06-10-2008, 09:12 | #1 (permalink) |
Junior Member Join Date: Oct 2006 Location: POLAND Age: 38
Member: 368256 Status: Offline Thanks Meter: 17 | unlock problem with sagem myx5-2v ! need help i'm try try try and nothing with few version software i'm connect to box Do jobs! 10% and nothing i'm need advice what i'm doing wrong? i'm try with Jtag and usb cable have question with this model is reqaierd internet connection to unlock when unlock? (needs logs?) this is what i'm see : PROBLEM: Failed to read IMEI! PROBLEM: Failed to read IMEI! PROBLEM: Failed to read IMEI! PROBLEM: Setting phone speed failed! PROBLEM: Setting phone speed failed! NEED HELP ! |
06-10-2008, 09:44 | #2 (permalink) |
No Life Poster Join Date: Nov 2005 Location: Moldova Age: 41
Member: 204045 Status: Offline Thanks Meter: 7 | IMEI: 35217901623645-3; PROBLEM: Bootloader failed! Phone Info: 027135026849 LA5,8L: 200906 1427; HT (2C 20 05); Phone Code: 0000 PROBLEM: Failed to read IMEI! The same problem BR |
06-10-2008, 09:52 | #3 (permalink) |
No Life Poster Join Date: Feb 2002 Location: Europe
Member: 9544 Status: Offline Thanks Meter: 5,533 | @ionelka Open your eyes, please! It`s not same problem. Seems you has not read thread about SageJtagUnlocker support! Read it. You will solve your problem very easy. @lukasss Can you connect another Sagem phones? |
06-10-2008, 10:02 | #4 (permalink) |
Member: 368256 Status: Offline Thanks Meter: 17 | yes this is my log with another sagem phone myx5-2 and unlock is successfull and no problem with read phon withmy box? Phone Info: 236718091455 KB3,ME: 150604 1452; HT (2F 00 00); Phone Code: 00000000 this is log with another sagem phone |
06-10-2008, 10:08 | #6 (permalink) |
Member: 9544 Status: Offline Thanks Meter: 5,533 | @lukasss Set Phone speed to "Speed AUTO", clean phone connector , check cable. If you can unlock even one Sagem, you will unlock all others from list of supported phones! Just check connectors and cables. |
06-10-2008, 10:30 | #7 (permalink) |
Member: 368256 Status: Offline Thanks Meter: 17 | yes i'm thing with clen coonnector and this is my first step, charge fulll baterry, second cable and my idea what wrong is over i'm have another question If my phone is usb only support unlock ( i'm need internet conection)? thiis is sagem myx5-2v i'm no have logs? |
06-10-2008, 10:36 | #8 (permalink) |
Member: 368256 Status: Offline Thanks Meter: 17 | my window on sagemJTAGUNLOCKER _______________________________________ 6,6% - Analysing phone, Please wait.... or 10% _______________________________________ PROBLEM: Failed to read IMEI! |
06-10-2008, 10:37 | #9 (permalink) |
Member: 9544 Status: Offline Thanks Meter: 5,533 | @lukasss Again and over again! SagemDD must read phone info with or without connected TP. (with old cable set, not with USB Data cable) So, you have cable or connector or another hardware problem. Or maybe you did funny mistake. |
06-10-2008, 15:31 | #12 (permalink) |
Member: 9544 Status: Offline Thanks Meter: 5,533 | @ionelka Thank, you! SagemDD software together with SagDD box supports all Sagem based on M62, M62+, Sec. M62+, M63, M64 platforms. All about unlocking these phones was explained here: http:///vbb/...d.php?t=526394 Good luck! |
problem with my furious i need help | ramazoti10 | FuriousGold | 3 | 02-06-2009 13:30 |
unlock 6280 with 1.09 BB5king ?? need help!! | roman2008 | BB5 No TP By Jafsupport | 1 | 12-07-2008 06:25 |
Vk200 Unlock Problem - Which Cable?? No Connection, Need Help?? | khem | Multi-Box | 3 | 08-15-2007 17:30 |
Problem with w6001, please i need help | darkacido | Cruiser Suite | 5 | 03-12-2007 06:15 |
