Alcatel TCL Phones and New Models OT, OH & E series, and all new TCL and Alcatel Models which are not listed in upper sections. |
01-20-2015, 00:04 | #1 (permalink) |
Freak Poster Join Date: Feb 2012 Location: Hungary Age: 37
Member: 1720556 Status: Offline Thanks Meter: 57 | Alcatel Ot 6036Y recovery backup or reflash firmware need Only t-mobile logo appears and nothing happen. My customer tried the flash but not succes and this happened . i wait for someone can halp me . thanks |
The Following User Says Thank You to sinji1 For This Useful Post: |
01-20-2015, 05:49 | #2 (permalink) | |
No Life Poster Join Date: May 2001 Location: Bulgaria Age: 56
Member: 4627 Status: Offline Sonork: 57528:debeliamark Thanks Meter: 1,034 | Quote:
The Following User Says Thank You to debeliamark For This Useful Post: |
01-20-2015, 22:57 | #3 (permalink) |
Member: 163 Status: Offline Thanks Meter: 7,785 | In addition to debeliamarks post, New Alcatel Qualcomm phones are not the thing to play with, because if OTU Updater refuse the update, saying that "you already have the latest version", only solution is bring dead phone to someone who have alcatel service access, to reflash the phone on service software (forced restore/update). I hope you succeeded with OTU updater... otherwise, start looking for someone with mentioned tools/access. b.r. Alex |
02-27-2015, 20:48 | #5 (permalink) | |
Member: 163 Status: Offline Thanks Meter: 7,785 | Quote:
Actually, I found out that you CAN make "clean" backup and restore to other, dead phones. Alcatel QCom models have "Qualcomm EMMC mode", with volume down + power button, in which, you can see it as RAW Hard Disk with partitions. In such mode, you can use HDD Raw Copy portable, and make Full image from working phone, which can be written into dead phone, and after first power on, it will re-create NVM area, imei, but wifi/bt mac will be changed, which is ok. or if phone still can power on, you can root it, mount some mmcblkp partition, change pid, and use OTU updater. b.r. Alex | |
05-04-2015, 14:04 | #6 (permalink) | |
No Life Poster Join Date: Jul 2002 Location: Hungary, Győr Age: 46
Member: 13569 Status: Offline Sonork: 1619596 Thanks Meter: 72 | Quote:
Did you try this (first method) by yourself, or this is only a theory? Many thanx. dazexy | |
05-04-2015, 19:34 | #7 (permalink) | |
I baked up and restored my 6016x this way, even put some Russian rooted rom. That is full backup, even with user data. b.r. Alex
__________________ Always press THANKS button if my post was helpful! Please DO NOT send me PM's for help, You can ask for help on forum Do not post THANKS posts - use thanks button ! ALWAYS use SEARCH button before posting! | |
05-04-2015, 21:28 | #8 (permalink) |
Member: 13569 Status: Offline Sonork: 1619596 Thanks Meter: 72 | Oh my g0d... if i knew this method earlier, I didn't do that horrible slow jtaging with some Ot-995. Many thanx for responding. |
05-04-2015, 21:52 | #9 (permalink) | |
with key combination, but with QPST software, and switching into DLOAD mode. and btw, if it was detected via pc as HS-USB 9008 port, it could be repaired with QPST only, no any JTAG needed, like most Qualcomm's. (although, maybe some tespoints needed for forced HS-USB 9008 mode). QPST is in fact intended for such things, to fill empty boards. There are 2 modes : no/dead boot = hs-usb 9008, boot alive and eMMC mode available for raw programming = hs-usb 9006 p.s. OTU updater for Qualcomm alacatels, is in fact QPST module, with scripts, it do all those things like manually with QPST. b.r. Alex
__________________ Always press THANKS button if my post was helpful! Please DO NOT send me PM's for help, You can ask for help on forum Do not post THANKS posts - use thanks button ! ALWAYS use SEARCH button before posting! Last edited by Brka; 05-04-2015 at 21:59. Reason: added some info | |
The Following User Says Thank You to Brka For This Useful Post: |
02-03-2016, 18:17 | #10 (permalink) |
No Life Poster Join Date: Sep 2007 Location: Gizah/Egypt Age: 33
Member: 594436 Status: Offline Sonork: 100.1657777 Thanks Meter: 952 | Here is the 2 Stock FWs for this model backed up with two different methods, :: TWRP Backup
:: Mobile Upgrade Q 4.5.4 Downloaded Folder
BR |
09-20-2016, 16:58 | #11 (permalink) |
No Life Poster Join Date: May 2005 Age: 40
Member: 146708 Status: Offline Sonork: 100.108221 Thanks Meter: 1,603 | i think i bricked a 6036y..even i have the full dump (8gb) emmcraw tool..but after flashing the dump device still stucks at qualcomm emmc mode.. |
09-20-2016, 21:49 | #12 (permalink) | |
Latest OTU Updater Q 5.1.2 - HERE p.s. If you still have eMMC drive, and eMMC Raw tool can see it, we can still change PID, and force OTU Updater to flash it. Partition you are looking for is called "Traceability", it's actually pro_info partition ... Changing pid to some retail, ie: 6036Y-2AALFR1 or 6036Y-2AALEU1 should do the job, and trick OTU to start update it. So, just read it, write back, close eMMC raw tool, start OTU Updater .... p.s.2 When you put phone to eMMC mode, OTU should read it and start updating ... post results ... b.r. Alex
09-21-2016, 08:10 | #13 (permalink) | |
Member: 146708 Status: Offline Sonork: 100.108221 Thanks Meter: 1,603 | Quote:
i fixed it.. i will add all details.. just let me try changing language... | |
09-21-2016, 09:48 | #14 (permalink) |
Member: 146708 Status: Offline Sonork: 100.108221 Thanks Meter: 1,603 | hey.. device has no parittion..only i can read the DUMP.. and if i edited the PID in dump updater gives attention.. there is no new sw for ur device.. maybe if we can find the twrp old android (4.1.2) backup maybe we can solve the pb... because if i edit (from 2ABGRU7 to 2AALDE7) and write the old dump which taken before updated is useless..again same error; there is now new sw for ur device.. |
09-21-2016, 17:08 | #15 (permalink) |
Member: 163 Status: Offline Thanks Meter: 7,785 | Try with 2AALFR1, its retail france pid, should update.... B.r. Alex
