Welcome to the GSM-Forum forums. You are currently viewing our boards as a guest which gives you limited access to view most discussions and access our other features. By joining our free community you will have access to post topics, communicate privately with other members (PM), respond to polls, upload content and access many other special features. Registration is fast, simple and absolutely free so please, join our community today! If you have any problems with the registration process or your account login, please contact contact us. |
| Register | FAQ | Donate | Forum Rules | ★. iPhone Unlock .★ | -= JTAG BOOM =- | .: Nokia Unlock :. | Search | Today's Posts | Mark Forums Read |
| BF, BG, TH, BHx Series Alcatel BF3/4 and also BG3 series, also THx, BHx are located here. |
| | #1 (permalink) |
| Junior Member Join Date: Sep 2006
Member: 358958 Status: Offline Thanks: 0
| VYGIS "sorry,this flash type is not supported yet" Hello, I has a mobile phone to unlock model alcatel 332 The used cable is the than this in the section download vygis's page for the BG3: ![]() The problem is than to connect the following window of error appears ![]() Somebody that had solved this? Thank you for responding......... |
| | #2 (permalink) |
| No Life Poster ![]() ![]() ![]() ![]() ![]() ![]() ![]() Join Date: May 2001 Location: Bulgaria
Member: 4627 Status: Offline Sonork: 57528:debeliamark Thanks: 51
| You have unsoldered flash IC ( or CPU or both, because it's not detected well ) or just not enough power for MAX IC in cable... so first try to use external powered cable and see what happening... |
| | #4 (permalink) |
| hi I have tried to change the coneccion this way: ![]() Even I have the same problem... You say that max232 has low power Can I attempt a short circuit in some diode of the output 7805? When I press "connect"......... Must the movil phone be off? Thank you for responding......... |
| | #6 (permalink) |
| thanks Ok, with the phone off ...I have the same problem: "sorry,this flash type is not supported yet" There is nothing unsoldered In the appliance's label this written: BG34C 5BTLAR1 Any ideas? |
| | #7 (permalink) |
| Freak Poster ![]() ![]() ![]() ![]() Join Date: Jun 2004 Location: Retired Unlocker in DZ
Member: 69987 Status: Offline Thanks: 19
| I confirm that it must be flash cable if phone hardware is good (assuming battery is full and phone connectors are clean). Good luck. |
| | #9 (permalink) |
| There is no flash IC with ID: DFFF - so try to check all one more time ... try to ask some friend for working ( tested ) cable, try to find one more BG3 phone and test your onw one.... |
| | #10 (permalink) |
| The connections are all right, there are no bad contacts... I'm doubting in the MAX232, my circuit this using the MAX232N And Vygis's circuit is MAX232C My circuit's capacitors are 1 micro farads tantalium And they are 0.22 micro farads in Vygis's circuit Will these be the causes of the problem? |
| | #11 (permalink) |
| Really!!! The problem was the cable... The MAX232 did not have much power supply But, now I have another problem.. Doesn't vygis support subversion KV126300 ? ![]() Am I in the oven? |
| Bookmarks |
| Thread Tools | |
| Display Modes | |
| M65 Flash Type is Not Supported! | kasamiko | Martech CLIP / Box / Key | 1 | 04-08-2009 06:41 |
| c65 c72 Flash Type is not supported! | mobile star | SIEM Service Tools | 2 | 12-22-2006 10:36 |
| I am sorry, but this file type is not allowed unless you are a paid account | robbiesl42 | x1x to x45/x50 | 1 | 01-28-2003 00:46 |
