Alcatel TCL Phones and New Models OT, OH & E series, and all new TCL and Alcatel Models which are not listed in upper sections. |
10-16-2014, 13:56 | #1 (permalink) |
Freak Poster Join Date: Feb 2005 Location: World Wide Age: 54
Member: 120932 Status: Offline Thanks Meter: 58 | Alcatel 5036A / 5036X / 5036D ROM Last edited by Brka; 02-10-2016 at 21:07. Reason: added working link. |
The Following 2 Users Say Thank You to Cell-Manager For This Useful Post: |
04-17-2015, 22:32 | #2 (permalink) |
No Life Poster Join Date: Jun 2007 Location: Mexico
Member: 527046 Status: Offline Thanks Meter: 97 | Request ROM Alcatel 5036a Hi to all, have a nice day. can you help me with rom stock for alcatel 5036a PID - 5036a-2CUFMX1? i have tried with this rom: ALCATEL ONE TOUCH 5036A_141015_110328.rar but itīs on alcatel bootloop. thanks in advance. |
The Following User Says Thank You to hyber_99 For This Useful Post: |
04-18-2015, 19:42 | #3 (permalink) | |
Member: 163 Status: Offline Thanks Meter: 7,785 | Quote:
If not, firt do that, and make Wipe Cache / Data, then reboot phone, and see if it power on. Second Question: Did you flash all files ? In archive, there is ALL needed to revive DEAD phone. Download attached scatter file, and put into folder where you unpacked that rom, open scatter (attached one) in SPFT, ALL files should be checked (marked, ticked), and Flash phone. Should power on after that (make reset from recovery also). post results. b.r. Alex
__________________ Always press THANKS button if my post was helpful! Please DO NOT send me PM's for help, You can ask for help on forum Do not post THANKS posts - use thanks button ! ALWAYS use SEARCH button before posting! | |
The Following 2 Users Say Thank You to Brka For This Useful Post: |
04-20-2015, 12:24 | #6 (permalink) |
Member: 163 Status: Offline Thanks Meter: 7,785 | ROM is tested, and working, but provided scatter is wrong. Use attached scatter (from my previous post), it will work, for sure. (if phone hardware is ok). B.r. Alex
__________________ Always press THANKS button if my post was helpful! Please DO NOT send me PM's for help, You can ask for help on forum Do not post THANKS posts - use thanks button ! ALWAYS use SEARCH button before posting! Last edited by Brka; 04-20-2015 at 19:35. Reason: added info |
The Following User Says Thank You to Brka For This Useful Post: |
07-06-2015, 19:58 | #7 (permalink) | |
Junior Member Join Date: Mar 2013 Location: Malaysia Age: 35
Member: 1895835 Status: Offline Sonork: asrikerex Thanks Meter: 0 | Quote:
I've try flash file from 5036A with SPFT version v3.1332.0 and version v5.1516 but it stay boot loop. even after Wipe data. Please help me. Here product code: 5037X-2ADHMY1 | |
07-06-2015, 20:16 | #8 (permalink) | |
b.r. Alex
07-06-2015, 23:46 | #10 (permalink) | |
whole map of eMMC memory in phone. Open with text editor, and check for yourself. Anyway, you can read pro_info from your phone, edit it and write back. Use attached scatter file, load in spft, go to Read Back tab, press ADD, double click on new appeared item, select save location, enter start address : 0x700000 , length : 0x300000 After finished reading, use Notepad++ or some hex editor, find original PID string inside, change to some other, get back to Download tab, manually tick "pro_info", select file you edited, and download to phone. If for some reason reports error, you can go to drop down menu "Window", select "Write Memory", and under new tab, you can open pro_info file, ("open raw data"), select "emmc", input start address (same as for reading), and length, and press "Write memory", after connect powered off phone to cable. 5037X, there is only one pid : 5037X-2ADHMY1 ; Try with 5036X , pid's : 5036X-2AALEU1 or 5036X-2AALFR1 or 5036X-2AALGB1 post results. b.r. Alex
08-25-2015, 22:02 | #11 (permalink) |
Junior Member Join Date: Aug 2015
Member: 2449800 Status: Offline Thanks Meter: 0 | can you help me find that room pls....thank in advance mine are not all checked the ones missing are protect_s protect_f and custpack, mobile_info but the files are in the folder why is this happening?? Last edited by Brka; 09-22-2015 at 19:59. Reason: merged, no reason to write multiple posts for one thing |
09-17-2015, 00:45 | #12 (permalink) | |
Junior Member Join Date: Feb 2015 Location: San Francisco, Camotes
Member: 2349359 Status: Offline Sonork: 100.1662822 Thanks Meter: 3 | Quote:
5063a but i recieve an error relating cache. i found out that the file i downloaded has no CACHE plss share im still working on | |
09-17-2015, 02:01 | #13 (permalink) |
Member: 163 Status: Offline Thanks Meter: 7,785 | You dont need cache. Make format, Reflash the phone and after flashing, Do wipe data/cache from recovery. B.r. Alex
09-22-2015, 19:56 | #15 (permalink) |
