Alcatel TCL Phones and New Models OT, OH & E series, and all new TCL and Alcatel Models which are not listed in upper sections. |
04-21-2015, 14:36 | #1 (permalink) |
No Life Poster Join Date: Sep 2006 Location: Allah is Greatest
Member: 358694 Status: Offline Sonork: 100.1597323 Thanks Meter: 994 | on the back written same thing... 4007x-2AVDZA1 I try to flash that phone from download other files but it same... now how can i read back up from working fone ad write here... after writing readed file with volcano now phone is dead... i flash it with sptool but flashing complet and phone still dead.... Last edited by Brka; 04-27-2015 at 18:04. Reason: consolidate forum space |
04-21-2015, 23:33 | #2 (permalink) |
Member: 163 Status: Offline Thanks Meter: 7,778 | Read THIS and THIS thread carefully. You have all needed files in there. Basically, what you need to do is : - Fully format phone from SPFT - Use testpoint, and write preloader and DSP_BL from flash that you will use - After that, normally flash the phone with SPFT, it should be alive - It will have bad imei, write provided NVRAM file, it will get back. Procedure is same for 4007x and 4007d, just different flash files used. b.r. Alex
__________________ Always press THANKS button if my post was helpful! Please DO NOT send me PM's for help, You can ask for help on forum Do not post THANKS posts - use thanks button ! ALWAYS use SEARCH button before posting! |
04-27-2015, 05:52 | #3 (permalink) |
Junior Member Join Date: Jan 2015 Location: Pakistan ajk bhimber
Member: 2334192 Status: Offline Thanks Meter: 3 | l[H/W] Data of the block is unstable after erasing NAND Flash! [Reason] lIt maybe a SMT issue solution for this error and tell what does it mean bootloader does not exist so download bootloader first how i download |
04-27-2015, 12:30 | #4 (permalink) |
Member: 163 Status: Offline Thanks Meter: 7,778 | What the heck is problem with you??? I wrote like 15 times, fully format phone, use tp and write preloader and dsp_bl, After, normally flash the phone. I described whole process in details.
