BF, BG, TH, BHx Series Alcatel BF3/4 and also BG3 series, also THx, BHx are located here. |
09-02-2002, 02:15 | #1 (permalink) |
Freak Poster Join Date: Apr 2001 Location: Belgium
Member: 4378 Status: Offline Thanks Meter: 0 | Hi to All :-) twoo alcatel dead bf3 and bf4 read all phone ok !!!but not written i kan read the partiel flash and the full flash but i kan not write back Any idee plz thanks |
09-02-2002, 09:06 | #2 (permalink) |
No Life Poster Join Date: Aug 2002 Location: Romania, The Bla Bla Country Age: 44
Member: 14279 Status: Offline Thanks Meter: 35 | what do u mean? that u wrote the flashes and the phones are still dead? - use repair flashes or that the writing stops in the middle of process? - if so check battery, it is the common reason for this or u can't connect tham to the computer? - oops, this is verry, verry bad, if your cable works |
09-02-2002, 09:23 | #3 (permalink) |
No Life Poster Join Date: Aug 2001 Location: Roma Age: 49
Member: 5926 Status: Offline Thanks Meter: 275 | I think you use anjel soft Try use Wray's soft Works fine for read write flash and after that repair flash and write back with Wray sw. Anjel soft don't works for all pc Rak|m |
09-02-2002, 13:02 | #5 (permalink) | |
Freak Poster Join Date: Feb 2001 Location: Cj,Ro,Eu
Member: 3262 Status: Offline Thanks Meter: 1 | Re: Hi to All :-) twoo alcatel dead bf3 and bf4 read all phone ok !!!but not written Quote:
Most of free progs, don't erase flash good, I mean static zone in phone,so if u want to writte a flash inside in that zone will be another information,and prog stops in writing. If u want to see what progs erase good, erase flash with everyone and than read back to see where is stored the static information! My best regards to all! cosmo | |
09-02-2002, 15:53 | #6 (permalink) |
Member: 4378 Status: Offline Thanks Meter: 0 | thanks to all helper First thanks to All Yes i use Angel-gsm i read the phone ok i tyry to wrote the flash maybe 1% or maximum 40% the programme stop and i get the message ( wrote error try again )the batrie of the phone is 100% charge + batrie for externe power 75% charge normaly everything is good thanks i try with other software plz sombody have schemes for alcatel Bf 3 and 4 but with Max 3232 i have the schemes with Max232 Thanks |
09-02-2002, 16:03 | #7 (permalink) |
Member: 14279 Status: Offline Thanks Meter: 35 | first: angel is not a very good progy for bf3 (killed 2 phones this way). as for bf4 is best, as long as u have the partial unlock flashes. if u have read flash with angel and u try to upload it with another progy change the extention to ".bin". and do not use battery as external power - flashing alcatel takes a little time and the qualities of the battery will not remain the same |
09-02-2002, 16:35 | #8 (permalink) |
Member: 4378 Status: Offline Thanks Meter: 0 | but my freind if you dind't use xterne power you kan not read the phone maybe you right for flashing phone with out externe batrie i try this methode you kan contact me on this email or this Icq number [email protected] 109156001 thanks ou for your reply |
09-02-2002, 18:49 | #9 (permalink) |
Member: 14279 Status: Offline Thanks Meter: 35 | u did not understand me, i meant that u should try to change the battery with a stable external power - a charger for example (for example i use a home made bf interface - afilip scheme - and as external power i have a charger from a Mitsubishi trium). of course u are right, without external power u can not read or flasg the phone |
09-02-2002, 22:59 | #10 (permalink) |
Freak Poster Join Date: Jun 2002 Location: Romania
Member: 13153 Status: Offline Thanks Meter: 0 | Hi, the external power isn't needed if you use a desktop computer. Only in the case of some laptops is the case. But you have to take into account that the flash read/erase/writes at 1,8V provided by the phones power suply. So if you maintain a decent 3,...V you dont have problems. I succesfully make operations with no external power and with the phone's battery till death . Cosmo means that tehnical zone is erased in smaller chunks because of the nature af data in tehnical zone who can be accesed and be modified by the service software fast. Some software indeed have problems in erasing that area, but as far i know mine and bekos free lite versions do it good . |
help n82 spread all charge sokot and track ok but not charging | m.malik | Chinese Models & Cloned Phones | 3 | 12-17-2009 02:21 |
>>> K1s - Unlocking phone... OK - BUT NOT UNLOCK <<< | RNC_EBM | Smart-Clip | 31 | 06-06-2008 12:03 |
read phone ok but impossible to make log.. | pierrodamore | Nokia Base Band 5 ( BB-5 ) | 9 | 08-29-2007 14:20 |
k300 phone ok but not connevting | Formingus | Sony Ericsson Hardware Repair | 15 | 04-20-2007 12:43 |
where is soft to add tones to bf3 and bf4 ? | makona | BF, BG, TH, BHx Series | 1 | 02-22-2003 08:56 |
