01-04-2011, 14:49 | #226 (permalink) |
No Life Poster Join Date: Oct 2007 Location: Unknown
Member: 603971 Status: Offline Thanks Meter: 730 | G2158 unlock done. Required Time: 00:00:12 Direct unlock succeeded. IMEI: 35889203358563-7 1. Remove the battery and then insert it again! 2. Press Power ON shortly! IMEI: 358892033585637 Firmware: REL_P1.1PU01V01.06 {ahmadge} |
01-04-2011, 15:48 | #227 (permalink) |
No Life Poster Join Date: Oct 2005 Location: Pakistan
Member: 192810 Status: Offline Sonork: Some people NEED change Thanks Meter: 860 | G1157 Unlock Done Elapsed Time: 00:00:16 Required Time: 00:00:13 Direct unlock succeeded. IMEI: 35633403724077-0 1. Remove the battery and then insert it again! 2. Press Power ON shortly! IMEI: 356334037240770 Firmware: REL_P1.2PU04V01.04 |
01-05-2011, 13:04 | #228 (permalink) |
Freak Poster Join Date: May 2006 Location: Gomel Belarus Age: 47
Member: 283936 Status: Offline Thanks Meter: 109 | ZTE a711g by velcom Belorusia unlock ok. ZTE a711g by velcom Belorusia unlock ok. Code: [01/05/11 13:48:00] Firmware: ER-BY-VELCOM-P108B1(G)V1.0.0B05 [01/05/11 13:48:00] IMEI: 354979021540312 [01/05/11 13:48:00] [01/05/11 13:48:01] 2. Press Power ON shortly! [01/05/11 13:48:01] 1. Remove the battery and then insert it again! [01/05/11 13:48:01] [01/05/11 13:48:33] IMEI: 35497902154031-2 [01/05/11 13:48:34] Direct unlock succeeded. [01/05/11 13:48:34] Required Time: 00:00:30 [01/05/11 13:48:34] Elapsed Time: 00:00:36 |
The Following 2 Users Say Thank You to aborigenn For This Useful Post: |
01-06-2011, 17:20 | #229 (permalink) |
Member: 192810 Status: Offline Sonork: Some people NEED change Thanks Meter: 860 | Z100 Unlock Done Elapsed Time: 00:00:14 Required Time: 00:00:11 Direct unlock succeeded. IMEI: 35286504307587-8 1. Remove the battery and then insert it again! 2. Press Power ON shortly! IMEI: 352865043075878 Firmware: E-PK-CMPAK-P108A34FM(S)V1.0.0B04 |
01-08-2011, 14:32 | #230 (permalink) |
Member: 654997 Status: Offline Sonork: 1613804(Don't Spam Plz) Thanks Meter: 4,073 | T156 Unlock done Elapsed Time: 00:00:20 Required Time: 00:00:13 Direct unlock succeeded. IMEI: 35308103452317-8 1. Remove the battery and then insert it again! 2. Press Power ON shortly! IMEI: 353081034523178 Firmware: P1.2PU02V01.01 |
01-08-2011, 14:34 | #231 (permalink) |
Member: 654997 Status: Offline Sonork: 1613804(Don't Spam Plz) Thanks Meter: 4,073 | Z100 unlock done Elapsed Time: 00:00:17 Required Time: 00:00:11 Direct unlock succeeded. IMEI: 35286504290404-5 1. Remove the battery and then insert it again! 2. Press Power ON shortly! IMEI: 352865042904045 Firmware: E-PK-CMPAK-P108A34FM(S)V1.0.0B03 |
01-09-2011, 10:03 | #232 (permalink) |
Member: 654997 Status: Offline Sonork: 1613804(Don't Spam Plz) Thanks Meter: 4,073 | ZTE Z100 Unlock done Elapsed Time: 00:00:16 Required Time: 00:00:11 Direct unlock succeeded. IMEI: 35286504215229-8 1. Remove the battery and then insert it again! 2. Press Power ON shortly! IMEI: 352865042152298 Firmware: E-PK-CMPAK-P108A34FM(S)V1.0.0B04 |
01-10-2011, 08:29 | #233 (permalink) |
Member: 654997 Status: Offline Sonork: 1613804(Don't Spam Plz) Thanks Meter: 4,073 | T156 Unlock done Elapsed Time: 00:00:19 Required Time: 00:00:13 Direct unlock succeeded. IMEI: 35308103465680-4 1. Remove the battery and then insert it again! 2. Press Power ON shortly! IMEI: 353081034656804 Firmware: P1.2PU02V01.01 |
