Alcatel TCL Phones and New Models OT, OH & E series, and all new TCL and Alcatel Models which are not listed in upper sections. |
03-23-2018, 00:52 | #46 (permalink) |
Member: 163 Status: Offline Thanks Meter: 7,785 | As previously stated, all needed can be found on these 3 pages. (or post #5.) or if you are too lazy - HERE *** edit: Found some more ROMs : - Russian v01004 Stock backup 4034D , flash via "firmware upgrade" option in SPFT - Stock rom backup via box LINK1 or LINK2 - Use scatter attached to this post if you get error loading, replace original Try them, if you get brick after flash - try flash only preloader from 4034x rom, or preloader from some other rom. You can "mix" files from different roms (like system.img, custpack.img) and use scatter files from other roms. p.s. If it still breaks down after few weeks, it's definatly not software problem... b.r. Alex
__________________ Always press THANKS button if my post was helpful! Please DO NOT send me PM's for help, You can ask for help on forum Do not post THANKS posts - use thanks button ! ALWAYS use SEARCH button before posting! Last edited by Brka; 03-23-2018 at 01:26. Reason: added more info |
The Following User Says Thank You to Brka For This Useful Post: |
03-01-2019, 22:55 | #48 (permalink) | |
Member: 163 Status: Offline Thanks Meter: 7,785 | Quote:
If your phone power on, UNTICK preloader when flashing. test and post results. b.r. Alex
__________________ Always press THANKS button if my post was helpful! Please DO NOT send me PM's for help, You can ask for help on forum Do not post THANKS posts - use thanks button ! ALWAYS use SEARCH button before posting! | |
The Following 2 Users Say Thank You to Brka For This Useful Post: |
03-06-2019, 21:03 | #50 (permalink) |
Member: 163 Status: Offline Thanks Meter: 7,785 | Please read this thread : Alcatal PIXI4 (4) 4034x Firmware Needed - GSM-Forum and on last page, my last post. Hopefully, that rom should have Poland lang, but no guarantee. However, if you have bricked phone - that's how to unbrick it. b.r. Alex
03-08-2019, 16:20 | #52 (permalink) |
Freak Poster Join Date: Mar 2004 Location: VoiD
Member: 59737 Status: Offline Sonork: 100.1603188 Thanks Meter: 18 | As mentioned, write firmware (it's the only firmware which worked on my piece), edit proinfo (PL T-Mobile PID - you need to check) use mobile s upgrade gotu or however it is called and you are done. If needed please let me know, will give you proinfo file from PL T-Mobile |
07-24-2019, 21:00 | #54 (permalink) |
Junior Member Join Date: Dec 2015 Location: Trebinje Age: 33
Member: 2508042 Status: Offline Thanks Meter: 3 | @Brka I have Alcatel 4034D 2AALE31, killed with xxxx box trying to reset frp...BROM error all i got... I have tried with couple fw's i found but always same error. Even with xxxx or xxxxx ...do you have exactly fw which i need or suitable DA? Last edited by Brka; 10-24-2019 at 22:55. Reason: removed boxes |
10-24-2019, 22:56 | #57 (permalink) | |
Don't have it. Use PID change method + official updater. Read sticky threads please : http://forum.gsmhosting.com/vbb/f317...first-1893215/ http://forum.gsmhosting.com/vbb/f317...phone-1896218/ Exactly as written on previous answer. b.r. Alex
10-25-2019, 14:42 | #58 (permalink) |
No Life Poster Join Date: Sep 2009 Location: pakistan
Member: 1119917 Status: Offline Sonork: nedi Thanks Meter: 190 | 4034d-2GALWE1 solution needed............ dear brka bro my set was ok just pattern and after format with xxxxxx box now set is only logo on and i tried many files but same set 4034d-2GALWE1 and please give me solution to revive this set Last edited by Brka; 10-26-2019 at 23:08. Reason: removed boxes |
10-26-2019, 23:10 | #59 (permalink) | |
Check here (post #2) : http://forum.gsmhosting.com/vbb/f317...first-1893215/ b.r. Alex
