Alcatel TCL Phones and New Models OT, OH & E series, and all new TCL and Alcatel Models which are not listed in upper sections. |
12-18-2017, 22:13 | #33 (permalink) |
Junior Member Join Date: Dec 2004 Age: 58
Member: 97797 Status: Offline Thanks Meter: 0 | Hmm ok so I flashed a UK O2 model 4034X-2AOBGB2 with the 4034X-2XALGB1 rom in this thread (including preloader). Now the phone doesn't boot and I can't flash anything else to it. always the same DRAM error 4032. Format, update etc all don't work. Same SP flash tools version as the other poster. The repair flash has a bad scatter but even with a fixed one it won't start to flash anything. **** merged post I flashed the wrong preloader to my 4034X (O2 GB2) and now it won't flash anything. I got hold of a new one and can use 'read back' in sp tool to read the preloader out of it. But droid tools doesn't work to create the scatter file, and neither does it convert the read back bin file (because it doesn't know the scatter). How can I copy the preloader from the working phone to the dead one? (Using another rom from the internet doesn't work and gives me DRAM error). Last edited by Brka; 12-19-2017 at 21:27. Reason: merged |
12-19-2017, 18:47 | #34 (permalink) |
No Life Poster Join Date: Mar 2005 Location: wales uk
Member: 125632 Status: Offline Thanks Meter: 233 | try using this scatter,.its the 1 i used.. with this firmware ot-4034X-2XALGB1_Original_SPFT_ROM_by_bRkA.7z i can givve u link if u waant tothhe firmware,but scatter is attahed |
12-20-2017, 09:20 | #35 (permalink) |
Member: 97797 Status: Offline Thanks Meter: 0 | I tried that scatter file and flash but that’s what killed the first phone. On the second phone I flashed it without preloader and it works fine. Now I need to fix the first phone. I read the Preloader from the working phone using sp flash tool and looked at the file produced, the preloader is longer than the length in all these scatter files. The new file has a different format (a file header) too. I tried to manually remove it but sp flash tool still won’t accept the file. I either need a full backup from a GB2 phone or a way to read it back from my working phone. I managed to strip out the container from the preloader i read from the working phone and flash it back to the dead one, and everything works now I was initially getting a DRAM error because the preloader in the flash files on the net are different from the one required for this phone. Hmm now a different issue. I got 3 new phones, and when i flash the same recovery to them it fails to boot. I think the oem lock is still set and won't unlock. so i urgently need to find 4034X-2AOBGB2 firmware, or any way to back it up from a working phone. It seems no custom recovery will boot on this phone, so I wonder if the oem lock is still on. I tried to unlock it again and again but I think this new rom is not doing it properly. 1) I flashed Twrp recovery, it fails to boot into it (it tries then restarts the phone into normal mode) 2) I ran the alcatel upgrade tool to upgrade it. It restore the recovery although it says 4034D instead of 4034X now. 3) I tried to unlock the bootloader - it succeeds, returns to fastboot and is stuck there (as the first phone). I reboot and it boot loops showing android green robot then reboot. 4a) I tried to flash twrp, still same issue won't boot. 4b) I repeated 1 to 3 but this time I tried to fastboot boot the recovery - same issue 4c) I repeated 1, 2, and tried to flash and boot the recovery - same issue. Any idea what's going on here? I just picked up 2 more phones, and they both do the same thing :/ Last edited by Brka; 12-21-2017 at 22:27. Reason: merged multiple posts |
12-21-2017, 22:55 | #36 (permalink) |
Member: 163 Status: Offline Thanks Meter: 7,785 | Looks like bootchain cheks are now implemented into new software / android version. However, since you now have working rom, you can try some of custom recoveries (ctr v6.6, twrp 3.0.2, 3.1.0). Download full pack - HERE Flash it normally with SPFT. Reboot immediately into recovery, after flashing. b.r. ALex
__________________ Always press THANKS button if my post was helpful! Please DO NOT send me PM's for help, You can ask for help on forum Do not post THANKS posts - use thanks button ! ALWAYS use SEARCH button before posting! |
12-23-2017, 00:31 | #37 (permalink) |
Member: 163 Status: Offline Thanks Meter: 7,785 | ... and in case you need repair files (boot, preloader, recovery, etc.), to fix bricked phone(s), here are original stock files : Download - OBGB2_4034X_DL5 b.r. Alex
04-02-2018, 11:33 | #39 (permalink) | |
Freak Poster Join Date: Nov 2014 Location: ISLAMABAD,PAKISTAN
Member: 2290305 Status: Offline Sonork: 1672955 Thanks Meter: 33 | Quote:
Alcatel 4034x ROM ROM PID: 4034X-2AWNIT1 (Wind Italy branded) Last edited by Brka; 04-02-2018 at 21:00. Reason: fixed link, added info | |
05-15-2018, 02:57 | #41 (permalink) | |
Member: 163 Status: Offline Thanks Meter: 7,785 | Quote:
OBGB2 preloader is missing from OTA server. However, you can try preloader from 4034X-2xALGB1 attached to this post ... b.r. ALex
__________________ Always press THANKS button if my post was helpful! Please DO NOT send me PM's for help, You can ask for help on forum Do not post THANKS posts - use thanks button ! ALWAYS use SEARCH button before posting! | |
The Following 2 Users Say Thank You to Brka For This Useful Post: |
06-17-2018, 10:37 | #44 (permalink) |
No Life Poster Join Date: Jul 2016 Location: Africa
Member: 2601900 Status: Offline Thanks Meter: 519 | Please which ot4034 version can be flashed into VFD 300? I have tried all files that work with vfd300 but it wont boot up, only on round ball, so i want to convert it to retail version, please help |
