Welcome to the GSM-Forum forums. You are currently viewing our boards as a guest which gives you limited access to view most discussions and access our other features. By joining our free community you will have access to post topics, communicate privately with other members (PM), respond to polls, upload content and access many other special features. Registration is fast, simple and absolutely free so please, join our community today! If you have any problems with the registration process or your account login, please contact contact us. |
| Register | FAQ | Donate | Forum Rules | ★. iPhone Unlock .★ | -= JTAG BOOM =- | .: Nokia Unlock :. | Search | Today's Posts | Mark Forums Read |
| Alcatel TCL Hardware Repair Section here you can get all the Hardware Repair information for all Alcatel and Alcatel TCL Phones. |
| | #1 (permalink) |
| Junior Member ![]() ![]() Join Date: Nov 2004 Age: 42
Member: 91905 Status: Offline Thanks: 0
| Alcatel Secret Codes ALCATEL: *#06# -> Displays imei & Software Version 000000* -> Entering in engineering Menu1 (with sim) ###847# -> Reset to Factory Defaults (with sim) ###765*02# -> Add Barring Groups ###765*05# -> Locking To Network ###765*07# -> Unlocking From Network ###765*78# -> Deactivate Barring Groups |
| The Following User Says Thank You to nana_rivo For This Useful Post: |
| | #2 (permalink) |
| Insane Poster ![]() ![]() ![]() Join Date: Nov 2004 Age: 37
Member: 94669 Status: Offline Thanks: 33
| Alcatel secret codes Alcatel - Service Codes For E Series: Next codes work on alcatel E Series... *#8273*# - Network Services ###847# - General reset *7528*# - Simlock Flags *#7253*# - Total call duration *#7846*# - Reset to idle disabled... *#7849*# - Reset to idle enabled *#3377*# - Config as clam phone *#2277*# - Config as bar phone *#3646*# - Engineering module *#7378*# - Reset informaions *#6362*# - Free memory *#3862*# - Test mode -- usually keypad.. *#4837*# - Internal vesion *#3837*# - Version revision Older Alcatel Models: Enter Service Menu : *#000000# View Secret Menu : 000000 and press * To remove the security codes : HD1,HE1 : 25228353 BE1,BE3 : 25228352 BE4,BE5 : 83227423 BG3.BH4 : 83227423 ***.TH4 : 83227423 Init codes: ###847# Reset to factory defaults (danger...) ###337*07# Phone restart Language selectors: *#0000# Automatic *#00xx# xx= 07,27,41,44,61,63,64,84,91,92,94 English xx= 43,49 Deutsch xx= 48 Polski *#0420# Czech *#0421# Slovak -Lock/Unlock codes: (ask your Provider for network codes... ) 000000* Entering in Engineering Menu1 (with SIM) ###874# Reset to Factory Defaults (with SIM) ###765*02# Add Barring Groups ###765*05# Locking to Network ###765*07# Unlocking from Network ###765*08# Erase Network ###765*78# Deactivate Barring Groups |
| | #3 (permalink) |
| Secret codes Secret Codes To view IMEI (International Mobile Equipment Identity) number enter *#06# To Enter Service Menu enter: *#000000# To view Secret Menu type 000000 then press * Secret Menu Appears TRACES channel indicator menus ARRETS - ? VIDER ARRETS Press OK and the phone responds: This action is executed! CTRL CHARGE It show the charger voltage and battery voltage. DAMIER display test This is something that I got that I have yet to decipher. IMEI 3300 1453 1139 420 When activated with a Telstra card the Phone boots up with: "PRODUCT CODE" "VAL. => OK" Then we enter 025121992 OK "ENTER SPECIAL CODE" **05* same as Motorola "UNBLOCKING" " PUK ? " 10608CC2*. These two from Vodaphone also work 906081C2* 15900807* "UNBLOCKING" " PIN ? " 0000* "UNBLOCKING" "PIN AGAIN " 0000# Alcatel Software Info UPDATED / NEW Software releases HC400 on the backside near the IMEI number is a sticker with a software release. Alcatel have split the software releases 1.x No Cellbroadcast 5.x Cell broadcast The newest software release of the HC 1000 is AK1 03 Alcatel HC600/800/1000 Pin-Out diagram 1 3 5 7 9 11 13 15 I I I I I I I I O O 17 I I I I I I I I 2 4 6 8 10 12 14 16 1 Vbat_ext 9 SDA_E 2 EMMI_PAE 10 GND 3 Mic 11 GND 4 EMMI_OPE 12 DC_IN (charge) 5 GND 13 Speaker 6 EXT_EMET 14 MARCHE 7 SCL_E 15 DC_IN (charge) 8 EXT_RECDIT 16 GND 17 Antenna+internal switch (int/ext) Software update, how? I have been asked a lot about how to update the software in Cellular phones. The easiest thing to do is to go to the nearest cellular dealer and make him do it for you. Just remember that it is supposed to be free (a receipt is requiet) so don't let him tell you anything else! Removing SP lock on Alcatel Easy This is how to remove the SP lock on Alcatel (one touch) Easy. (You wil need a cable, a eeprom device and some sw) Edit the eeprom: Address Replace with ------------- --------------- 176h FFh 177h FFh Alcatel One Touch Easy To view IMEI (International Mobile Equipment Identity) number enter *#06# To Enter Service Menu enter: *#000000# To view Secret Menu type 000000 then press * Secret Menu Appears TRACES channel indicator menus ARRETS - ? VIDER ARRETS Press OK and the phone responds: This action is executed! CTRL CHARGE It show the charger voltage and