Alcatel TCL Phones and New Models OT, OH & E series, and all new TCL and Alcatel Models which are not listed in upper sections. |
12-05-2014, 17:53 | #1 (permalink) |
No Life Poster Join Date: Sep 2013 Location: The Hell Age: 31
Member: 2033150 Status: Offline Thanks Meter: 624 | Alcatel Idol X 6040D , 6040A , 6040X ROM, Flashing, Unbrick, Arabic rom etc. plz any one help thanks a lot Last edited by Brka; 05-18-2015 at 18:30. Reason: added title with more sense, according to models ... |
12-05-2014, 23:58 | #6 (permalink) |
Member: 163 Status: Offline Thanks Meter: 7,784 | not bad, there is a hope .... okay, download this stuff : - SPFlashTools MOD + usb drivers - Flash File, Russian, ot-6040D v4.2.x - Flash File 6040D, Russian, 6040D V4.2.x - PID Changer for 6040x Yandex Disk have some file downloading limit, you can download 2 files as I remember, so don't stop downloads, or you will need to restart your router to get new ip address. now, after you unpacked files ... - start SPFlashTools - go to folder where you unpacked flash file ALCATEL-ONE-TOUCH-6040D_13.10.12 - select MT6589_Android_scatter_emmc.txt - in middle window, click on custpack - and select manually custpack.img - finally press DOWNLOAD button - connect phone to cable - if you have issues connecting, press volume UP, and connect cable while holding it SPFlashTool will start download, and hopefully, when finished, you will have phone, that power on ... if it doesnt power on, hold power on button longer if it power on but have boot-loop (stays on logo or not finishes booting), go to recovery menu (vol UP + power on, release power on after 3-4 secs.), and do reset/wipe user data / cache partition. now ... in case you have phone that is working, and you need to restore it back to stock (the same operator it was before, same languages etc.), you will need to use last file - 6040D_Change_Pro_info short how-to : - get some hex-editor (or you can try with notepad++, should work), - open with it file named "pro_info" - find this : 6040D-2EMSRU1 - change it to your original PID (ie: 6040D-2AS7RS1 = Serbia MTS, 6040D-2EALHR1 = Croatia etc.) - open up SPFlashTool MOD, scatter-loading, - go to folder where you unpacked "6040D_Change_Pro_info", - load "MT6589_Android_scatter_emmc.txt", - in middle window, click on PRO_INFO, and select file from folder - "pro_info" - press DOWNLOAD, connect cable to powered off phone, ignore warning messages some PID's : Code: 2AALAZ1,2AALBD1,2AALCH1,2AALCZ1,2AALDE1,2AALEU0,2A ALFR1,2AALHK1,2AALHR1,2AALIN2 2AALIR1,2AALIR1,2AALIT1,2AALME1,2AALNL1,2AALUA1,2A ALVN2,2AGWIN1,2AHHTW1,2AMSRU1 2AN3MY1,2AN3MY1,2ARGAM1,2AS7RS1,2ASJIN1,2BALHK1,2B S7RS1,2CALAZ1,2CALBD1,2CALCH1 2CALCZ1,2CALCZ1,2CALDE1,2CALEU0,2CALFR1,2CALHK1,2C ALHR1,2CALIN2,2CALIR1,2CALIT1 2CALME1,2CALME1,2CALNL1,2CALUA1,2CALVN2,2CGWIN1,2C HHTW1,2CMSRU1,2CN3MY1,2CRGAM1 2CS7RS1,2CS7RS1,2CSJIN1,2DALAZ1,2DALBD1,2DALCH1,2D ALCZ1,2DALDE1,2DALEU0,2DALFR1 2DALHK1,2DALHK1,2DALHR1,2DALIN2,2DALIR1,2DALIT1,2D ALME1,2DALNL1,2DALUA1,2DALVN2 2DGWIN1,2DGWIN1,2DHHTW1,2DMSRU1,2DN3MY1,2DRGAM1,2D S7RS1,2DSJIN1,2EALAZ1,2EALBD1 2EALCH1,2EALCH1,2EALCZ1,2EALDE1,2EALEU0,2EALFR1,2E ALHK1,2EALHR1,2EALIN2,2EALIR1 2EALIT1,2EALIT1,2EALME1,2EALNL1,2EALUA1,2EALVN2,2E GWIN1,2EHHTW1,2EMSRU1,2EN3MY1 2ERGAM1,2ERGAM1,2ES7RS1,2ESJIN1,2FALEU0 after finished, phone will work same as before, BUT - official upgrade tool, will see it as original one, as it was before, and will load up original flash file. if it says that there is no higher version and don't want to upgrade, only thing to do is flash another/edited pro_info and try OTU updater. that's it. write how it went ... b.r. Alex Last edited by Brka; 05-18-2015 at 18:25. Reason: removed some obsolete info |
12-06-2014, 08:38 | #7 (permalink) |
Member: 2033150 Status: Offline Thanks Meter: 624 | I have this file and i tried it before same issue 3144.. I will try it again with ur instructions then post result... Thanks dear Last edited by Brka; 05-18-2015 at 18:25. Reason: no thanks in posting |
12-07-2014, 20:28 | #10 (permalink) |
Member: 2033150 Status: Offline Thanks Meter: 624 | ok sp flash tool always get error 3144 i will upload pic with latest ver of sp flashtool " error 8406 " I think emmc nand dead Last edited by Brka; 05-18-2015 at 18:25. Reason: space consolidation |
12-08-2014, 18:47 | #11 (permalink) |
Member: 163 Status: Offline Thanks Meter: 7,784 | if you are getting BROM ERROR: S_DA_EMMC_FLASH_NOT_FOUND (3144), there are few possibilities : - Try with some latest version of spflashtools, or THIS one - check if download agent is correctly selected (MTK_AllInOne_DA.bin) - check if USB Download mode is selected - try downloading WITHOUT preloader file - finally, try other modes on phone (power+ volume down) etc. if all above gives same error ... I'm sorry, but EMMC (NAND) is probably dead b.r. Alex |
05-15-2015, 19:07 | #14 (permalink) | |
Member: 163 Status: Offline Thanks Meter: 7,784 | Quote:
You can try with TCT S950 rom, and later, if needed change operator frequency (band) from engineering menu. Rom #1 - Download HERE (Full Backup) Rom #2 - Download HERE Rom #3 - Download HERE (stock 01006) But ... first you should try with custom roms : * custom roms (to be installed from CWM or other recovery) : Custom based, S950 - Download HERE (For CWM Recovery) S950 S4 UI - Download HERE AOSP_4.4MODv1.3.10 - Download HERE CWM Recovery - download HERE ClockworkMod recovery (CWM) 6.0.1.2 (Custpack backup) Carliv Touch Recovery 6.0.4.4 + AROMA Filemanager - HERE If after custom / stock phone locked - use THIS (for cwm/twrp) Custom recovery should be flashed with SPFT. SPFT - many versions HERE Engineering menu : *#*#3646633#*#* b.r. Alex
__________________ Always press THANKS button if my post was helpful! Please DO NOT send me PM's for help, You can ask for help on forum Do not post THANKS posts - use thanks button ! ALWAYS use SEARCH button before posting! | |
The Following User Says Thank You to Brka For This Useful Post: |
