Alcatel TCL Phones and New Models OT, OH & E series, and all new TCL and Alcatel Models which are not listed in upper sections. |
12-18-2014, 06:59 | #1 (permalink) |
Junior Member Join Date: Oct 2012
Member: 1824797 Status: Offline Thanks Meter: 0 | alcatel one touch x'pop 5035x displays nothing "black sreeen" how I can solve this problem plz help |
12-19-2014, 00:00 | #4 (permalink) | |
Member: 163 Status: Offline Thanks Meter: 7,778 | Quote:
okay ... - download SPFlashTool v3.1244 ... HERE - download full backup for SPFlashTools ... HERE - Unpack all - in SPFlashTools ... go to Scatter-Loading button, open MT6577_Android_scatter_emmc.txt - click on RECOVERY, select manually factory_NONmodified_recovery.img - DOWNLOAD BUTTON, connect powered off phone to cable ... post results. p.s. You can try manually selecting also, CUSTPACK (custpack2.img), and MOBILE_INFO (mobile_info.img) b.r. Alex Last edited by Brka; 12-19-2014 at 00:09. | |
The Following User Says Thank You to Brka For This Useful Post: |
12-19-2014, 17:19 | #6 (permalink) |
Member: 163 Status: Offline Thanks Meter: 7,778 | use scatter from folder where you unpacked Flash File, that way SPFlashTool defaults to that folder, and use files there. and if still the same, try re-installing the drivers, or if you already did full format on phone, try holding volume up and insert cable when start flashing. b.r. Alex |
12-20-2014, 20:15 | #8 (permalink) |
Member: 163 Status: Offline Thanks Meter: 7,778 | ok, - download latest SPFlashTool ... HERE - load scatter from unpacked rom folder, don't change anything in there, boot etc., leave as is - try to flash the phone - post results. b.r. Alex |
12-21-2014, 19:37 | #10 (permalink) | |
Member: 163 Status: Offline Thanks Meter: 7,778 | Quote: if you are good in hardware repairs, disassemble phone, check if NAND is not glued, and re-heat it with hot air gun (resolder). and of course, repeat steps with SPFlashTools, if after re-heating not power on. post results. b.r. Alex | |
