Alcatel TCL Phones and New Models OT, OH & E series, and all new TCL and Alcatel Models which are not listed in upper sections. |
04-07-2014, 18:56 | #1 (permalink) |
Freak Poster Join Date: Feb 2013 Location: Timisoara, Romania
Member: 1879471 Status: Offline Thanks Meter: 6 | Alcatel 6012x Unbrick / Language Change [EU-CH-Spain, Bulgaria, Arabic, etc.] Now I have this error : BROM ERROR: S_DL_GET_DRAM_SETTING_FAIL ( 5054 ). Or if you have this phone can you upload somewhere a full backup with all partitions for a flash with sp flash tool ? Last edited by Brka; 10-23-2015 at 01:31. Reason: changed title to reflect thread content |
08-25-2014, 16:38 | #3 (permalink) |
Member: 163 Status: Offline Thanks Meter: 7,785 | There you go .... debranded rom, for SPFlashTool. Flash it with "Write Memory" option. if after flashing, doesn't boot to system, or have bootloop, do format/wipe data/cache. 7zip to unpack .... ROM_0.7z ROM_0.7z ROM_0.7z ROM_0.7z ROM_0.7z ROM_0.7z ****** EDIT: ROM is from Switzerland region, Languages - EU - CH - Spain p.s. it also solves all imei/nvram related problems, returns original imei back, which stays after reset. thanx to Russian forums for initial solution. press thanx if it was usefull for you. b.r. Alex Last edited by Brka; 10-23-2015 at 01:34. Reason: added list of languages in rom |
08-25-2014, 22:12 | #4 (permalink) |
Member: 163 Status: Offline Thanks Meter: 7,785 | interesting post regarding procedures with Alcatel's and other MTK phones : http://forum.gsmhosting.com/vbb/f317.../#post10517293 have a nice day. b.r. Alex |
09-25-2014, 15:40 | #6 (permalink) | |
Member: 163 Status: Offline Thanks Meter: 7,785 | Quote:
- download sp_flash_tool_v3.1344.0.212 - SPFlashTools start, load scatter file (from attachment) - upper menu - Window - Write memory - tab Write memory appears, - select EMMC, Open Raw Data - select ROM_0 file - press Write memory - connect phone to cable - wait untill finished. - you have working phone. the end. (otherwise, do format data/cache fro mrecovery) - PRESS THANKS, of course. b.r. Alex | |
The Following 4 Users Say Thank You to Brka For This Useful Post: |
12-29-2014, 19:04 | #7 (permalink) |
Junior Member Join Date: Dec 2014
Member: 2319257 Status: Offline Thanks Meter: 3 | Many thanks Brka, your post helped me to unbrick my Hiro after hundreds of ROM's. Cheers and Happy New Year! |
The Following 2 Users Say Thank You to manone666 For This Useful Post: |
12-31-2014, 07:26 | #9 (permalink) |
Member: 2319257 Status: Offline Thanks Meter: 3 | Yes, the procedure it's very simple to follow, just be patient with the first start of the phone, it's takes longer than usual. I tried many ROM's with TWRP recovery, changing the files in the BACKUPS folder but every time the phone remains stuck at boot logo. For me this ROM written with SP Flash was the salvation. Thank you again, Alex. |
The Following User Says Thank You to manone666 For This Useful Post: |
04-15-2015, 08:16 | #10 (permalink) |
No Life Poster Join Date: Nov 2004
Member: 91799 Status: Offline Thanks Meter: 3 | Thanks for the ROM, Brka. Managed to repair and unlock an Orange Hiro, with that and Alcatel online upgrade tool. |
The Following User Says Thank You to e-person For This Useful Post: |
06-29-2015, 23:48 | #11 (permalink) |
Junior Member Join Date: Jul 2014
Member: 2218478 Status: Offline Thanks Meter: 0 | hi i have a bricked alcatel hiro mtk 6572 says stuck on boot logo when i am tryng to use this method the flash tool is stuck on searching nothin happen, what can i do ? phoneis off and shows me the charging screen. solved problem after installing mediatek orange hiro drivers ty for the room you are a life saver briked after trying to install that room on alcatel 6012 X orange hiro can you please upload the preloader and dsp_bl for this phone Last edited by Brka; 06-30-2015 at 13:51. Reason: consolidating forum space |
07-01-2015, 04:45 | #12 (permalink) | |
Use scatter file from post #6, there is detailed instruction in that post too. before write memory (flashing), do format whole flash. b.r. Alex
__________________ Always press THANKS button if my post was helpful! Please DO NOT send me PM's for help, You can ask for help on forum Do not post THANKS posts - use thanks button ! ALWAYS use SEARCH button before posting! | |
The Following 2 Users Say Thank You to Brka For This Useful Post: |
07-06-2015, 20:20 | #14 (permalink) |
Member: 2218478 Status: Offline Thanks Meter: 0 | while attempting to flash the room from post 3# the Sp flash tool gives error 4032 enable dram fail the rom has the preloader inside ? can u get it out the necesary files to install preloader first maybe will make it to get back to life is completly dead and get detected by pc as MTK usb port and if i hold volume button get detected as unknown usb device descriptor request failed what Sp flash tool should i use and how to solve this pleas help and now i get enable dram setting failed 5054 error i uninstalled all drivers and installed just the correct one the sp flash tool comunicates with device but gives this error seems is something about the wrong preloader, i searched on net to see, can you help me by uploading the revire files for this phone please like u did with 6030X in a post best regards Allex. Last edited by Brka; 07-07-2015 at 20:14. Reason: merged for better readability |
07-07-2015, 20:15 | #15 (permalink) |
Member: 163 Status: Offline Thanks Meter: 7,785 | Download Telenor Bulgaria ROM - HERE You have inside all files, including preloader. Make format whole flash, write preloader in forced flash mode, after flash normally full flash. b.r. Alex
