Successfully Unlocked/repaired Phones By SagDD Post all Successfully Unlocked/repaired Phones By SagDD Zte z100 unlock ok Code: Direct unlock succeeded. |
HUAWEI t156 unlock ok |
For me thread is useless ... because there no other results for officially supported phones. Anyway you can post yours results here... :) |
Direct unlock succeeded. IMEI: 352865****1513-3 1. Remove the battery and then insert it again! 2. Press Power ON shortly! IMEI: 352865****15133 Firmware: E-PK-CMPAK-P108A34FM(S)V1.0.0B03 |
g2158 Direct unlock succeeded. IMEI: 35889203239492-4 1. Remove the battery and then insert it again! 2. Press Power ON shortly! IMEI: 358892032394924 Firmware: REL_P1.1PU01V01.03 |
Direct unlock succeeded. IMEI: 35308103372903-2 1. Remove the battery and then insert it again! 2. Press Power ON shortly! IMEI: 353081033729032 Firmware: P1.2PU01V01.01 |
Direct unlock succeeded. IMEI: 35942801005812-1 1. Remove the battery and then insert it again! 2. Press Power ON shortly! IMEI: 359428010058121 Firmware: P1.2nV01.05:ULC2GL |
Z100>>>{zong}unlock! Direct unlock succeeded. IMEI: 35286504012387-9 1. Remove the battery and then insert it again! 2. Press Power ON shortly! IMEI: 352865040123879 Firmware: E-PK-CMPAK-P108A34FM(S)V1.0.0B03 {ahmadge} |
Direct unlock succeeded. IMEI: 35814603011528-0 1. Remove the battery and then insert it again! 2. Press Power ON shortly! IMEI: 358146030115280 Firmware: P1.2PU01V01.01 {ahmadge} |
Direct unlock succeeded. IMEI: 35286504014249-9 1. Remove the battery and then insert it again! 2. Press Power ON shortly! IMEI: 352865040142499 Firmware: E-PK-CMPAK-P108A34FM(S)V1.0.0B03 {ahmadge} |
Direct unlock succeeded. IMEI: 35889203216086-1 1. Remove the battery and then insert it again! 2. Press Power ON shortly! IMEI: 358892032160861 Firmware: REL_P1.1PU01V01.03 {ahmadge} |
Direct unlock succeeded. IMEI: 35889203203664-0 1. Remove the battery and then insert it again! 2. Press Power ON shortly! IMEI: 358892032036640 Firmware: REL_P1.1PU01V01.03 {ahmadge} |
Direct unlock succeeded. IMEI: 35308103479456-3 1. Remove the battery and then insert it again! 2. Press Power ON shortly! IMEI: 353081034794563 Firmware: P1.2PU02V01.01 {ahmadge} |
Direct unlock succeeded. IMEI: 35308103890073-7 1. Remove the battery and then insert it again! 2. Press Power ON shortly! IMEI: 353081038900737 Firmware: P1.2PU01V01.01 {ahmadge} |
Z100 {zong new} unlock done. Direct unlock succeeded. IMEI: 35286504006588-0 1. Remove the battery and then insert it again! 2. Press Power ON shortly! IMEI: 352865040065880 Firmware: E-PK-CMPAK-P108A34FM(S)V1.0.0B03 {ahmadge} |
