Alcatel TCL Phones and New Models OT, OH & E series, and all new TCL and Alcatel Models which are not listed in upper sections. |
07-07-2015, 21:09 | #16 (permalink) |
Junior Member Join Date: Jul 2014
Member: 2218478 Status: Offline Thanks Meter: 0 | by flashing this rom again i get error 4032 enable dram failed but when tryed to flash that ROM_0 i get error 5054 enable dram setting fail, what could be the problem ? Last edited by Brka; 07-07-2015 at 22:10. Reason: merged, double posting |
07-07-2015, 22:11 | #17 (permalink) | |
Member: 163 Status: Offline Thanks Meter: 7,785 | Quote:
Forced flash mode = Volume up + power on + insert usb cable. b.r. Alex
__________________ Always press THANKS button if my post was helpful! Please DO NOT send me PM's for help, You can ask for help on forum Do not post THANKS posts - use thanks button ! ALWAYS use SEARCH button before posting! | |
The Following User Says Thank You to Brka For This Useful Post: |
07-07-2015, 22:19 | #18 (permalink) |
Member: 2218478 Status: Offline Thanks Meter: 0 | i select autoformat whole flash and click start then keep pressing vol up + power? then connect to pc? did i not mentioned that the phone is dead no chage icon no prealoder vcom in device manager?, the only thing that works on it its a blue led and its detected as mtk usb port(COM) in pc i think its meta mode, i don't have any backup, when i try to format whole flash using that scatter file still get the error 4032 enable Dram failed how to know if the phone supports format ? Last edited by Brka; 07-07-2015 at 23:55. Reason: merged |
07-07-2015, 23:56 | #19 (permalink) |
Member: 163 Status: Offline Thanks Meter: 7,785 | two things : 1st - You have bricked (Hard bricked) phone, probably no solution. 2nd - STOP spamming the board, and writing message by message. b.r. Alex
08-25-2015, 21:59 | #22 (permalink) |
Junior Member Join Date: Jul 2011
Member: 1610961 Status: Offline Thanks Meter: 0 | Hello I have the same problem. I bricked my Alcatel 6012X while flashing it via SP flashtool. Flashing went well, but phone didn't turn on. Now it recognizes as MTK device, but when I try to flash I get errors (or 4032 , eiter 5054) I tried to flash it's 6012X's original firmware and the debranded rom I found above. In box is written 6012X-2BTWIE1 I couldn't find this firmare to try. Please if you can help me with this problem. |
08-27-2015, 20:27 | #24 (permalink) | |
then it's bricked. correct procedure is : - FULL Format, with bootloader - holding volume down or up, or both + power on and insert USB cable - Flash preloader only from spft, - After that phone accepts normal flash - Fully flash phone, or flash TWRP and restore backup from sdcard I have attached boot recovery pack - download HERE Also, attached different scatter file, which can be problem also. b.r. Alex
The Following 2 Users Say Thank You to Brka For This Useful Post: |
08-27-2015, 20:59 | #25 (permalink) | |
Insane Poster Join Date: Oct 2008
Member: 886703 Status: Offline Thanks Meter: 20 | Quote:
1: to flash preloader from sptf shall I use the one that is on your boot recovery pack? 2: the full flash should contain cache and user data? | |
08-27-2015, 21:29 | #26 (permalink) | |
1: I did used the preloader from your pack 2: I used the full flash you uploaded on post #23 for now phone is on, but got imei invalid, now I'm flashing Rom_0 from post #3 and write results! | |
08-27-2015, 22:36 | #27 (permalink) |
Member: 886703 Status: Offline Thanks Meter: 20 | another one alive!!! As bRkA said, imei invalid can be solved, just read carefully his instructions and the phone will be working again, I flashed phone with rom from post #3 and got original imei back, and even spanish language. |
The Following User Says Thank You to young_floyd For This Useful Post: |
09-18-2015, 10:06 | #28 (permalink) | |
Junior Member Join Date: Sep 2015
Member: 2457341 Status: Offline Thanks Meter: 0 | Hi, Will it work for an OT-6012A ? Quote:
09-18-2015, 13:06 | #29 (permalink) |
Member: 2457341 Status: Offline Thanks Meter: 0 | I tried and it works now! My phone was "locked" with the message "The slot has been permanently locked" (due to too many attemps for simunlock it). Last edited by Brka; 09-18-2015 at 13:13. Reason: no thanks in posting, use thanks button ! |
