12-24-2009, 14:51 | #1 (permalink) |
Insane Poster Join Date: May 2005 Age: 54
Member: 144417 Status: Offline Thanks Meter: 4 | Vodafone A136 unlock problem [12/24/09 15:20:54] Firmware: EH-HU-P108E5(S)V1.0.0B03 [12/24/09 15:20:54] IMEI: 352786038541320 [12/24/09 15:20:54] [12/24/09 15:20:54] 2. Press Power ON shortly! [12/24/09 15:20:54] 1. Remove the battery and then insert it again! [12/24/09 15:20:54] [12/24/09 15:21:13] IMEI: 35278603854132-0 [12/24/09 15:21:14] Direct unlock succeeded. [12/24/09 15:21:44] Firmware: EH-HU-P108E5(S)V1.0.0B03 [12/24/09 15:21:44] IMEI: 352786038554554 [12/24/09 15:21:44] [12/24/09 15:21:44] 2. Press Power ON shortly! [12/24/09 15:21:44] 1. Remove the battery and then insert it again! [12/24/09 15:21:44] [12/24/09 15:21:58] PROBLEM: Direct unlock failed! [12/24/09 15:33:48] Firmware: EH-HU-P108E5(S)V1.0.0B03 [12/24/09 15:33:48] IMEI: 352786038197651 [12/24/09 15:33:48] [12/24/09 15:33:48] 2. Press Power ON shortly! [12/24/09 15:33:48] 1. Remove the battery and then insert it again! [12/24/09 15:33:48] [12/24/09 15:34:04] IMEI: 35278603819765-1 [12/24/09 15:34:05] Direct unlock succeeded. Flash.bin readed succesfuly. [12/24/09 15:23:16] Firmware: EH-HU-P108E5(S)V1.0.0B03 [12/24/09 15:23:16] IMEI: 352786038554554 [12/24/09 15:23:16] [12/24/09 15:23:16] 2. Press Power ON shortly! [12/24/09 15:23:16] 1. Remove the battery and then insert it again! [12/24/09 15:23:16] [12/24/09 15:23:54] No active Phone Code [12/24/09 15:23:54] [12/24/09 15:23:54] Flash File Path: G:\Box\SagemDD\Flash.bin [12/24/09 15:23:54] Reading flash completed successfuly. |
12-24-2009, 15:10 | #2 (permalink) |
No Life Poster Join Date: Feb 2002 Location: Europe
Member: 9544 Status: Offline Thanks Meter: 5,533 | @ytris Try again! Some ZTE phones are very sensitive to the cable . If you can read flash.bin (Flash read fast), you could unlock the phone. Absolutelly! |
12-28-2009, 09:04 | #4 (permalink) |
No Life Poster Join Date: Feb 2005 Location: BAHOUAN
Member: 118601 Status: Offline Thanks Meter: 200 | man explan me how you do it because i have one A136 and ZTE A68+ but when connect, i have only phone not start even with phone power on like ask for those new Egold. i can't even succees to read flash. do you have TP for that phone? if cable problem i would like to soldered direct to phone pcb but under the battery TP is not look like those of other ZTE A35 for example. NB. when you say you solve it by disconect cable when ask for battery remove did put back the cable before end of procedure? |
ZTE A136 unlocking problem | zeerik | Infinity-Box | 3 | 09-22-2012 12:33 |
a136+ unlocking problem | shariq_3157 | Vodafone Star | 3 | 01-21-2010 16:12 |
vodafone 125 unlock problem | ..:::Gsm india:::.. | FuriousGold | 1 | 03-23-2008 06:46 |
vodafone 125 unlock problem... | shami | FuriousGold | 1 | 03-06-2008 10:25 |
Vodafone GX20 unlock problems. Nothing works for me. | mcmac | Sharp | 19 | 08-29-2004 17:01 |
