Go Back   GSM-Forum > GSM & CDMA Phones / Tablets Software & Hardware Area > Alcatel > Alcatel TCL Phones and New Models
Alcatel TCL Phones and New Models OT, OH & E series, and all new TCL and Alcatel Models which are not listed in upper sections.
Old 01-04-2017, 21:18   #16 (permalink)
daroas's Avatar
Member: 194078
Sonork: no have
Thanks Meter: 209
Hello,the device not find for Firmware write in SP Flash Tool..
Originally Posted by Brka View Post
4017f-2xALBR1 - RETAIL BRASIL, Unbranded firmware
Download - HERE
press thanks if helped
b.r.
ALex
Old 01-04-2017, 22:04   #17 (permalink)
Moderator
Brka's Avatar
Member: 163
Thanks Meter: 7,785
What does that mean ???
__________________
Always press THANKS button if my post was helpful!
Please DO NOT send me PM's for help, You can ask for help on forum
Do not post THANKS posts - use thanks button !
ALWAYS use SEARCH button before posting!
Old 01-05-2017, 11:45   #18 (permalink)
daroas's Avatar
Member: 194078
Sonork: no have
Thanks Meter: 209
4017f hang's on logo after make FRP process with 4017x.
After make 4017f firmware the device power on,but after time hang's on logo.
Yesterday i make sucess in flash for SPFT holding Volume + and Power On with Elastic but only show Logo alcatel and Pixi4 and restar
Old 01-05-2017, 21:11   #19 (permalink)
Moderator
Brka's Avatar
Member: 163
Thanks Meter: 7,785
Did you maybe make full phone format ?
b.r.
Alex
__________________
Old 01-06-2017, 18:36   #20 (permalink)
daroas's Avatar
Member: 194078
Sonork: no have
Thanks Meter: 209
I believe that yes, I'm not sure
b.r.
Alex
Old 01-06-2017, 22:08   #21 (permalink)
Moderator
Brka's Avatar
Member: 163
Thanks Meter: 7,785
That is very probably the reason of phone hanging on logo ...
after flashing, try to make wipe data/cache from recovery,
it that dont helps, you will need full rom_0 backup from working phone.
flash file i provided is factory original stock rom, it is 100% ok.
b.r.
Alex
__________________
The Following User Says Thank You to Brka For This Useful Post:
Old 03-10-2017, 14:01   #22 (permalink)
Member: 2014547
Sonork: 100.1665176
Thanks Meter: 18
Before being so aggressive and flash the nand, try this software solution, it worked smooth for me, i tried it on my PIXI 4 6".
https : / / www . youtube . com / watch?v=2LuT_sJkTPM
Press Thanks if it works for you too .)
Old 03-10-2017, 14:25   #23 (permalink)
Moderator
Brka's Avatar
Member: 163
Thanks Meter: 7,785
It's not nand, but emmc. And if address is correct,
It's 5 seconds job.
Of course, there are bypass methods, agree on that.
B.r.
Alex
__________________
Old 03-10-2017, 14:44   #24 (permalink)
Member: 2014547
Sonork: 100.1665176
Thanks Meter: 18
It's 5 seconds job.
B.r.
Alex
Indeed "if" the address is correct, if not that procedure can cause other issue to the device, there are a lot of models and variants and the adress you want to overwrite can be different so i think a soft bypass is much better, and i suggest to try hard to found that software bypass before going for flash eMMC
Old 03-10-2017, 15:25   #25 (permalink)
Member: 1056722
Thanks Meter: 19
Please,after make Repair FRP,the Alcatel 4017f show Alcatel and restar
just hard reset your phone and it is done!!!
Old 03-10-2017, 22:19   #26 (permalink)
Moderator
Brka's Avatar
Member: 163
Thanks Meter: 7,785
There is nothing "scary" in that procedure. It's uncomparable faster and working.
And there is no any "IF", because I'm not guessing the address,
it's correct address for that model.
Each (MTK) brand, model have mostly different address,
and there should be no guessing. Only correct ones.
b.r.
Alex
__________________
Old 09-17-2017, 21:09   #27 (permalink)
Member: 1058551
Download attached scatter file, Download some SPFlashTools v5.12xxxx,
Load scatter file, go to "Format" tab, "Manual format", tick "Validation",
Begin address : 0x4200000, Format length: 0x100000
Press "Start", connect powered off phone to cable, wait for finish,
Restart phone, wait for boot. FRP Should be gone.
If not, repeat procedure, boot phone in recovery, volume up + power on key,
make wipe data/cache.
If, for some reason, phone is not detected, Install Official OTU Updater , it will install needed drivers.
b.r.
Alex
This worked for me, I have the 4017a model
Old 08-24-2020, 07:40   #28 (permalink)
Member: 2171555
Thanks Meter: 129
i need help twrp
hi i need help 4017x 3.5 twrp .....
Old 08-25-2020, 01:45   #29 (permalink)
Moderator
Brka's Avatar
Member: 163
Thanks Meter: 7,785
Download: 4017x_twrp_recovery
It's made for Android 5.x ... hope that it's the one in your device ?
Additional Download: pixi4_4017x_CTR_recovery
p.s. Merged with some existing thread for 4017x ...
b.r.
Alex
__________________
Page generated in 0.21711 seconds with 9 queries
