How can i Hard Reset my Alcatel OT-990? Recently i bought an Alcatel ot-990 which is an Android 2.2 Froyo and it has some hardware defects so i returned it and replaced with another piece of handset and now again it has a software problem which turn offs the display when i got a call or at making a call...! can't able to disconnect a call from my side coz it's completely a touch screen...!even though i reset the mobile also i faces the same problem... can somebody help me here... thanks in advance |
Hold down # key and press Power key for a while to reset phone, or if you have acces to meny, from main menu select restore default set then enter master code 25228353. |
hold volume down and power on |
good formation if you likr to recet alcatil ot990 you can hold volume down and power or from main menu select restore default set then enter master code 25228353. :) :) |
It won't have a # button it's a touch screen mobile Quote:
By holding volume down and powering on it switch on's normally Quote:
When phone is power off long press volume UP+ power ON. I reset one OT-990 now with this solution. |
hard reset ot990 by this. |
press volume up+powr, when phone swiths on release the power but keep holding volume up,,,, u will see reset menu |
Alcatel OT 990 hard reset Alcatel OT 990 mobile phone is frozen, can power on Make sure your battery is not completely used up or damaged Remove your battery, remove your SIM card then reinstall them to power on again, if still does not work Try the Volume UP + POWER on trick to get into recovery menu. ALL User phone data: contacts, photos, messages and files, downloaded applications like Java games will be lost permanently. From the main menu, select the menu icon and select Restore default set. Alcatel master code 25228353 |
hold volume up and power on its worket 100/100 |
Yes the above one is a working solution. |
Hard reset ot-990: Telenor One Touch hard reset - YouTube |
i have alcatel one tuch 990 display show blue light any solution |