battery voltage. DAMIER display test This is something that I got that I have yet to decipher. IMEI 3300 1453 1139 420 When activated with a Telstra card the Phone boots up with: "PRODUCT CODE" "VAL. => OK" Then we enter 025121992 OK "ENTER SPECIAL CODE" **05* same as Motorola "UNBLOCKING" " PUK ? " 10608CC2*. These two from Vodaphone also work 906081C2* 15900807* "UNBLOCKING" " PIN ? " 0000* "UNBLOCKING" "PIN AGAIN " 0000# It seems that I need to find out the PIN because at this point the phone reboots I have got the info from a a guy somewhere on the net but I can't remember who so I can't give him the credit (sorry..) Write me if you are the one.. Removing SP lock on Alcatel Easy This is how to remove the SP lock on Alcatel (one touch) Easy. (You wil need a cable, a eeprom device and some sw) Edit the eeprom: Address Replace with ------------- --------------- 176h FFh 177h FFh Unlock Generator for Alcatel phones Here's a program that generates the lock/unlock codes for the alcatel phones (One Touch Easy ..) NB. The program may not work with 203 & newer versions of the software. Download: unlock.exe [~34 kb] Instructions for unlock.exe Once you enter your IMEI, you got 2 codes, ON, OFF plus phone type. ON is the code for turning on the SIMLOCK. We don't wanna do that, right? :-) So let's go for the OFF code. This is supposed to be the one to remove the SIMLOCK, but it's incomplete, at least for the network providers here in Spain. This number, as you have seen, is in HEX format. I think it's a kind of universal code in which any netword provide add another fixed number (always the same) and the correct UNLOCK CODE is the sum of both of them. Let's see this in an example. IMEI: 330020536226XXX ON: 50453d90 OFF: 10453d90 Phone type: Alcatel HC800 Network provider: E MOVISTAR (214-07) If we introduce the OFF code, the phone won't accept it. We have to add another number to this code. In Spain and for 214-07 (MoviStar) this is 9FDFFA. So we have to sum this numbers. The easier way is by loading the windows's calc, use the Hex mode and realize the sum 10453d90+9FDFFA=10E51D8A 10E51D8A is the right number. So we type this in our phone and ... the SIMLOCK is removed! Alcatel One Touch Easy To view IMEI (International Mobile Equipment Identity) number enter *#06# To Enter Service Menu enter: *#000000# To view Secret Menu type 000000 then press * Secret Menu Appears TRACES channel indicator menus ARRETS - ? VIDER ARRETS Press OK and the phone responds: This action is executed! CTRL CHARGE It show the charger voltage and battery voltage. DAMIER display test This is something that I got that I have yet to decipher. IMEI 3300 1453 1139 420 When activated with a Telstra card the Phone boots up with: "PRODUCT CODE" "VAL. => OK" Then we enter 025121992 OK "ENTER SPECIAL CODE" **05* same as Motorola "UNBLOCKING" " PUK ? " 10608CC2*. These two from Vodaphone also work 906081C2* 15900807* "UNBLOCKING" " PIN ? " 0000* "UNBLOCKING" "PIN AGAIN " 0000# This is how to remove the SP lock on Alcatel (one touch) Easy. (You wil need a cable, a eeprom device and some sw) Edit the eeprom: Address Replace with ------------- --------------- 176h FFh 177h FFh Alcatel OTView Here's the info how to unlock OTView, 100% working. The Phone must be HD series, so the RETOFIT could work. -------------------------------------------------------- 1. Connect the phone to cable (phone must be OFF) 2. Start the RETROFIT software 3. Go to options, change Language to ENGLISH 4. Go to first left MENU, choose SWITCH ON 5. When the phone power up, choose CONNECT 6. You should see some weird lines on phone Display, and that is normal, the phone is in TEST Mode. 7. Go to FLASH ACCESS from pull-down menu 8. Choose WRITING BY KEYBOARD INPUT 9. First adress 7e00, second adress 7eFF (start, end) 10. In Down window enter 16 rows(lines) of FF (FFFFFFFFFFFFFFFF - 16 FF's) and in 17th line enter FFFF (4 ff's) 11. Press CTRL+ENTER 12. Go to first left menu, choose DISCONNECTION 13. Disconect the phone from cable. 14. Insert the SIM card into phone ... 15. The phone is unlocked and ready for ROCKING ))))))16. And the original IMEI is in phone ![]() ------------------------------- Alcatel HE1 V3.0 On adress 00 to 0A change to 0000....that works 70% works too on some v 301 afther that change contrast and backlight. Alcatel DB Solution You must edit Flash content and then: on Adress/Line 122A, change all to 00 |
| Bookmarks |
| Thread Tools | |
| Display Modes | |
| All Alcatels new model secret codes | samirov-gsm | Alcatel TCL Phones and New Models | 12 | 04-12-2013 10:25 |
| Secret codes ### for Alcatel OT311 (BF31W) ? | french_g | BF, BG, TH, BHx Series | 13 | 09-23-2009 07:32 |
| C139 handset codes... Secret Codes | gsm1999 | ODM (Original Design Manufacturing) | 13 | 04-28-2008 12:19 |
| alcatel secret codes for traduction | anis76 | BF, BG, TH, BHx Series | 12 | 07-16-2004 23:12 |
| phone code for motorola by entering some secret code!!! | mikSer | Old Legacy Motorola (EMMI) | 0 | 09-12-2002 01:47 |
