BF, BG, TH, BHx Series Alcatel BF3/4 and also BG3 series, also THx, BHx are located here. |
04-14-2002, 05:04 | #1 (permalink) |
No Life Poster Join Date: Oct 2000 Location: Split / Zagreb, Croatia Age: 53
Member: 2236 Status: Offline Thanks Meter: 58 | Small problem with Zulea's soft... I got it from Zulea yesterday and today I tested it. Works 101% fine but just the problem is that I can't use it on my laptop. It's a Toshiba Satellite PRO 4600, 600 MHz. All, and I mean all, other softwares and cables, interfaces, dongles, registrations etc... etc... , work on it except the cable that was supplied with the soft (not mine, borrowed it from mslion7). The cable is working on my PC for "unlock purposes" without problems and that is a old MMX 266 MHz... So, someone said here that the power supply plug should be plugged in the laptop to make it work fine but that does not help. I have a BEx datacable, a little bit modified, without external power supply, and that data cable works fine on my laptop, even with Koci, IMSI or whatever, although I use Martech box/i-face... If there is someone that can explain me if it is possible to increase the voltage on the serial port, it would be helpfull because low voltage is probably the problem with this "special cable" Regards Spalato |
Small problem with twister | sonkar | Twisterflasher | 3 | 04-28-2005 23:24 |
Small problem with ufs. | sonkar | UFS2 + UFS3-Tornadoflasher | 3 | 10-13-2004 18:03 |
Small problem with the jigs to power up the phone .... | Burnt Cobba | SagMaster Team OLD Products | 3 | 07-16-2004 00:02 |
Small problem with replace eeprom in My3052 | Professor | Infineon C16X M51 & ARM7 M52 BASED | 8 | 06-08-2003 11:57 |
