10-24-2005, 13:59 | #1 (permalink) |
No Life Poster Join Date: Apr 2003 Location: Sao Paulo - BRAZIL Age: 49
Member: 26751 Status: Offline Thanks Meter: 2 | Astro-Clip versus P207 and X480 Regards, Sergio |
10-24-2005, 14:53 | #2 (permalink) |
Product Supporter Join Date: Sep 2004 Age: 39
Member: 81703 Status: Offline Thanks Meter: 1,332 | I think that X480 is a white phone the same as P207, check that the phones yellow, red or green are just special phones. Maybe x480 can be a green one but I doubt it: 1. Connect 9V battery to the clip. 2. Power OFF your phone. 3. Connect Phone to the clip via right cable. 4. Press shortly unlock button in the clip. 5. If led goes Red press power ON in your phone and hold it until led goes Green - If led goes Green just wait. 6. Wait until led will blinks a few times. BR and post here if it worked well |
10-24-2005, 17:44 | #3 (permalink) | |
Member: 26751 Status: Offline Thanks Meter: 2 | Quote:
X480 is the same as T100 cable. Tried and phone turned on just after conecting cable. Unlocked using another method (software) and selecting C200 as model. Not sure what cable to use with P207. | |
10-26-2005, 22:13 | #9 (permalink) |
Member: 81703 Status: Offline Thanks Meter: 1,332 | P207 cable is Usb and you must buy it or home made. You can also use original Usb cable for D500.Then follow this procedure gived by AstroTeam: Unlock solution for P207 Phone: 1. Install Samsung USB Driver 2. Run Update Software For Clip 3. Connect Clip to PC Via Update Cable. 4. Press unlock button in the clip (Untill led will go from Red to Green) 5. Click (Direct Unlocker) 6. Connect Phone to PC Via P207 Usb Cable. 7. Check In system , What is your Virtual Comport for your Samsung phone. 8. Choose this Comport Number in your Virtual Comport. 9. Click (Unlock P207) Button Check that was not announced E760 it's now supported!!! BR Luskao[AstroTeam BetaTester] |
10-27-2005, 10:26 | #10 (permalink) |
Member: 26751 Status: Offline Thanks Meter: 2 | Ok, just saw... but things are not so clear to me... D500 must be original or any USB-D500 cable will do? My clip is updated (at least to the last file on support - just noticed siemens c62 installer are not there anymore). I must connect clip using USB, Ok. And phone connected to USB to my PC too, correct? So... what software should I use? Thanks for helping |
10-27-2005, 13:11 | #11 (permalink) |
Member: 81703 Status: Offline Thanks Meter: 1,332 | D500 must be original, no china cables. If you want pinout for usb p207 I will find you. You must download new updater with support for unlocking from PC. BR |
10-27-2005, 14:38 | #12 (permalink) |
Freak Poster Join Date: Jul 2005 Age: 50
Member: 167856 Status: Offline Thanks Meter: 4 | @sdantas: Pinout for Samsung P207 original OEM cable can be found here http://pinouts.ru/data/samsung_p207_pinout.shtml |
10-27-2005, 15:09 | #14 (permalink) |
Member: 167856 Status: Offline Thanks Meter: 4 | @sdantas: Sorry, feel free to be corrected but Samsung P207 via original OEM cable was supported since we released an update for it (1st October). But simply, we just forgot to add it's unlock procedure to the sticky guide. |
Nok DCT4 flasher, Samsung Easy clip & Astro clip For Sale | davesmobiles | Sell ur Old and Used Stuff | 1 | 03-20-2007 18:37 |
can W600i and Z520 be unlocked by Astro Clip? | winglik | Astro Clip | 1 | 01-22-2006 18:27 |
903sh and astro clip | Kevbodian | Astro Clip | 1 | 09-30-2005 15:57 |
Smart Clip versus Cxxx Vxxx clips...the new "unlocks war" !!?? | ffmp | Motorola P2k | 11 | 08-07-2004 17:21 |
