Go Back   GSM-Forum > Product Support Sections > No More Supported Solutions (Dead Products) > No More Supported H/W Products > Astro Clip
Old 11-14-2005, 14:53   #1 (permalink)
ali-g-string's Avatar
Member: 11099
e720 unlocking problem
Trying to unlock e720, when I do step 4 below. I pres unlcok, led light up red, I hold unlock button, but it does not go green, just stay red, no matter how long I hold.
What is wrong? I have updated latest firmware in clip
Unlock solution for Red marked phones:
1. Connect 9V battery to the clip.
2. Power OFF your phone.
3. Connect Cable to the clip - Do not connect phone yet.
4. Press unlock button in the clip (led will goes Red) and hold it until led goes Green and Red again.
5. Connect phone to the cable.
(If led will not goes green in a few seconds then press power ON button in your phone and hold it until led goes green).
6. Wait until led will blinks a few times.
Old 11-14-2005, 18:48   #2 (permalink)
AstroTeam's Avatar
Member: 167856
Are you using correct cable? Or, is the battery full?
Also make sure that you enter TAT mode.
Old 11-14-2005, 22:10   #3 (permalink)
Member: 184414
Hi, just unlocked an e720 this evening. Directions from the forum sticky didnt work for me either.
Through trial and error I was successful by connecting the correct (e810) cable then pressing unlock and power on on the phone simultaneously, then waiting for the flasing green light whilst keeping the two buttons depressed.
Not sure if this is the correct way, but it worked for me. Good luck
Regards
Andre
Old 11-15-2005, 15:01   #4 (permalink)
Member: 11099
thank you Andre
silly me I was using the cable labeled e720
Old 12-08-2005, 16:03   #5 (permalink)
UnlockBR's Avatar
Member: 26751
Hummm, I do need help.
I tried to unlock a E720 using E720 cable too. But I tried like "white" phone (pressing unlock and then power on). Grenn light went on, blinked a few times and turned off. Everything seemed ok, BUT now phone is dead (don't turn on). Any advice?
Just tried as otswald said but now don't work.
Any help apreciated
BR,
Sergio
Old 12-08-2005, 16:26   #6 (permalink)
AstroTeam's Avatar
Member: 167856
@UnlockBR:
Remove phone battery for 15-20 minutes and retry, if that did not work shortcut battery memory.
Old 12-09-2005, 15:33   #7 (permalink)
UnlockBR's Avatar
Member: 26751
Ok, unlocked it:
- pressed unlock button till light goes red and green again
- pressed power on button on the phone
- waited till green light blinks a few times
Used E810 cable.
Thanks,
Samsung Jet S800 Unlock problem javakiller Z3X-Team Products 8 05-15-2010 12:14
E720 Unlock Problem... shami UST Pro II 2 11-19-2007 15:07
E720 keypad problem!!!!!!!!! tofigno Samsung Hardware Repair Area 11 02-16-2006 22:41
E720 contrast problem O.K. magic3 Samsung Hardware Repair Area 16 09-07-2005 23:41
E720 LCD problem flash after simlockman1 NSPRO 7 08-03-2005 12:49
Page generated in 0.26782 seconds with 11 queries
