Alcatel TCL Phones and New Models OT, OH & E series, and all new TCL and Alcatel Models which are not listed in upper sections. |
07-15-2015, 20:56 | #2 (permalink) |
Member: 163 Status: Offline Thanks Meter: 7,778 |
__________________ Always press THANKS button if my post was helpful! Please DO NOT send me PM's for help, You can ask for help on forum Do not post THANKS posts - use thanks button ! ALWAYS use SEARCH button before posting! |
The Following 3 Users Say Thank You to Brka For This Useful Post: |
08-01-2015, 23:50 | #4 (permalink) | |
Member: 163 Status: Offline Thanks Meter: 7,778 | Quote:
Write here original PID from back sticker (903D-2XXXXXX). b.r. Alex
__________________ Always press THANKS button if my post was helpful! Please DO NOT send me PM's for help, You can ask for help on forum Do not post THANKS posts - use thanks button ! ALWAYS use SEARCH button before posting! | |
08-03-2015, 00:21 | #6 (permalink) | |
Of course it will be dead after format. And, your impatience can only make things worse, if you continue playing with phone, without any idea what are you doing. now, to make phone alive again, and re-make it into single sim version, download THIS ROM file with flasher, and flash the phone. if it doesn't power on, use OTU updater, it will bring it back to life. (after flashing whole pack). Of course, if you are patient enough, I will upload original flash next days. b.r. Alex
The Following User Says Thank You to Brka For This Useful Post: |
08-04-2015, 22:09 | #8 (permalink) |
Member: 163 Status: Offline Thanks Meter: 7,778 | - unpack files - make new folder on c: (c:\mts960) - select all files from unpacked folder and move to new made folder on c:\1 - do not move sub-folders but all files directly - rename scatter file into MT6573_Android_scatter.txt - use older SPFlashTools - download HERE - load scatter, and manually select/load all non-ticked files (nvram, pro_info, etc.). flash the phone. b.r. Alex
05-25-2016, 14:26 | #9 (permalink) |
No Life Poster Join Date: Jan 2012 Location: Morocco
Member: 1712203 Status: Offline Thanks Meter: 354 | hi all anyone have any working rom of this model 903D-2AALAT1-S40 trying OTU but no luck i got error of firewall but i'm not using it also disabled A/V same result after wipe data / cache Last edited by Brka; 05-25-2016 at 19:50. Reason: thread reorganizing |
05-25-2016, 20:04 | #11 (permalink) |
Member: 1712203 Status: Offline Thanks Meter: 354 | same story but i find something about that otus_log : Code: The phone's cu is ÿÿÿÿÿÿÿÿÿÿÿÿ The phone's IMEI is 8653330120XXXXX The phone's version is ÿÿÿÿÿÿÿ The version in the server is NULL anyone got that to edit with my own info ? Code: The phone's cu is M903D-2AALAT The phone's IMEI is 8653330120xxxxx The phone's version is 9FAMTA1 The version in the server is NULL mmmmmm thanks brka for the file but i failed with your attached file that's why i look for something else i find another post for you here i use the same PRO_INFO with own information save it flash it with write memory option after that succeeded with OTU i'm downloading now Code: The phone's cu is 903D-2AALAT1 The phone's IMEI is 8653330120xxxxx The phone's version is 9FAMTA1 The version in the server is AFJGYJ0 Last edited by Brka; 05-26-2016 at 21:23. Reason: merged posts |
05-26-2016, 21:22 | #13 (permalink) | |
b.r. Alex
05-27-2016, 11:35 | #14 (permalink) | |
Junior Member Join Date: Aug 2012
Member: 1793793 Status: Offline Thanks Meter: 0 | Quote:
i dont know how to fix this problem with otu how make it work the otu my friend? i have a bricked 903d Last edited by Brka; 05-30-2016 at 00:53. Reason: double posting | |
06-10-2016, 12:26 | #15 (permalink) |
Member: 1793793 Status: Offline Thanks Meter: 0 | i finaly change pid and otu make the upgrade.. but phone still not open@ what is wrong? The phone's cu is 903D-2AALAT1 The phone's IMEI is 8653330118xxxx The phone's version is 9FAMTA1 The version in the server is AFJGYJ0 different pid? or rom scatter file for my model? |
