Alcatel TCL Phones and New Models OT, OH & E series, and all new TCL and Alcatel Models which are not listed in upper sections. |
01-16-2015, 18:36 | #1 (permalink) |
Junior Member Join Date: Jan 2015
Member: 2329511 Status: Offline Thanks Meter: 0 | Alcatel 6034R reflash |
01-16-2015, 20:40 | #2 (permalink) | |
Member: 163 Status: Offline Thanks Meter: 7,772 | Quote:
And ... Phone you have is Qualcomm phone, totally different than MTK models, which are easy to solve, Qualcomm - not so easy. btw. did you try official OTU updater ? if yes - does it work ? no ? there is one, unofficial way to fix ... but for it, you will need one working phone. b.r. Alex | |
01-17-2015, 10:48 | #3 (permalink) |
Member: 2329511 Status: Offline Thanks Meter: 0 | Hi again, I used an application called 3C toolbox which provides some optimization features like zipalign. After that "optimization" at first reboot the phone ended in boot loop. The official OTU tool says "there is no newer version" and refuses to flash the phone. I found in some french forum some images - there was a partial success with one them - the phone booted but ... GSM and wireless don't work - i think something is wrong with baseband as in about menu there is a line "BASEBAND unknown". So currently the phone is not completely bricked - i succeeded to boot but without radio services. |
01-17-2015, 17:54 | #4 (permalink) | |
Those are probably raw images for phone in EMMC mode, in which you can write them directly as raw partition(s) ? if so, those flashes you used can probably be edited, to trick OTU updater, to allow update / restore and fix phone. b.r. Alex | |
The Following User Says Thank You to Brka For This Useful Post: |
01-17-2015, 23:11 | #5 (permalink) |
Member: 2329511 Status: Offline Thanks Meter: 0 | images location Hi, the files are available on goo*gl/IuUX8j - sorry for this but I am not allowed to post links so i put * instead of DOT I have rebooted the phone in recovery mode and using adb pushed following commands: fastboot -i 0x1bbb erase boot fastboot -i 0x1bbb erase recovery fastboot -i 0x1bbb erase system fastboot -i 0x1bbb erase custpack After that I loaded the downloaded files: fastboot -i 0x1bbb flash boot boot*img fastboot -i 0x1bbb flash recovery idolscwm6.0.3.7*img fastboot -i 0x1bbb flash system system1*img fastboot -i 0x1bbb flash custpack custpack*img fastboot -i 0x1bbb reboot The system image file is located at: mega*co*nz/#!HBIF3KzY!R6roKuvEeVYCcPFphY0fPi7FoMll0WqRaCZQLor oP_w (sorry again for the mess with the * but the DOT symbol is recognized as link) There are two files in subfolder ROM on the link above which seem to contain some zip rom images but I don't know how to flash them. BR Pavel Last edited by pmarkov; 01-17-2015 at 23:19. |
01-19-2015, 20:23 | #6 (permalink) |
Member: 163 Status: Offline Thanks Meter: 7,772 | Hi, The problem here is not the android system or custpack, neither is boot and recovery. Some of those mentioned images are intended for CWM/TWRP recovery. regarding no wifi, etc, it refers to either no modem partition in phone, or screwed up NVM area. Can you somewhere find exactly the same working phone ? Maybe there is a chance of repairing, but you'll need one working phone to try it. b.r. Alex |
07-20-2016, 11:39 | #7 (permalink) | |
Junior Member Join Date: Jul 2016
Member: 2600762 Status: Offline Thanks Meter: 0 | Quote:
Is there a way I can use the working phone to reflash or restore the non working one. The non working is stuck in a loop where it says unfortunately xxx has stopped working , which I clear and then says again. | |
07-20-2016, 21:19 | #8 (permalink) | |
b.r. Alex
__________________ Always press THANKS button if my post was helpful! Please DO NOT send me PM's for help, You can ask for help on forum Do not post THANKS posts - use thanks button ! ALWAYS use SEARCH button before posting! | |
07-21-2016, 06:29 | #9 (permalink) |
Member: 2600762 Status: Offline Thanks Meter: 0 | Hi, I downloaded OTU Updater for Idol s and I cannot connect it to both the bricked and working phones. I selected Idols on the LAcatel site and then downloaded Mobile Upgrade Q 4.1.0. I then selected One Touch 6034R from the dropdown menu, and it stops there. Can't do any further. I can read from the good phone in Explorer so I know it is connecting to USB. Any ideas what I am doing wrong ? |
07-21-2016, 16:09 | #10 (permalink) |
Member: 163 Status: Offline Thanks Meter: 7,772 | Revert to some normal windows, win7 or winXP, Everything will start working like magic, And no more bricked phones. P.s. 32bit win B.r alex
07-21-2016, 23:49 | #11 (permalink) |
Member: 2600762 Status: Offline Thanks Meter: 0 | Ok, Put the software on my Windows 7 Laptop and OTU Updater all runs well. Used version 5 which is for Idol4, but it has 6034 as a phone option so worked on my Idol S. Updated new 6034R and it went well, took 30 minutes and was done. Unfortunately the non-working phone only got about 1/4 of the way through the update with it crashing out and giving the message to remove battery and retry. Could not get past this error message. Am I out of options to repair faulty phone ? cheers Digger |
07-22-2016, 00:23 | #12 (permalink) | |
If still the same, try contacting me in private, we'll try something else, prepare teamviewer and skype. b.r. Alex
