Alcatel TCL Phones and New Models OT, OH & E series, and all new TCL and Alcatel Models which are not listed in upper sections. |
09-15-2016, 21:55 | #1 (permalink) |
No Life Poster Join Date: Oct 2005 Location: Ubá--Brazil Age: 34
Member: 194078 Status: Offline Sonork: no have Thanks Meter: 209 | Alcatel Pixi 3 (4,5) 4017x (A,X,F) FRP Lock Remove, TWRP some procedures that need to hold home button but not succeeded . someone help ? |
09-15-2016, 22:29 | #2 (permalink) | |
Member: 163 Status: Offline Thanks Meter: 7,785 | Quote:
Load scatter file, go to "Format" tab, "Manual format", tcik "Validation", Begin address : 0x4200000, Format length: 0x100000 Press "Start", connect powered off phone to cable, wait for finish, Restart phone, wait for boot. FRP Should be gone. If not, repeat procedure, boot phone in recovery, volume up + power on key, make wipe data/cache. If, for some reason, phone is not detected, Install Official OTU Updater , it will install needed drivers. b.r. Alex
__________________ Always press THANKS button if my post was helpful! Please DO NOT send me PM's for help, You can ask for help on forum Do not post THANKS posts - use thanks button ! ALWAYS use SEARCH button before posting! | |
The Following 8 Users Say Thank You to Brka For This Useful Post: |
10-14-2016, 15:44 | #5 (permalink) | |
Try wipe data/cache from recovery, see if that helps. B.r. Alex
10-15-2016, 22:34 | #7 (permalink) |
The Following 4 Users Say Thank You to Brka For This Useful Post: |
10-16-2016, 21:25 | #8 (permalink) |
Junior Member Join Date: Oct 2016
Member: 2637716 Status: Offline Thanks Meter: 0 | Please Help Me hello my problem is that I also have a pixi 3 4.5 but the model is not the 4017f is 4017A and has the famous google lock,I have 3 days without results, someone can me help Do PD: I try with mobile upgrade for alcatel but still the same |
10-17-2016, 20:41 | #10 (permalink) | |
Load scatter file, go to "Format" tab, "Manual format", tick "Validation", Begin address : 0x4200000, Format length: 0x100000 Press "Start", connect powered off phone to cable, wait for finish, Restart phone, wait for boot. FRP Should be gone. If not, repeat procedure, boot phone in recovery, volume up + power on key, make wipe data/cache. If, for some reason, phone is not detected, Install Official OTU Updater , it will install needed drivers. b.r. Alex
__________________ Always press THANKS button if my post was helpful! Please DO NOT send me PM's for help, You can ask for help on forum Do not post THANKS posts - use thanks button ! ALWAYS use SEARCH button before posting! Last edited by Brka; 10-17-2016 at 20:48. | |
The Following 3 Users Say Thank You to Brka For This Useful Post: |
10-17-2016, 20:45 | #11 (permalink) | |
Load scatter file, go to "Format" tab, "Manual format", tick "Validation", Begin address : 0x4200000 , Format length: 0x100000 Press "Start", connect powered off phone to cable, wait for finish, Restart phone, wait for boot. FRP Should be gone. If not, repeat procedure, boot phone in recovery, volume up + power on key, make wipe data/cache. b.r. Alex
10-24-2016, 13:27 | #12 (permalink) | |
Junior Member Join Date: Sep 2013
Member: 2033727 Status: Offline Thanks Meter: 3 | Quote:
Where I can find the others ROMs for others models for Alcatel? tks This Metod works on 4017F Brazil | |
10-24-2016, 17:20 | #13 (permalink) |
Member: 163 Status: Offline Thanks Meter: 7,785 | Nowhere. B.r. Alex
11-29-2016, 02:12 | #14 (permalink) | |
Junior Member Join Date: Nov 2016
Member: 2654633 Status: Offline Thanks Meter: 0 | Working This method is working, after a lot of searching, crashing computer i remove the frp. Quote:
