08-14-2008, 08:56 | #1 (permalink) |
Product Supporter Join Date: Oct 2007 Age: 39
Member: 609952 Status: Offline Sonork: 100.1574492 Thanks Meter: 154 | Unlocking Problem Phone Info: 678245293010 JA3,JE: 230904 1452; HT (22 00 00); Phone Code: 00000000 IMEI: 35285900503798-4; L40: 16249909-18; L00: 05478169-87; 3. Press 'Space' key, 'Enter' key or 'Direct Unlock' button! 2. Power ON phone! 1. Remove the battery and then insert it again! Direct unlock failed # can tell me what is the unlocking code of this mobile i will put in manulay or any other idead to unlock of this mobile thanks |
08-14-2008, 09:12 | #2 (permalink) | |
No Life Poster Join Date: Jun 2002 Location: East Europe Age: 51
Member: 12837 Status: Offline Thanks Meter: 2,740 | Quote:
There is 2 codes - L40: 16249909-18; L00: 05478169-87; try via first , if not success enter second one. If you don't know how to enter code - use 'Direct unlock' option | |
08-14-2008, 09:27 | #3 (permalink) |
Member: 609952 Status: Offline Sonork: 100.1574492 Thanks Meter: 154 | I TRY BOTH OF THEM BUT NOT UNLOCK THE MOBILE ( OK BUTTON IS BINLK BUT ON PRESS NO WORK ) I try to direct unlock but erro to unlock ( failed to direct unlock ) |
08-14-2008, 10:23 | #4 (permalink) | |
Not possible - did you check phone state before start unlocking? What write on phone lcd without sim in and when non operator sim plugged in ? Are you sure which code phone expect - network or phone code ? Direct unlock failed - if phone not restart automatically; made it manually. | |
08-14-2008, 12:04 | #5 (permalink) |
Member: 609952 Status: Offline Sonork: 100.1574492 Thanks Meter: 154 | i try to direct unlock but same reponce from mobile [08/14/08 16:27:04] Phone Info: 678245293010 JA3,JE: 230904 1452; HT (22 00 00); Phone Code: 00000000 [08/14/08 16:27:10] IMEI: 35285900503798-4; L40: 16249909-18; L00: 05478169-87; [08/14/08 16:27:10] [08/14/08 16:27:10] 3. Press 'Space' key, 'Enter' key or 'Direct Unlock' button! [08/14/08 16:27:10] 2. Power ON phone! [08/14/08 16:27:10] 1. Remove the battery and then insert it again! [08/14/08 16:27:15] [08/14/08 16:27:22] Direct unlock succeeded. mobile shows sim locked |
08-14-2008, 12:26 | #6 (permalink) |
No Life Poster Join Date: Feb 2002 Location: Europe
Member: 9544 Status: Offline Thanks Meter: 5,533 | @stan1comm Seems your phone shows SIM locked without SIM inside! This means that someone "big" master had damaged phone (not casually). What is the solution! Read old manuals. Solution is incredible simple. Make Hardware faiule and CRC repair together. You will have working unlocked phone. |
Samsung Jet S800 Unlock problem | javakiller | Z3X-Team Products | 8 | 05-15-2010 12:14 |
Alcatel ot 103 Unlock probleme | abote didier | Infinity-Box | 4 | 04-26-2010 17:04 |
Samsung Z630 unlock problem = 2 in 1 cable problem or.. | radez | Z3X-Team Products | 10 | 08-27-2008 22:19 |
w200 unlock problem i think exe problem please lead look here | saily | Cruiser Suite | 22 | 08-15-2007 14:31 |
