Alcatel TCL Phones and New Models OT, OH & E series, and all new TCL and Alcatel Models which are not listed in upper sections. |
01-13-2017, 04:39 | #1 (permalink) |
No Life Poster Join Date: Dec 2015 Location: Somewhere on the Internet
Member: 2500215 Status: Offline Thanks Meter: 417 | Alcatel Pop 4 Plus 5056E , 5056X , 5056O Firmware |
01-15-2017, 21:37 | #2 (permalink) |
Member: 163 Status: Offline Thanks Meter: 7,778 | Hi, You can try with factory OTU Updater, latest version, 5.1.7, Download - HERE Your model is listed as "One Touch 5056", Select it, and follow the instructions in software. **** EDIT: Mobile Upgrade Q 5.0.2 - HERE (If newer version don't work) b.r. Alex
__________________ Always press THANKS button if my post was helpful! Please DO NOT send me PM's for help, You can ask for help on forum Do not post THANKS posts - use thanks button ! ALWAYS use SEARCH button before posting! Last edited by Brka; 06-20-2017 at 21:49. Reason: added links |
The Following 3 Users Say Thank You to Brka For This Useful Post: |
05-11-2017, 20:05 | #4 (permalink) | |
Member: 163 Status: Offline Thanks Meter: 7,778 | Quote:
let's see what will happen. Install it and follow instructions ... b.r. Alex
__________________ Always press THANKS button if my post was helpful! Please DO NOT send me PM's for help, You can ask for help on forum Do not post THANKS posts - use thanks button ! ALWAYS use SEARCH button before posting! | |
05-11-2017, 21:22 | #6 (permalink) |
Member: 163 Status: Offline Thanks Meter: 7,778 | As I said earlier - Download OTU updater, it will do whole magic, from installing drivers, to upgrading/reviving your device. b.r. Alex
06-20-2017, 21:03 | #7 (permalink) |
No Life Poster Join Date: Feb 2003 Location: africa Age: 54
Member: 22284 Status: Offline Thanks Meter: 81 | Help alcatel pop4 5056x flash file May someone help with a link where I may download Alcatel pop4 5056x flash file (TCL_TCL_ANDR_v6.0.1_5056D_POP455C_5056X/D). |
06-20-2017, 21:48 | #8 (permalink) | |
Read thread from beginning. b.r. Alex
07-17-2017, 20:45 | #10 (permalink) |
Junior Member Join Date: Jul 2017
Member: 2737356 Status: Offline Thanks Meter: 1 | While I have a long sad tale and explanation about the new phone being generally locked right after the AT&T Worldglobe startup animation but occasionally an available root shell, I'll skip it unless there's any interest. I have searched for either a ROM or an OTU for this model in the usual places I can't mention, and the unusual ones across the Net, but I've had no joy. If anyone more knowledgeable can point me in the direction of something (ROM, OTU, magic spell) to reset an Alcatel Onetouch Allura 5056O back to factory, I would appreciate it. While I download both versions with my rather slow aDSL, can I assume this will load a non-AT&T-branded, Alcatel-generic version of the operating system? This would NOT be a bad thing, BTW, since there is so much cruft added to the AT&T OS. Last edited by Brka; 07-18-2017 at 01:50. Reason: merged posts |
07-18-2017, 05:45 | #11 (permalink) |
Member: 2737356 Status: Offline Thanks Meter: 1 | Epic fail thus far. Have tried both versions multiple times, both get stuck at 5%, "Scanning your mobile phone..." I've tried plugging the phone in before launching the app, after launching the app but before hitting "Upgrade Phone," after launching and pressing "Upgrade Phone." The two versions do seem to work differently; the older version does not seem to charge the phone while connected, where the later version does seem to continue charging the phone (charging LED remains on). I have left it sit for times between ten minutes and three hours. Plan to leave it connected overnight this evening as an experiment. Each time I selected ONE TOUCH 5056 before continuing, although the picture of the phone is slightly different than the 5056O. It did install diagnostic, QDLoader, and COM drivers (Android HS-USB). I've been working with computers since the early 1980's, but if I've learned anything it's to assume I'm doing something wrong. I've read through the stickies here, but there's no real "what to do when the unexpected happens," so I'm not sure what to try next. Would apprecaite guidence. Anyway, after leaving it sit for ~11-hours, still at 5%. Unless I have done something wrong, it appears the OTU for the 5056 doesn't work for the 5056O Allura. Anyone have any other ideas for recovering a soft-bricked 5056O? I am currently in communication with Alcatel's U.S. support (which may be outsourced, who knows?), and they have made it clear there is no OTU available for the AT&T Alcatel Allura 5056O device. Their current advice is limited to performing a factory reset via the GUI, which of course isn't possible for a softbricked phone. I am explaining carefully the issue I and others here have experienced with this phone, specifically asking for some method to reload the stock ROM, and will report any constructive suggestions they may have. But the OTU that lists the 5056 simply will not work on the 5056O. Last edited by Brka; 07-27-2017 at 20:42. Reason: merged posts |
The Following User Says Thank You to CharlieSummers For This Useful Post: |
01-20-2020, 20:29 | #13 (permalink) |
Member: 163 Status: Offline Thanks Meter: 7,778 | For those US versions, no. b.r. Alex
The Following User Says Thank You to Brka For This Useful Post: |
