Go Back   GSM-Forum > Product Support Sections > No More Supported Solutions (Dead Products) > No More Supported H/W Products > SAGEM JTAG UNLOCKER
Old 11-16-2005, 15:02   #16 (permalink)
i_seeque's Avatar
Member: 15238
Thanks Meter: 128
Originally Posted by latigido
@i_seeque
Sagem schemes are not available!
But schemes can`t help you for resolving described problem.
It means that except the unlock code provided by that specific operator, there is no other way to unlock such phone.
Or stolen database can help.
Like i got an myv55 with TP broken and locked to voda-uk. So in this case the logs are also not useful. And needle / pencil / direct solders - all are not giving results.
So sir, latigido - wat can be done ??
Old 11-16-2005, 21:07   #17 (permalink)
electrosoft's Avatar
Member: 93850
Thanks Meter: 48
Hi ihope that help you
Old 11-25-2005, 08:20   #18 (permalink)
i_seeque's Avatar
Member: 15238
Thanks Meter: 128
Thanks for the PIC - That's great effort. The similar thing was stated in my earlier post.
http://forum.gsmhosting.com/vbb/show...7&postcount=14
Originally Posted by i_seeque
......The revealation leads towards cpu. If sc...
Once again thanks a lot.
Old 05-01-2006, 16:39   #19 (permalink)
mrfixit's Avatar
Member: 60899
Thanks Meter: 792
another idea if broken testpoint, use microscope and sharp knife.
Old 05-04-2006, 17:26   #20 (permalink)
pnganga's Avatar
Member: 70343
Thanks Meter: 38
Thumbs up Thanks latigido!
Thank you latigido for your answer. I've had a few of these and had no clue what to do with them.
Old 05-04-2006, 19:02   #21 (permalink)
dynamic-gsm's Avatar
Member: 166385
Thanks Meter: 282
hehehe , i also test it..100/100 work , as i say sagem jitag is best tool for this time .
br dynamic .
Old 06-07-2006, 12:11   #22 (permalink)
webshawk's Avatar
Member: 107267
Thanks Meter: 62
Great i fill pencil at broken TP and i solve my problem.... Just do it if you are in truble like me....
Old 11-03-2006, 08:17   #23 (permalink)
Irfangk786's Avatar
Member: 146630
Thanks Meter: 21
great info about broken Test point good job
Old 11-20-2006, 10:01   #24 (permalink)
Irfangk786's Avatar
Member: 146630
Thanks Meter: 21
MyV-56
Originally Posted by latigido View Post
@electrosoft
Use so called needles method!
Solder needle to wire for broken TP, solder wires to others 3 TP.
Press top of the needle to brocken TP(near centre) and try to unlock phone.
If you are lucky you will get codes after first try, if no - after more than 20 tryes!
Advisable, insulate needle from fingers!
Received one MyV-56 Boken all 4 Test points.Pic is attached any solution about this prob.
Old 11-20-2006, 14:45   #25 (permalink)
Member: 9544
Thanks Meter: 5,533
@Irfangk786
Did you tried this nice solution?
http://forum.gsmhosting.com/vbb/show...50&postcount=7
Old 01-24-2007, 11:58   #26 (permalink)
Member: 207598
good work..............................................
Old 02-22-2007, 13:53   #27 (permalink)
Member: 201209
Thanks Meter: 5
Thank you about the ideea with the graphite!
Old 06-17-2007, 04:55   #28 (permalink)
malikzahidawan's Avatar
Member: 251421
Sonork: 100.1609329
Thanks Meter: 439
thanks Alot Nice Support Really its helpful,
keep it Up
Doc Unlock
Old 12-06-2007, 06:17   #29 (permalink)
naeem janjua's Avatar
Member: 155992
Sonork: 1585672
Thanks Meter: 171
i solved my problem with pencel it really works.
thanks for the sulotion.
Old 01-13-2008, 16:03   #30 (permalink)
meknes gsm's Avatar
Member: 376587
Thanks Meter: 8
thanks!!!!!!!!!!!!!!!!!!!!!!!!!
g1157 Test Point broken ejazakbar905 FuriousGold 0 03-26-2010 13:51
myx1w test point broken GSM RAJ Sagem Hardware Repair Area 3 01-31-2006 06:22
A-50 Test Point Broken Help !!!! amitks_in Siemens Hardware Repair Area 3 04-28-2005 22:02
Page generated in 0.28779 seconds with 10 queries
