Go Back   GSM-Forum > GSM & CDMA Phones / Tablets Software & Hardware Area > Alcatel > Alcatel TCL Phones and New Models
Alcatel TCL Phones and New Models OT, OH & E series, and all new TCL and Alcatel Models which are not listed in upper sections.
Old 04-20-2017, 17:11   #1 (permalink)
Member: 257734
Thanks Meter: 10
alcatel idol 3 6045k dead
phone not responding (no power, black lcd...) only led flash when connected to pc or charger... when connected to pc nothing happen mobile upgrade q tool cannot detect phone... download mode (volume up + volume down + usb cable) not working too... changed usb cable and pc but no luck... battery show 4.2V
any solution?
Old 04-20-2017, 19:19   #2 (permalink)
Moderator
Brka's Avatar
Member: 163
Thanks Meter: 7,785
any solution?
Time to check usb connector (charging port) on phone ...
Without battery, and both volume keys + insert usb cable - port 9008 must appear in device manager ...
b.r.
Alex
__________________
Always press THANKS button if my post was helpful!
Please DO NOT send me PM's for help, You can ask for help on forum
Do not post THANKS posts - use thanks button !
ALWAYS use SEARCH button before posting!
The Following 2 Users Say Thank You to Brka For This Useful Post:
Old 04-21-2017, 16:45   #3 (permalink)
Member: 257734
Thanks Meter: 10
i did what you said but nothing happen... charging works fine and usb port looks good (nothing broken etc..)
Old 04-23-2017, 20:43   #4 (permalink)
Moderator
Brka's Avatar
Member: 163
Thanks Meter: 7,785
What was initial problem with phone, how it become "Dead Meat" ?
b.r.
Alex
__________________
The Following User Says Thank You to Brka For This Useful Post:
Old 04-23-2017, 20:55   #5 (permalink)
Member: 257734
Thanks Meter: 10
I changed lcd+touch+frame more then 1 month ago and phone worked great but now is totally dead... I don't know exactly what happened before phone died... however I already tried to disconnect almost everything from board but still nothing... I connected phone to 10000mah power bank (capable to charge iPhone 7 3 times) fully charged and 6-7 hours later power bank were almost discharged and battery shows 4.2V... no sign of water damage...
Old 04-23-2017, 22:07   #6 (permalink)
Moderator
Brka's Avatar
Member: 163
Thanks Meter: 7,785
Something is draining power ... if too high resistance on battery positive and negative pins, time to start digging on board,
starting from PA (Power Amplifier), bluetooth/wifi module, etc.
b.r.
Alex
__________________
Old 04-24-2017, 22:14   #7 (permalink)
Member: 257734
Thanks Meter: 10
resistance is 11.15k... strange but no battery drain i think... from 3.8V to 3.4V 24h passed
Old 09-11-2017, 19:46   #8 (permalink)
Crazy Poster
Member: 1136261
Thanks Meter: 7
hello
i have a same problem just vibration and nothing more,no power no connection with pc
Old 09-11-2017, 21:51   #9 (permalink)
Moderator
Brka's Avatar
Member: 163
Thanks Meter: 7,785
Originally Posted by ababahk View Post
hello
As expleained HERE (use google transleate),
You need USB-OTG cable, and a USB type A on both sides,
when plugged in - phone should go to HS-USB Qdownloader 9008 mode.
After that - Mobile Upgrade or flash via QFIL, or flash via BOX.
b.r.
Alex
__________________
Old 09-23-2017, 00:24   #10 (permalink)
Member: 2760532
Hello can you help me too? I cannot use mobile upgrade or qfil cause it needs to enter to download mode then I cannot cause my idol 3 is dead already.
Old 09-23-2017, 13:56   #11 (permalink)
Moderator
Brka's Avatar
Member: 163
Thanks Meter: 7,785
Please, read my previous post.
You will need OTG-usb cable, double A-type usb cable,
And maybe will need to disassemble phone.
All explained in link from previous post.
B.r.
Alex.
__________________
Old 09-23-2017, 23:14   #12 (permalink)
Member: 2760532
Unhappy
B.r.
Alex.
Ahm, hello. Do i still need to buy a otg cable and usb type a though my pc detected my phone qdloader 9008? It's just when I use qfil i do not have the compatible program firehose file and the xml files for alcatel idol 3. And when I tried other mbn and xml files, it says switch to edl mode fail. How to resolve this?
Old 09-24-2017, 20:43   #13 (permalink)
Moderator
Brka's Avatar
Member: 163
Thanks Meter: 7,785
Reflash it with THIS
Download, unpack, run, wait to start, start download in software,
then connect phone.
If it displays error on 45 or more % , don't worry,
disconnect it, reboot, make factory reset from recovery
and run phone normally.
post results.
b.r.
Alex
__________________
Old 09-25-2017, 22:10   #14 (permalink)
Member: 2760532
it says load nprg error as early as 2% what to do? Huhu
Still not good. Why can't the tool detect the IMEI, CU Ref, Hardware, and others of the phone? And it stops and says NPRG Error. What to do?
Old 09-26-2017, 12:27   #15 (permalink)
Moderator
Brka's Avatar
Member: 163
Thanks Meter: 7,785
Probably hardware malfunction (flash memory died).
B.r.
Alex
__________________
Page generated in 0.23392 seconds with 9 queries
