Go Back   GSM-Forum > GSM & CDMA Phones / Tablets Software & Hardware Area > Alcatel > Alcatel TCL Phones and New Models
Alcatel TCL Phones and New Models OT, OH & E series, and all new TCL and Alcatel Models which are not listed in upper sections.
Old 03-30-2019, 23:52   #76 (permalink)
Moderator
Brka's Avatar
Member: 163
Thanks Meter: 6,150
Originally Posted by hallo View Post
@Brka maybe You have 4034G-2AB7AUA? Phone flashed before me with some flash and become "dead". I see that xxxxx box have that fw (Telstra Australia) but I don't have xxxx box beside all boxes at me..
Thank's in advance.
4034G phone is same hardware as 4034D, 4034X.
(G model have just different GSM/3G/LTE bands/frequencies, software-controlled).
Mark "A" at the end of PID says that it's "Cost Down" version,
which only differs in Display. Everything else in it is the same as normal 4034x/d.
So, to make it alive again (and change region etc.), here is simple procedure :
- flash attached preloader (scatter included)
- Flash already posted 4034D-2xALRUA firmware WITHOUT preloader
- device should be alive and working, but dual-sim, and with Russian
- then simply flash SYSTEM only from ANY desired rom (Serbian?)
or ... reverse ... flash 4034D-2xALRUA , flash system from any rom,
and at the end flash attached preloader.
test and post results.
p.s. I got that Telstra rom, will take two hours to upload,
and will send you links later, in case that this doesn't work.
b.r.
Alex
File Type: rar 4034G-2xB7AUA_Preloader+scatter_by_bRkA.rar (74.0 KB, 97 views)
__________________
Always press THANKS button if my post was helpful!
Please DO NOT send me PM's for help, You can ask for help on forum
Do not post THANKS posts - use thanks button !
ALWAYS use SEARCH button before posting!
The Following 2 Users Say Thank You to Brka For This Useful Post:
Old 04-01-2019, 09:11   #77 (permalink)
hallo's Avatar
Member: 21365
Thanks Meter: 86
Thank's @Brka, preloader makes phone "alive" again, and that 4034d rom bring again working phone.
The Following User Says Thank You to hallo For This Useful Post:
Old 04-03-2019, 07:56   #78 (permalink)
Member: 2277735
Thanks Meter: 157
Originally Posted by Brka View Post
Actually, this just proves known differences
between old and new revisions.
Hardware is the same, only display is difderent.
So, what you did is used just system+cache+userdata
from older (4034x) and rest of files from 4034D new revision
and all went good?
B.r
Alex
Yes correct as all UK did not work so mixed the UK with ru!
The Following User Says Thank You to P3T3 For This Useful Post:
Old 04-25-2019, 15:10   #79 (permalink)
bright hlatini's Avatar
Member: 1614640
Thanks Meter: 460
alcatel 4034x 2KVDZAA hang on logo flashing with above firmware 4034D-2xALRUA_Original_Stock_ROM_by_bRkA,l get error 4008]Error: S_FT_DOWNLOAD_FAIL
Old 04-25-2019, 21:43   #80 (permalink)
Moderator
Brka's Avatar
Member: 163
Thanks Meter: 6,150
Try another version of SPFlashTool (v5.16xxx or v5.17xxx),
check / reinstall drivers - use Mobile Upgrade installer,
it have correct drivers - or try on another PC.
If you manage to flash device, and it doesn't power on,
just use attached preloader, flash it together with desired rom,
or just flash preloader after flashing any other rom.
p.s. If you still cant boot/flash that device - it may be hardware issue.
b.r.
Alex
File Type: rar 4034X-2KVDZAA_Preloader+Scatter_by_bRkA.rar (74.4 KB, 50 views)
__________________
Old 05-17-2019, 17:49   #81 (permalink)
Member: 2899660
I have Alcatel 4034x-2AE8GBA
Sent from my Infinity 7 Pro using Tapatalk
Old 05-17-2019, 22:05   #82 (permalink)
Moderator
Brka's Avatar
Member: 163
Thanks Meter: 6,150
Very good. If you need to repair software errors, or unbrick the device,
please read whole thread from beginning.
b.r.
Alex
__________________
Old 06-29-2019, 16:42   #83 (permalink)
Member: 2915880
Hi I am also having touble finding rom for 4034x 2ae8gb1. Non of the suggested roms work
with my UK phone
I flashed with supplied SP Thanks . but phone still has no life after incorrect rom flash. re my 4034x-2ae8gb1
can anyone help
Old 07-01-2019, 00:39   #84 (permalink)
Moderator
Brka's Avatar
Member: 163
Thanks Meter: 6,150
@bwizz
Your phone is old (normal) revision. Rom from post #4 should be okay.
Only one thing may not be the same, and that is PRELOADER.
So, to make it work, use attached preloader and scatter,
replace preloader and scatter in unpacked rom from post #4
and reflash the phone.
If after that, phone still doesn't power on, check battery.
If battery is okay and well charged, phone may have other (hardware) problems,
and any try to repair it with software is useless.
b.r.
Alex
File Type: rar 4034X-2AE8GB1_Preloader+Scatter_by_bRkA.rar (74.1 KB, 12 views)
__________________
Old 07-01-2019, 19:22   #85 (permalink)
Member: 2915880
Pixi 4 Rom needed
I have followed all the info on Pixi 4 pages 1 to 6 with no joy !
I screwed my partners phone trying to resolve a" loss on data connection " with a rom flash! I bricked it with a rom fom the site. !
now after trying the standard rom on page 5 ,My phone charge light comes on and the phone sounds to boot but nothing on screen!
can anyone help UK Phone 4034 x 2ae8gb1
Old 07-01-2019, 21:11   #86 (permalink)
Moderator
Brka's Avatar
Member: 163
Thanks Meter: 6,150
@bwizz
few more advices for you:
1. try previously attached preloader with different roms on this forum (section)
2. leave battery to charge at least half an hour or more
3. if nothing of that helps ... well, time to visit authorized Alcatel service center.
b.r.
Alex
__________________
The Following User Says Thank You to Brka For This Useful Post:
Old 07-06-2019, 18:32   #87 (permalink)
Member: 2915880
Re Pixi 4 GB issue
I can't do a quick reply. I tried suggested pre loader with various roms that will flash " No go" ! When I try to flash the Brka7z rom . I get sp message " error 4032 dram failed "check load matches target
Tried two flash tools same result?
Old 07-07-2019, 22:03   #88 (permalink)
Moderator
Brka's Avatar
Member: 163
Thanks Meter: 6,150
okay, can you take a picture of phone sticker (you can blur imei), and post here ?
b.r.
Alex
__________________
Old 07-09-2019, 11:41   #89 (permalink)
Member: 2915880
I can't place links as Idon't have enough posts! Can't drop picture in box ,Only URL
I tried Alcatel again. They offer no usefull assistance or software download options
I tried a barcode product scan of label, but nothing found in search!
numbers on label read "v4034x-2ae8gb1" 354288079988375
Thanks for interest and help
Old 07-09-2019, 20:56   #90 (permalink)
Moderator
Brka's Avatar
Member: 163
Thanks Meter: 6,150
@bwizz
Okay, managed to get original factory firmware with exact pid.
Upload in progress, check private messages for link and further instructions.
btw. strange thing is, that on imei check, that device is shown
as totally different PID - 4034X-2ARGMC3 (Orange Monaco ???)
From which network is your device (or to which network is locked) ?
p.s. ROM I have is for pid from the sticker - 4034x-2ae8gb1
b.r.
Alex
__________________
Page generated in 0.57925 seconds with 8 queries
