run time error'76' Path not found can any one help please when i open the astro updater this appears. Switching in TEST MODE.....OK. Reading clip INFO....OK. Producor Astro.Product date 07.01.2005. Last update 11.10.2005.SW Version 1.014. EEP Version ...... serial Number 10xxx ...Switching in NORMAL MODE ...OK. Then when i open the astro manager and press anything i get an alert box telling me run time error'76' Path not found. then on the astro manager display it will read Search Clip..Clip connected on Comm Port 4..Producer;Astro . Start Application. Can any one help with this please... http://www.freeyourmobile.com |
maybe there are some conflicts on ur computer ? |
Unfortunatly it happens on 2 different pc's has anyone at Astroclip seen this before? http://www.freeyourmobile.com |
Unfortantly this is an bug in the application which was compiled by Visual Basic. This problem will be resolved in the next version, meanwhile i will upload the updater separately at support area. Sorry if this may caused any inconvenience. |
Thank you. Apologies if I do not understand. Do we get the updater from the support area to fix this problem or do we wait for the next update. |
@alexbrowne Sorry, file is now uploaded in support area, at \Uploads. |
run time path error '76' hiya this run time path error is still happening I have uninstalled and reinstalled no joy any ideas or help? can anyone tell me where to go get starting instructions as i am finding the set up really confusing any help appreciated.THANKS cha 1888:mad: :mad: :( |
@cha1888: I have stated that this problem will be correct in next Astro Manager, meanwhile use the temporarily Astro Updater instead of Astro Manager. Astro Updater can be found at \Uploads - Astro-Clip Updater.zip. Other files can be found at \Astro Manager. |
