4,073 | HUAWEI G2201c Unlock DOne :) Code: Elapsed Time: 00:00:21 Required Time: 00:00:17 Direct unlock succeeded. IMEI: 35962003159569-9 1. Remove the battery and then insert it again! 2. Press Power ON shortly! IMEI: 359620031595699 Firmware: 09.03.03:21.38.01:09.04.00:ULC2GPRS |
05-07-2014, 06:53 | #567 (permalink) |
Member: 654997 Status: Offline Sonork: 1613804(Don't Spam Plz) Thanks Meter: 4,073 | G2201C Unlock Done :) Code: Elapsed Time: 00:00:22 Required Time: 00:00:17 Direct unlock succeeded. IMEI: 35962003159547-5 1. Remove the battery and then insert it again! 2. Press Power ON shortly! IMEI: 359620031595475 Firmware: 09.03.03:21.38.01:09.04.00:ULC2GPRS |
05-13-2014, 14:52 | #568 (permalink) |
Member: 654997 Status: Offline Sonork: 1613804(Don't Spam Plz) Thanks Meter: 4,073 | ZTE Z100 Unlock Done :) Code: Elapsed Time: 00:00:20 Required Time: 00:00:16 Direct unlock succeeded. IMEI: 35286504149869-2 1. Remove the battery and then insert it again! 2. Press Power ON shortly! IMEI: 352865041498692 Firmware: E-PK-CMPAK-P108A34FM(S)V1.0.0B03 |
07-08-2014, 21:02 | #569 (permalink) |
Freak Poster Join Date: Nov 2005 Location: Romania Age: 46
Member: 198519 Status: Offline Sonork: 100.1604680 Thanks Meter: 63 | vodafone 236 direct unlock ok Elapsed Time: 00:00:19 Required Time: 00:00:15 Direct unlock succeeded. IMEI: 352785034XXXXX-X 1. Remove the battery and then insert it again! 2. Press Power ON shortly! IMEI: 352785034XXXXXX Firmware: ED-DE-P108E6(S)V1.0.0B05 |
10-11-2014, 09:53 | #570 (permalink) |
Member: 654997 Status: Offline Sonork: 1613804(Don't Spam Plz) Thanks Meter: 4,073 | Huawei T156 Unlock Done :) Code: Elapsed Time: 00:00:22 Required Time: 00:00:14 Direct unlock succeeded. IMEI: 35814603157616-7 1. Remove the battery and then insert it again! 2. Press Power ON shortly! IMEI: 358146031576167 Firmware: P1.2PU01V01.02 |
