Go Back   GSM-Forum > Product Support Sections > No More Supported Solutions (Dead Products) > No More Supported H/W Products > SAGEM JTAG UNLOCKER
Old 10-14-2009, 17:33   #1 (permalink)
Member: 3508
Thanks Meter: 71
Unlocking with TP doesn't work?
Hi!
I have old Sagem JTAG box via LPT port, and before 2-3 months I can't unlock none of the phones which are connected via testpoints to unlock!!
I measured all testpoint lines to the atmel and all are ok!! I even made new testpoint cable but problem is the same!!
If I connect phone I always got bootloader failed!
For example this is 501C, but I tried with 10 other phones and always same problem!!
[10/14/09 17:42:30] IMEI: 35924100455891-9; PROBLEM: Bootloader failed!
[10/14/09 17:43:40]
[10/14/09 17:43:41] Phone Info: 830200546217 LA5,II: 220806 1005; HT (24 21 05); Phone Code: 0000
So what can be the problem!? What else can I try!?!?
Old 10-14-2009, 18:03   #2 (permalink)
Member: 9544
Thanks Meter: 5,533
@GSMBlade
Damaged JTAG interface or phones requires connection/unlocking with USB data cable.
Be more detailed.
What type are other 10 phones?
Old 10-14-2009, 18:18   #3 (permalink)
Member: 3508
Thanks Meter: 71
Originally Posted by latigido View Post
@GSMBlade
Be more detailed.
Old type phones, X5, X1, C4....they even can't be connected via USB!!
On the begining I thought that proble was in the phones but now I'm 100% shure that problem is in the box!!
So if is problem in the box I only can buy new one or is some way to repair it!?!
Old 10-14-2009, 18:30   #4 (permalink)
Member: 9544
Thanks Meter: 5,533
@GSMBlade
Damaged JTAG interface.
-resolder all component on box pcb;
-check protection resistors near RJ45 connector;
-check position of RJ45 spring pins.
Old 10-14-2009, 19:31   #5 (permalink)
Member: 3508
Thanks Meter: 71
@GSMBlade
I already resoldered all components on the box, checked protection resistors, and tried to solder testpoint wires direct on box PCB!!
So if I need new box is there any discount for users with damaged interface!?
Old 10-14-2009, 20:39   #6 (permalink)
Member: 9544
Thanks Meter: 5,533
@GSMBlade
Post box SN to [email protected].
We shall continue further correspondance via support mail.
BR!
The Following User Says Thank You to latigido For This Useful Post:
Anyone can send me a list of Which Sagem Model unlock With TP & Without TP. rajinder1978 SAGEM JTAG UNLOCKER 1 02-28-2009 16:46
Unlock my K800i doesn't work. Log gone phonk KULANKENDI Server 4 07-26-2007 14:01
Unlock by patch doesn't work for my U8180. hyds Cruiser Suite 6 12-10-2005 10:48
V66 Unlock! Patriot Clip Doesn't work! WHY? ESN Authority Motorola P2k 5 05-17-2004 04:04
HOV CAN I OPEN NOKIA PHONE IF THE COMUNICATION WITH MBUS DOESN'T WORK Marsovec Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 6 03-26-2000 20:23
Page generated in 0.16327 seconds with 9 queries
