Alcatel TCL Phones and New Models OT, OH & E series, and all new TCL and Alcatel Models which are not listed in upper sections. |
04-28-2017, 19:29 | #2 (permalink) |
No Life Poster Join Date: Jul 2001 Age: 42
Member: 5184 Status: Offline Thanks Meter: 246 | Your firmware: alcatel 5010u & 5010d firmware |
The Following 2 Users Say Thank You to boganice For This Useful Post: |
04-29-2017, 12:22 | #3 (permalink) | |
Banned Join Date: May 2004 Location: Mauritius
Member: 64823 Status: Offline Thanks Meter: 438 | Quote:
5010u-2galap1-1 | |
The Following User Says Thank You to zakiyyboss For This Useful Post: |
05-03-2017, 21:58 | #6 (permalink) |
Member: 163 Status: Offline Thanks Meter: 7,777 | Without working phone to read backup, and write to that "problematic", is hard to say if you have software or hardware problem. Rom file itself is not available on support, only via service access - means, you need to send phone to some of alcatel authorized service centers for repair. b.r. Alex
__________________ Always press THANKS button if my post was helpful! Please DO NOT send me PM's for help, You can ask for help on forum Do not post THANKS posts - use thanks button ! ALWAYS use SEARCH button before posting! |
05-04-2017, 09:50 | #7 (permalink) | |
05-23-2017, 21:44 | #9 (permalink) |
Freak Poster Join Date: Oct 2009 Location: bahrain Age: 41
Member: 1150070 Status: Offline Thanks Meter: 29 | Alcatel pixi 4 (5) 5010u Hello I have problem my Alcatel 5010u locked with google account. I have tried to formatted with flash tool. Now the phone booting with white screen only I can't boot it to recovery mode to wipe it. Please advise Sent from my iPhone using Tapatalk |
05-24-2017, 19:44 | #10 (permalink) | |
Member: 163 Status: Offline Thanks Meter: 7,777 | Quote:
then write to faulty phone(s). Another advice : NEVER EVER fully format ANY MTK phone, without making ROM backup before that. And, 3rd advice - don't open new thread for same model of phone. You can use existing one(s). b.r. Alex
__________________ Always press THANKS button if my post was helpful! Please DO NOT send me PM's for help, You can ask for help on forum Do not post THANKS posts - use thanks button ! ALWAYS use SEARCH button before posting! | |
The Following User Says Thank You to Brka For This Useful Post: |
05-24-2017, 21:47 | #11 (permalink) |
Member: 1150070 Status: Offline Thanks Meter: 29 | Thanks for ur reply First of all I'm sorry to open new thread I tried to figure out but I'm not understanding the flash tutorials this is my first time using flash tool. Appreciate if u can help me more with more explanation about the backup how can I do the if some one can give me a valid backup. ****** EDIT : I found someone has the same phone What is the next step? How I can back up the new phone and restore the backup in the old one ? Last edited by Brka; 05-25-2017 at 00:36. Reason: merged posts |
05-25-2017, 01:45 | #12 (permalink) |
Member: 163 Status: Offline Thanks Meter: 7,777 | Use attached scatter file, load it in SPFlashTools, Go to tab "Readback", click on icon "Add", then double-click on newly appeared row, select save location and file name - ie: 5010u_full_readback.bin , type is hex, region is emmc_user , start address 0x0 , length : 0x79000000 Press "Readback" (green arrow icon), and connect powered off phone to cable, wait for read process to finish. Now you have working ROM readback, which have all needed files, and is single-file. To write to another phone : Start SPFT, load attached scatter file, press on keyboard CTRL + ALT + V , spft will show "Advanced mode", then go to drop-down menu "Window", and click on "Write memory" , new TAB will appear , "Write memory". Select file that you read in previous steps (5010u_full_readback.bin), begin address : 0x0 , click on "Write memory" icon, and connect powered off phone to cable. Wait for writing to finish, disconnect phone, boot it into recovery mode (volume UP + power on), and from recovery do "Wipe data / cache", then "reboot phone". At that moment ... Alcatel logo should appear, just connect charger, and leave it to fully boot, and don't worry - it may take up to 10 minutes. Or ... if after writing it doesn't power on, connect charger, and wait to see if it will start charging. If so - leave it to charge ~5-10%, then do the same steps from recovery, wipe data/cache , reboot. That should be it. If all goes well, use WinRAR, or 7zip and BEST / Ultra compression, pack the readed file, together with scatter file, and upload to google drive, or some "normal" hoster (Mega.nz, MediaFire, etc.), so others can unbrick, and revive their phones too. Happy unbricking ! Post results .... b.r. Alex
The Following 3 Users Say Thank You to Brka For This Useful Post: |
05-25-2017, 08:14 | #13 (permalink) |
Member: 1150070 Status: Offline Thanks Meter: 29 | You're Amazing I will do it tonight when I back from work. Cheers Sent from my iPhone using Tapatalk Last edited by Brka; 05-25-2017 at 21:48. Reason: removed quoting |
05-25-2017, 21:09 | #14 (permalink) | |
Member: 1150070 Status: Offline Thanks Meter: 29 | Quote:
I'm getting error In here my files Sent from my iPhone using Tapatalk | |
05-25-2017, 21:52 | #15 (permalink) |
Member: 163 Status: Offline Thanks Meter: 7,777 | For beginning, try with other SPFlashTools, if still the same, Probably phone have hardware problem. But, without using some commercial box to repeat operation, cant be 100% sure. Anyway you can still upload flash file ... b.r. Alex
