BF, BG, TH, BHx Series Alcatel BF3/4 and also BG3 series, also THx, BHx are located here. |
03-11-2006, 05:45 | #1 (permalink) |
Crazy Poster Join Date: Oct 2003 Age: 45
Member: 41146 Status: Offline Thanks Meter: 1 | *** blinking Micron 8+4MB *** v012 [___012_KW143B02] s2gsm in ver2.60 can repair, but need working full: WHAT'S NEW in version 2.60: ~~~~~~~~~~~~~~~~~~~~~~~~~~~ - now it's possible to repair sw problems with 3 original backup files - .sec1, .sec2 and .eep - these backup files are automatically stored in your eeprom folder each time you connect to phone - here is a little how to fix phone with sw problem (usually only blinks after power up): 1) write fullflash from another phone with exactly same firmware version 2) use restore backup function, switch file type to EEPROM backup files and select valid original backup file 3) use restore backup function, switch file type to SEC1 backup files and select valid original backup file 4) use restore backup function, switch file type to SEC2 backup files and select valid original backup file 5) use unlock function - that's all - if you've used valid original backup files phone will work now - dont ask me for any flashfiles, it's up to you to get it somewhere - it's quite complicated and designed for skilled users only - if you have any problem with anything from above then simple dont use it |
03-14-2006, 05:16 | #4 (permalink) |
Freak Poster Join Date: Sep 2003
Member: 39097 Status: Offline Thanks Meter: 0 | The backups should be taken from a working phone. Otherwise chances are that EEPROM is destroyed and even if you write a working full flash from other phone and then write your damaged EEPROM, you will get the same blinking phone... |
*** blinks red and off? | djyash | VygisToolbox | 3 | 02-13-2007 11:24 |
*** Blinking | snsoftkiller | Multi-Box | 7 | 11-15-2006 20:32 |
Need Full flash to repair Blinking Alcatel *** | nzeiga | BF, BG, TH, BHx Series | 8 | 10-22-2006 21:04 |
*** blink | patric | BF, BG, TH, BHx Series | 26 | 10-10-2006 19:21 |
*** just blink on power on | abdoune | VygisToolbox | 8 | 10-11-2005 23:31 |
