Alcatel TCL Phones and New Models OT, OH & E series, and all new TCL and Alcatel Models which are not listed in upper sections. |
05-15-2015, 19:50 | #16 (permalink) | |
Member: 163 Status: Offline Thanks Meter: 7,784 | Quote:
Here are ALL factory PID's : Code: 6040A-2[X=A,C,D,E]ALMX1 6040A-2[X=A,B,D,E]LDUS11 6040A-2[X=A,B,D,E]NNEC1 6040A-2[X=A,B,D,E]C9JM1 6040A-2[X=A,C,D,E]B6CA1 6040A-2[X=A,C,D,E]B6CA7 6040A-2[X=A,C,D,E]EECL1 6040A-2[X=A,C,D,E]C3IL1 6040A-2[X=A,C,D,E]PVIL1 6040A-2[X=A,C,D,E]AVCO1 6040A-2[X=A,C,D,E]AVDO1 6040A-2[X=A,C,D,E]AVSV1 6040A-2[X=A,C,D,E]AVGT1 6040A-2[X=A,C,D,E]AVCR1 6040A-2[X=A,C,D,E]AVHN1 6040A-2[X=A,C,D,E]NSAR1 6040A-A[X=A,C,D,E]NSAR2 6040A-2[X=A,C,D,E]TGMX1 6040A-2[X=A,C,D,E]TLCL1 6040A-2[X=A,C,D,E]ALMX0 b.r. Alex
__________________ Always press THANKS button if my post was helpful! Please DO NOT send me PM's for help, You can ask for help on forum Do not post THANKS posts - use thanks button ! ALWAYS use SEARCH button before posting! | |
The Following User Says Thank You to Brka For This Useful Post: |
05-16-2015, 14:27 | #18 (permalink) | |
Use search, dont be lazy, i posted several times how-to. You must use addresses for your phone. B.r Alex
05-16-2015, 18:43 | #20 (permalink) |
Freak Poster Join Date: May 2007
Member: 515830 Status: Offline Thanks Meter: 80 | i have an original backup from movistar arentina dumped with sp tool and transformed with mtk droid. if you want i can upload it but its not tested. |
The Following User Says Thank You to evasoft For This Useful Post: |
05-16-2015, 19:24 | #21 (permalink) | |
1. Via SPFT, use attached scatter, window "read memory", eMMC, start address : 0x1500000 ; length : 0x300000 2. Via MTK Droid tools - BACKUP, root phone first. you can post links to readed pro_info, upload it somewhere. b.r. Alex
05-16-2015, 19:28 | #22 (permalink) | |
for different models. p.s. I hope you have some uploading site like medifire, with account, on which links can last. b.r. Alex
05-16-2015, 21:35 | #23 (permalink) |
Junior Member Join Date: May 2015
Member: 2392667 Status: Offline Thanks Meter: 0 | This is what I get when I try to load the file you gave me. When I use SP Flash Tool v5.1252.xxx it does not give that error, but it just sits there for ever and does nothing after I click read |
05-17-2015, 03:24 | #25 (permalink) |
Member: 163 Status: Offline Thanks Meter: 7,784 | Go to engineering menu, *#*#3646633#*#* and check network bands, set those used by your operator B.r. Alex
05-18-2015, 13:04 | #26 (permalink) |
Member: 163 Status: Offline Thanks Meter: 7,784 | okay, will prepare original Canada rom later, be patient. b.r. alex
05-18-2015, 14:56 | #27 (permalink) |
Member: 2392667 Status: Offline Thanks Meter: 0 | I spent all night messing around and I finally got TCL s950 4.4.2 working with network. However I can't get the AOSP one working for the life of me. Instead of preparing original Canada ROM could you work with me on getting the AOSP ROM to work? The only thing that needs fixing is the Mobile network. EDIT1: I fixed the S950 ROM by copying original stock modem.img file and placing it in system/etc/firmware/ and changing the name to modem_1_3g_n.img (while the other modem.ig file was in there as well) and then changing permissions for modem_1_3g_n.img to 644 with a reboot. Unfortunately it's not working for the AOSP, but maybe it will give you an idea on how to fix. I should also add that the AOSP ROM you gave previously also only detects one storage location at a time. Either internal or SD but never both. EDIT2: Hey bro if you're still going to do this would you be able to make the AOSP ROM dual SD Card compatible? When I installed it it would only ever detect one of my two storage spaces. Last edited by Brka; 05-22-2015 at 22:25. Reason: merged for better visibility |
05-22-2015, 23:18 | #28 (permalink) |
Member: 163 Status: Offline Thanks Meter: 7,784 | 6040A Original Canada ROM - HERE SPFlashTools - HERE unpack, start spft, load-scatter, from rom folder, manually load custpack and mobile_info files, press download and connect phone to cable. b.r. Alex
The Following 3 Users Say Thank You to Brka For This Useful Post: |
05-26-2015, 15:57 | #29 (permalink) |
Junior Member Join Date: Apr 2014 Location: Tirana, Albania Age: 37
Member: 2163928 Status: Offline Thanks Meter: 4 | Thank you Brka for your precious support. I tried a month ago flashing some 6030s but unfortunately they had hardware issues so my efforts were useless. now i revived a 6040X it is fully functional. the rom i used was Android Srbija - Vesti, Zanimljivosti, Recenzije, Mali oglasi, Forum ... |
06-04-2015, 05:00 | #30 (permalink) |
Member: 2392667 Status: Offline Thanks Meter: 0 | Hey Brka. I was wondering if you could recommend the best custom ROM for the 6050a. I'm looking to be able to install themes using theme chooser and the slim cat ROM I have doesn't seem to support it. |
