BF, BG, TH, BHx Series Alcatel BF3/4 and also BG3 series, also THx, BHx are located here. |
04-10-2005, 15:10 | #1 (permalink) |
Freak Poster Join Date: Jan 2004 Age: 42
Member: 49044 Status: Offline Thanks Meter: 8 | bh4 dead after s2gsm orginal |
04-10-2005, 15:21 | #3 (permalink) |
Member: 49044 Status: Offline Thanks Meter: 8 | done already but i think its cable problem i tried with two difrent but still the same, but how phone become dead if software not sending anything, i mean is sending bootloader but nothing elese |
04-11-2005, 20:28 | #5 (permalink) |
Member: 49044 Status: Offline Thanks Meter: 8 | batterry is charged even when i use power supply, but even before i tried to conect with heenrich and wont connect with s2gsm conected but killed my phone i am getting crazzy i can find the reason |
04-12-2005, 15:05 | #6 (permalink) |
No Life Poster Join Date: Sep 2003 Location: Razgrad,Bulgaria Age: 39
Member: 39126 Status: Offline Thanks Meter: 12 | re! What OS you use? Henrich won't to connect ... strange? /... i had this problem on 102_283 ...once!/ I always use cable with external 9 volts battery - no problems !!! ... and NEVER s2gsm !!! When some soft won't to connect ... what other words can say about it?! Are you sure that each battery is charged? /phone & external/ |
04-12-2005, 15:43 | #7 (permalink) | |
No Life Poster Join Date: Aug 2002
Member: 14741 Status: Offline Thanks Meter: 119 | Quote:
Why don't you read first.......the only soft that can connect to phone is s2gsm!!!!!! | |
04-12-2005, 17:05 | #8 (permalink) |
Member: 39126 Status: Offline Thanks Meter: 12 | re! You read it !!! Or you have too many other posts to look at this little thing !!! The man tells that 1st - henrich won't connect and 2-nd s2gsm !!! PS - "to clean contacts" ... he sad that already use the cable ... if this is try then the ****ing problem is not from the contacts and the cable !!! - I don't see anywhre in www.service-gsm.net to offer Henrich, but s2gsm YES .... strange isn't it??? And he not demaged the phone with Henrich, but with s2gsm ORIGINAL ... I've s2gsm on 5 different PCs/with equal OS/ and only one connect to phone /from 7 tries/ ... if this is not STUPID ... Henrich 5.23 connect at first time you try !!! Bye !!! |
04-15-2005, 08:06 | #10 (permalink) |
Product Supporter Join Date: May 2002 Age: 54
Member: 12088 Status: Offline Thanks Meter: 4 | Problem is Mainly Caused by Cables Problem is mainly caused by cables or computers serial interfaces. Alcatel phones detect baud rates by exact data timing from program. To solve that kind of problem we made specific USB hardware OTUF USB box. In your case with s2gsm you must try it on several Serial and USB2Serial interfaces and on different computers. As far as I know s2gsm soft works with bh4 v102 well without killing phones. Last edited by gsmmasters; 04-15-2005 at 09:15. |
OT735 BH4 dead after unlock | pepik | Multi-Box | 9 | 04-02-2007 20:27 |
BH4 dead after flash | gattus | BF, BG, TH, BHx Series | 6 | 07-24-2006 18:21 |
bh4 dead after flash | Amir-SkillZ | BF, BG, TH, BHx Series | 4 | 01-30-2006 09:16 |
BH4 dead after bad unlock | Platijet | BF, BG, TH, BHx Series | 5 | 09-13-2005 22:56 |
BH4 dead after unlock lurker 4.0 | destinul | BF, BG, TH, BHx Series | 2 | 12-20-2003 20:13 |
