Alcatel TCL Phones and New Models OT, OH & E series, and all new TCL and Alcatel Models which are not listed in upper sections. |
07-29-2016, 11:15 | #1 (permalink) |
Junior Member Join Date: May 2016 Location: Egypt
Member: 2571486 Status: Offline Sonork: N/A Thanks Meter: 0 | Alcatel one touch EVO7 (RockChip) dead after flashing !! I flashed it with (EVO7 HD [E710] Android 4.1.1) firmware Now it's dead plz help .. |
07-30-2016, 16:34 | #2 (permalink) | |
Member: 163 Status: Offline Thanks Meter: 7,785 | Quote:
EVO 7HD = E710 / JUPITER Download - HERE V184AU182ALEU1 Post results. b.r. Alex
__________________ Always press THANKS button if my post was helpful! Please DO NOT send me PM's for help, You can ask for help on forum Do not post THANKS posts - use thanks button ! ALWAYS use SEARCH button before posting! Last edited by Brka; 12-04-2018 at 00:33. Reason: added some info | |
The Following 6 Users Say Thank You to Brka For This Useful Post: |
08-16-2016, 02:54 | #3 (permalink) |
Member: 2571486 Status: Offline Sonork: N/A Thanks Meter: 0 | Thanks for replying .. I have solved it by another firmware and it back to life again : I didn't get enough time to try your firmware .. thanks any way .. |
08-16-2016, 03:04 | #4 (permalink) | |
b.r. Alex
__________________ Always press THANKS button if my post was helpful! Please DO NOT send me PM's for help, You can ask for help on forum Do not post THANKS posts - use thanks button ! ALWAYS use SEARCH button before posting! | |
The Following 2 Users Say Thank You to Brka For This Useful Post: |
03-20-2017, 14:16 | #5 (permalink) |
No Life Poster Join Date: Jul 2004 Location: Ukraine Age: 44
Member: 75408 Status: Offline Thanks Meter: 1,190 | Brka, thanx, factory firmware tested and worked: Code: 15:06:24 954 Layer<2-1-4>:Download Boot Start 15:06:27 136 Layer<2-1-4>:Download Boot Success 15:06:27 138 Layer<2-1-4>:Wait For Maskrom Start 15:06:27 683 Layer<2-1-4>:Wait For Maskrom Success 15:06:27 685 Layer<2-1-4>:Test Device Start 15:06:27 687 Layer<2-1-4>:Test Device Success 15:06:27 688 Layer<2-1-4>:Check Chip Start 15:06:27 691 Layer<2-1-4>: Check Chip Success 15:06:27 692 Layer<2-1-4>:Get FlashInfo Start 15:06:27 694 <LAYER 2-1-4> INFO:FlashInfo: 00 00 80 00 00 08 08 18 1E 04 01 15:06:27 695 Layer<2-1-4>:Get FlashInfo Success 15:06:27 697 Layer<2-1-4>:Prepare IDB Start 15:06:27 697 <LAYER 2-1-4> INFO:CS(1) (4096MB) (MICRON) 15:06:27 730 Layer<2-1-4>:Prepare IDB Success 15:06:27 732 Layer<2-1-4>:Download IDB Start 15:06:28 806 <LAYER 2-1-4> ERROR:LowerFormatDevice-->Not support lowerformat 15:06:28 808 Layer<2-1-4>:Download IDB Success 15:06:28 810 Layer<2-1-4>:Reset Device Start 15:06:29 813 Layer<2-1-4>:Reset Device Success 15:06:29 816 Layer<2-1-4>:Wait For Loader Start 15:06:30 647 Layer<2-1-4>:Wait For Loader Success 15:06:30 650 Layer<2-1-4>:Test Device Start 15:06:31 660 Layer<2-1-4>:Test Device Success 15:06:31 662 Layer<2-1-4>:Download Firmware Start 15:10:54 084 Layer<2-1-4>:Download Firmware Success 15:10:54 089 Layer<2-1-4>:Reset Device Start 15:10:55 095 Layer<2-1-4>:Reset Device Success |
The Following 2 Users Say Thank You to Dr_Wolodya For This Useful Post: |
12-03-2018, 16:47 | #6 (permalink) |
Freak Poster Join Date: Sep 2016 Location: Rawalpindi
Member: 2628591 Status: Offline Sonork: 100.1582347 Thanks Meter: 85 | Hi sir, After flash its still stuck in same position as its attach to computer although button are not pressed. whats may be reason. need help. Thanks Br, raja |
12-04-2018, 00:32 | #8 (permalink) |
Member: 163 Status: Offline Thanks Meter: 7,785 | @Rajamtkmaster Problem can also be hardware, not only software (malfunctioned flash memory) @romeoalmajeko RockChip devices are usually flashed by holding volume up + inserting usb cable, PC should detect RK Device and istall drivers (or after volume up + insert cable, while holding volume up, press 5-8 times power on button). If none works, probably damaged usb connector or some other, hardware problem. b.r. Alex
12-04-2018, 21:39 | #10 (permalink) | |
Also, you need to post correct PID of the device, to get original ROM for your device region/state/country. b.r. Alex
