Alcatel TCL Phones and New Models OT, OH & E series, and all new TCL and Alcatel Models which are not listed in upper sections. |
11-21-2016, 20:19 | #1 (permalink) |
Banned Join Date: Jul 2006 Location: dword ptr [ebp-1C], edx
Member: 322417 Status: Offline Thanks Meter: 940 | Alcatel 5036X OTA Problem pro_info.bin via hexeditor is totally 0 How to repair IMEI ? Regards |
The Following User Says Thank You to Formingus For This Useful Post: |
11-23-2016, 20:38 | #2 (permalink) | |
Member: 163 Status: Offline Thanks Meter: 7,777 | Quote:
it will make default NVRAM area. After that you can use several ways to repair imei : - MTK Droid Tools 2.5.3, and root to repair imei or - MauiMeta / SNWriter MTK Tools or - Via some commercial box. p.s. Phone must show correct baseband info under settings/about phone menu, without correct baseband, you wont be able to repair it. b.r. Alex
__________________ Always press THANKS button if my post was helpful! Please DO NOT send me PM's for help, You can ask for help on forum Do not post THANKS posts - use thanks button ! ALWAYS use SEARCH button before posting! | |
The Following 3 Users Say Thank You to Brka For This Useful Post: |
11-24-2016, 04:14 | #3 (permalink) | |
Member: 322417 Status: Offline Thanks Meter: 940 | Quote:
Well give a try with root and mtkd. Thanks for replay friend.. Sent from my D6503 using Tapatalk | |
The Following 2 Users Say Thank You to Formingus For This Useful Post: |
11-24-2016, 22:45 | #4 (permalink) | |
TBH i got always from you correct instruction , using this opportunity to say thanks In this case i try almost everything , mtk droid, commercial , mui meta, sn writer and so on. Commercial tools report as burned OTP. Flashed via OT_5036X_2AVVBG1_ORIGINAL_SPFT_ROM_BY_BRKA, everythig is ok except IMEI. As i say before i try to flash via OTU 4.0.4 Says And 4.5.4 as i say , pro info in hex editor was completely 000000, so there was no provider, model and so oin hex editor. the only think i didnt try is nvram write or genuine flesh, but Flash for this 5036x-2ctbal1 does not exist on forums or hard to find. mtk droid Any Chance after all those information ? Thanks in Advance | |
11-24-2016, 23:09 | #5 (permalink) |
Member: 163 Status: Offline Thanks Meter: 7,777 | Try with pro info from THIS post, or pro_info from 7041x/d, edit by your needs, and see what will happen. (edit model name and pid, of course - use some retail PID ie: 5036X-2AALFR1 or 2AALEU1 / 2AALEU0) If dont succeed, contact me via PM. b.r. Alex
__________________ Always press THANKS button if my post was helpful! Please DO NOT send me PM's for help, You can ask for help on forum Do not post THANKS posts - use thanks button ! ALWAYS use SEARCH button before posting! Last edited by Brka; 11-24-2016 at 23:15. |
The Following User Says Thank You to Brka For This Useful Post: |
11-25-2016, 01:08 | #6 (permalink) |
Member: 322417 Status: Offline Thanks Meter: 940 | HI, Is there a way to avoid flashing all parts ? I want to flash only pro_info but getting PMT Changed for ROM Error It will reduce mine time while playing with PID. Thanks |
11-25-2016, 01:27 | #7 (permalink) | |
or window->memory write in older SPFT (New tab appears). start address : linear_start_addr: 0x700000 , length : 0x300000 p.s. check pm. b.r. Alex
11-25-2016, 01:55 | #8 (permalink) | |
Some delays may occur while doing thinks that you suggest. Working and will keep you updated , Thanks for being gr8 supporter | |
11-22-2017, 13:50 | #9 (permalink) | |
Insane Poster Join Date: Apr 2014
Member: 2162128 Status: Offline Thanks Meter: 6 | Quote:
What shell I do Brka send instroctions if you can? Thanks | |
