Alcatel TCL Phones and New Models OT, OH & E series, and all new TCL and Alcatel Models which are not listed in upper sections. |
04-20-2017, 17:11 | #1 (permalink) |
Freak Poster Join Date: Apr 2006 Location: Beach
Member: 257734 Status: Offline Thanks Meter: 10 | alcatel idol 3 6045k dead any solution? |
04-20-2017, 19:19 | #2 (permalink) | |
Member: 163 Status: Offline Thanks Meter: 7,785 | Quote:
Without battery, and both volume keys + insert usb cable - port 9008 must appear in device manager ... b.r. Alex
__________________ Always press THANKS button if my post was helpful! Please DO NOT send me PM's for help, You can ask for help on forum Do not post THANKS posts - use thanks button ! ALWAYS use SEARCH button before posting! | |
The Following 2 Users Say Thank You to Brka For This Useful Post: |
04-23-2017, 20:43 | #4 (permalink) | |
b.r. Alex
The Following User Says Thank You to Brka For This Useful Post: |
04-23-2017, 20:55 | #5 (permalink) |
Member: 257734 Status: Offline Thanks Meter: 10 | I changed lcd+touch+frame more then 1 month ago and phone worked great but now is totally dead... I don't know exactly what happened before phone died... however I already tried to disconnect almost everything from board but still nothing... I connected phone to 10000mah power bank (capable to charge iPhone 7 3 times) fully charged and 6-7 hours later power bank were almost discharged and battery shows 4.2V... no sign of water damage... |
04-23-2017, 22:07 | #6 (permalink) | |
starting from PA (Power Amplifier), bluetooth/wifi module, etc. b.r. Alex
09-11-2017, 21:51 | #9 (permalink) | |
You need USB-OTG cable, and a USB type A on both sides, when plugged in - phone should go to HS-USB Qdownloader 9008 mode. After that - Mobile Upgrade or flash via QFIL, or flash via BOX. b.r. Alex
09-23-2017, 13:56 | #11 (permalink) |
Member: 163 Status: Offline Thanks Meter: 7,785 | Please, read my previous post. You will need OTG-usb cable, double A-type usb cable, And maybe will need to disassemble phone. All explained in link from previous post. B.r. Alex.
09-23-2017, 23:14 | #12 (permalink) | |
Junior Member Join Date: Sep 2017
Member: 2760532 Status: Offline Thanks Meter: 0 | Quote:
Ahm, hello. Do i still need to buy a otg cable and usb type a though my pc detected my phone qdloader 9008? It's just when I use qfil i do not have the compatible program firehose file and the xml files for alcatel idol 3. And when I tried other mbn and xml files, it says switch to edl mode fail. How to resolve this? | |
09-24-2017, 20:43 | #13 (permalink) | |
Download, unpack, run, wait to start, start download in software, then connect phone. If it displays error on 45 or more % , don't worry, disconnect it, reboot, make factory reset from recovery and run phone normally. post results. b.r. Alex
09-25-2017, 22:10 | #14 (permalink) |
Member: 2760532 Status: Offline Thanks Meter: 0 | it says load nprg error as early as 2% what to do? Huhu Still not good. Why can't the tool detect the IMEI, CU Ref, Hardware, and others of the phone? And it stops and says NPRG Error. What to do? Last edited by Brka; 09-26-2017 at 12:26. Reason: Merged |
09-26-2017, 12:27 | #15 (permalink) |
Member: 163 Status: Offline Thanks Meter: 7,785 | Probably hardware malfunction (flash memory died). B.r. Alex