01-10-2011, 10:57 | #234 (permalink) |
Member: 192810 Status: Offline Sonork: Some people NEED change Thanks Meter: 860 | T156 Unlock Done Elapsed Time: 00:00:12 Required Time: 00:00:06 Direct unlock succeeded. IMEI: 35942801002325-7 1. Remove the battery and then insert it again! 2. Press Power ON shortly! IMEI: 359428010023257 Firmware: P1.2nV01.05:ULC2GL |
01-10-2011, 10:58 | #235 (permalink) |
Member: 192810 Status: Offline Sonork: Some people NEED change Thanks Meter: 860 | G2158 Unlock Done Elapsed Time: 00:00:19 Required Time: 00:00:11 Direct unlock succeeded. IMEI: 35889203152346-5 1. Remove the battery and then insert it again! 2. Press Power ON shortly! IMEI: 358892031523465 Firmware: REL_P1.1PU01V01.03 |
01-10-2011, 10:59 | #236 (permalink) |
Member: 192810 Status: Offline Sonork: Some people NEED change Thanks Meter: 860 | Z100 Unlock Done Elapsed Time: 00:00:15 Required Time: 00:00:11 Direct unlock succeeded. IMEI: 35286504010019-0 1. Remove the battery and then insert it again! 2. Press Power ON shortly! IMEI: 352865040100190 Firmware: E-PK-CMPAK-P108A34FM(S)V1.0.0B03 |
01-13-2011, 14:52 | #237 (permalink) |
Member: 603971 Status: Offline Thanks Meter: 730 | 3 ><z100{zong} unlock done Elapsed Time: 00:00:16 Required Time: 00:00:11 Direct unlock succeeded. IMEI: 35286504012053-7 1. Remove the battery and then insert it again! 2. Press Power ON shortly! IMEI: 352865040120537 Firmware: E-PK-CMPAK-P108A34FM(S)V1.0.0B03 Elapsed Time: 00:00:19 Required Time: 00:00:16 Direct unlock succeeded. IMEI: 35286504006588-0 1. Remove the battery and then insert it again! 2. Press Power ON shortly! IMEI: 352865040065880 Firmware: E-PK-CMPAK-P108A34FM(S)V1.0.0B03 Elapsed Time: 00:00:17 Required Time: 00:00:12 Direct unlock succeeded. IMEI: 35286504043479-7 1. Remove the battery and then insert it again! 2. Press Power ON shortly! IMEI: 352865040434797 Firmware: E-PK-CMPAK-P108A34FM(S)V1.0.0B03 {ahmadge} |
01-17-2011, 10:44 | #238 (permalink) |
Member: 192810 Status: Offline Sonork: Some people NEED change Thanks Meter: 860 | T156 Unlock Done Elapsed Time: 00:00:18 Required Time: 00:00:14 Direct unlock succeeded. IMEI: 35308103413981-9 1. Remove the battery and then insert it again! 2. Press Power ON shortly! IMEI: 353081034139819 Firmware: P1.2PU01V01.01 Elapsed Time: 00:00:16 Required Time: 00:00:13 Direct unlock succeeded. IMEI: 35308103808736-0 1. Remove the battery and then insert it again! 2. Press Power ON shortly! IMEI: 353081038087360 Firmware: P1.2PU03V01.01 |
The Following User Says Thank You to DUNIYA JAMAL For This Useful Post: |
01-18-2011, 14:08 | #239 (permalink) |
Member: 654997 Status: Offline Sonork: 1613804(Don't Spam Plz) Thanks Meter: 4,073 | T156 Unlock done Elapsed Time: 00:00:18 Required Time: 00:00:13 Direct unlock succeeded. IMEI: 35308103953162-2 1. Remove the battery and then insert it again! 2. Press Power ON shortly! IMEI: 353081039531622 Firmware: P1.2PU01V01.01 |
01-19-2011, 10:37 | #240 (permalink) |
Member: 654997 Status: Offline Sonork: 1613804(Don't Spam Plz) Thanks Meter: 4,073 | ZTE Z100 unlock done Elapsed Time: 00:00:17 Required Time: 00:00:11 Direct unlock succeeded. IMEI: 35286504215227-2 1. Remove the battery and then insert it again! 2. Press Power ON shortly! IMEI: 352865042152272 Firmware: E-PK-CMPAK-P108A34FM(S)V1.0.0B04 |
