Go Back   GSM-Forum > Product Support Sections > No More Supported Solutions (Dead Products) > No More Supported H/W Products > Astro Clip
Old 11-23-2005, 15:21   #1 (permalink)
Member: 197720
Thanks Meter: 24
how do i know my clip is activated
I just bought an astro clip and the resseller told me it has been activated. how do I confirm that?
Old 11-23-2005, 17:17   #2 (permalink)
AstroTeam's Avatar
Member: 167856
Thanks Meter: 4
If you attach the clip in clip mode, you will be able to ''Read Clip info'' with Astro Manager, then check your SW Version.
About registration license for software add-on's, you will have to PM me your unique hardware identity to get an activated license.
Edit:
Latest version is 1014.
Old 11-23-2005, 17:50   #3 (permalink)
Member: 197720
Thanks Meter: 24
software version I read out was 1.010-1.001 is that activated if yes how do i upgrade to the latest veesion using the device manager?
Old 11-23-2005, 19:02   #4 (permalink)
AstroTeam's Avatar
Member: 167856
Thanks Meter: 4
Login to the support area and access the folder Clip firmware and download the version 1014 and connect your clip into Clip mode and run Astro Manager and press Write Update to Clip.
Old 11-23-2005, 20:12   #5 (permalink)
Member: 197720
Thanks Meter: 24
write update to clip is not highlited in device manager what does that surpose to mean?does that mean the box is not activated?
Old 11-23-2005, 20:20   #6 (permalink)
AstroTeam's Avatar
Member: 167856
Thanks Meter: 4
Sorry, we are not talking about device manager.
Astro Manager, you can find it on support area if you login and install it, cause i doubt higly that you don't have it on your PC.
I suggest you to read all the sticky threads available in our subforum here, it can be a big help for you.
Old 11-23-2005, 22:12   #7 (permalink)
Member: 197720
Thanks Meter: 24
sorry i was calling it device manager instead of asto manager.under the astro manager you have device manager confirm is that one you are talking about?
Old 11-23-2005, 22:40   #8 (permalink)
Member: 197720
Thanks Meter: 24
still very sorry there seems to be some confusion.under astro manager you have astro updater. then I hold the clip unlock button until the light turns green then i run astro updater under astro manager write update to phone not hilighted.desperate to use the clip
How do i know my iphone is a (non-mc model) vinny_02 iPhone 2 / iPhone 3G / iPhone 3GS 1 03-18-2010 06:46
How do i know my JAF dongle is from Thomas or Raskal? Cake J.A.F. By Jafsupport.com 14 03-12-2010 13:36
how do i know my DM is integrated with BIS not BES ? voltus BlackBerry (RIM) 0 07-22-2009 17:34
how can i know my vspec is activate already? wew J.A.F. V-SPEC 3 01-28-2008 13:03
how do i know if counter is blocked plug NEC 9 01-17-2005 22:59
Page generated in 0.15564 seconds with 9 queries
