Welcome to the GSM-Forum forums. You are currently viewing our boards as a guest which gives you limited access to view most discussions and access our other features. By joining our free community you will have access to post topics, communicate privately with other members (PM), respond to polls, upload content and access many other special features. Registration is fast, simple and absolutely free so please, join our community today! If you have any problems with the registration process or your account login, please contact contact us. |
| Register | FAQ | Donate | Forum Rules | ★. iPhone Unlock .★ | -= JTAG BOOM =- | Search | Today's Posts | Mark Forums Read |
| Alcatel TCL Hardware Repair Section here you can get all the Hardware Repair information for all Alcatel and Alcatel TCL Phones. |
| | #1 (permalink) |
| Freak Poster ![]() ![]() ![]() ![]() Join Date: Mar 2006 Location: Portugal Age: 30
Member: 241933 Status: Offline Thanks: 13
| BE4 network problem..... hi all i have a BE4 with network problem... he have a good signal of network , but i canīt do call or recive them, this is hardware problem or software problem ??? |
| | #2 (permalink) |
| i have try this all until now: -flashing using SW Henrich_523v3 (in clone mode and full flash mode)with all version , 134,135,136,137,138,139. not solved -format the phone with robson and with codes(###847#) not solved -using be4 repair by LOTO , i have try using all 52 eeprom fix files. not solved ...i searching all old theard, and it seems this problem is very common on BE4 and others alcatel models. i'm sure my problem is hardware.... In old theard many guys describe to try rehot or change PA or cpu or duplex!!.... but i look everywhere and i can't find any pictures where is the points for rehot. If any one post me some pictures where is the rehot points...i will give him a candy (looooool)Thanks 2all |
| | #4 (permalink) |
| i will put soon all BE4 versions here....... For now i have put only Henrich_v5.23_with_BE4&BE5_TEH_Zones , (52 zones eeprom for repair) here http:///vbb/showthread.php?t=351969 How use: 1- write a full flash in clone mode, and check if the phone turns ON 2- Start write TEH zone_1.bin ....and so on up to 52...until ur phone works fine. To check if ur phone works fine .....he must not restart by self or "check sim card", and good network without loss. If ur phone works fine , but u canīt do calls or recive them.....than u have my problem to ..... and itīs hardware problem.... and i havenīt resolve t .......... anyway a will wait for more help |
| | #5 (permalink) |
| Here are some BE4 full flash hi again.... Ok here is 5 full flash... , all diferent BE4 versions : http://www.geocities.com/badwily_wv/...sh/135_amd.zip http://www.geocities.com/badwily_wv/Alcatel_BE4_Flash/136_amd.zip http://www.geocities.com/badwily_wv/Alcatel_BE4_Flash/137_amd.zip http://www.geocities.com/badwily_wv/Alcatel_BE4_Flash/138_KG176_amd.zip http://www.geocities.com/badwily_wv/Alcatel_BE4_Flash/139_KG179_amd.zip Note: this all flash are AMD loaders..... If ur phone are INTEL or MICRON, than use this software to convert to ur phone type. That's allhttp://www.geocities.com/badwily_wv/Alcatel_BE4_Flash/be4flashcor.zip Good luck |
| | #6 (permalink) |
| http://www.geocities.com/badwily_wv/...es/135_amd.zip http://www.geocities.com/badwily_wv/...es/136_amd.zip http://www.geocities.com/badwily_wv/...es/137_amd.zip http://www.geocities.com/badwily_wv/..._KG176_amd.zip http://www.geocities.com/badwily_wv/..._KG179_amd.zip Note: this all flash are AMD loaders..... If ur phone are INTEL or MICRON, than use this software to convert to ur phone type. That's all http://www.geocities.com/badwily_wv/...e4flashcor.zip Link repaired |
| | #9 (permalink) |
| Freak Poster ![]() ![]() ![]() ![]() Join Date: Apr 2002
Member: 10679 Status: Offline Thanks: 9
| Type 000000* and you'll get in monitor mode. But what's the problem you are experiencing EXACTLY? Is it on GSM900, GSM1800, does it beep or show any message? Are you located in Germany? |
| | #10 (permalink) |
| hi again =) when i got more time i will put here the information from "monitor mode". about the calls , when i do a call, phone beep's 3-4 times (without any normal sound of call) and turn off the call, and he can't recive any calls. about gsm network i couldn't found any menu to change 900 or 1800 or automatic!!!!! Thanks |
| | #11 (permalink) | |
| Quote:
Monitor mode: Traces: Network- 0014 28 57 2 0 18 002B1BFB RXLEV- 0014 27 0034 26 ???? ??( some times appears 0773 06) 0014 27 ???? ??( some times appears 0032 06) ???? ??( some times appears 0770 03) 0014 29 ???? ??( some times appears 0021 11) ???? ?? BSIC- 0034 63 ???? ?? (some times appears 0770 63) 0032 63 ???? ?? ???? ?? ???? ?? C1/C2- 0014 56 056 0034 54 054 ???? ?? ??? (some times appears 0770 09 ???) 0032 10 010( 032 ?? ???) 0773 12 ??? ???? ?? ??? ???? ?? ??? | |
| | #12 (permalink) |
| Crazy Poster ![]() ![]() ![]() Join Date: Sep 2006 Location: India(Assam) Age: 50
Member: 359015 Status: Offline Sonork: tarunshan Thanks: 0
| dear Brother. I ve got the same prob. one set became dead for applying heat in the network section. network showing full but no out going and no incoming prob Remady: only to change the handsfree conector. |
| Bookmarks |
| Thread Tools | |
| Display Modes | |
| Nokia 3120 Network Problem | ramdev_mobbile | Nokia Hardware & Hardware-Repair Area | 3 | 07-13-2010 08:46 |
| Alcatel BE4 Network Problem | sagir | Alcatel & TCL Old Models | 0 | 01-04-2005 21:46 |
| be4 network problem | misel | Alcatel & TCL Old Models | 0 | 10-06-2003 18:41 |
| be1 network problem=be4 net probem? | szakiz | Hardware Repair by brands | 0 | 07-01-2002 03:16 |
| BE4 138 - problem with network | dusan.g | Alcatel & TCL Old Models | 3 | 11-02-2001 13:08 |
